RTz
Administrators
    23
Everything posted by RTz
  1. Hey Bo, That shows pin 9 to be the thermo fan... which it very well may be. Problem is, there are other pins that don't match.
  2. I'm installing a '98 180sx Engine/ECU/Harness in my 510. I've managed to figure out every wire/pin-out except one... pin 9 (green w/red stripe). I hate to buy a FSM for one lousy wire Anybody know what this pin feeds, or have a '97-'98 FSM?
  3. V4 will go sequential ignition up to 4 cylinders, V4+ 6 cylinders, and V500 is capable of 8 cylinder sequential.
  4. Hey Pete! I didn't know you had finished that up. Nice.
  5. Yeah, momentary loss of brain activity.
  6. I've done it a couple times. So has Hughdogz & KTM. Easiest way is to use the '83-'84 280zxt CAS sensor. EDIS isn't directly compatible with Wolf.
  7. The lower the weld, the more force its exposed to. I prefer to section just below the gland nut threads.
  8. I hear Vette's work pretty well Not sure what kind of pic you're looking for, but here are a couple... C4 5-link... C5 Double A-arm... Notice the whole cradle is 'rotated'.
  9. All my digits are crossed. Good luck Doc!
  10. The stock S30 yoke fits my '98 SR20DET tranny. Wouldn't surprise me if Nissan 'stayed true' with the 350z as well.
  11. Yeah, it was an internal WG. Previous owner converted it.
  12. Nope. Stock T25. I have nothing against it. In fact, I think it could be a nice swap. I was just trying to provide back-up for the weight.
  13. I found John to be nearly spot on this weekend. We weighed a stock L24 and also a mildly mod'd SR20DET, including intercooler and plumbing. The L6 is about 30-35lbs heavier, but the SR trans is about 15 lbs heavier. Post #2 & #12... http://forums.hybridz.org/showthread.php?t=125246 Installed in like trim, total weight should be pretty darn close.
  14. SR20DET.... With aftermarket clutch, top mount exhaust manifold, external wastegate, cast pan, oil, and alternator. No water, starter, air filter, MAF, intercooler & piping... 349.8 LBS With aftermarket intercooler, complete intake piping and MAF... 365.9 LBS (Tare weight zero'd)
  15. This forum is founded on such things. Swap info is welcome and appreciated
  16. L16... (Datsun 510) 291.0 LBS Including alternator, oil, and fuel pump. No clutch, water, air filter, starter, or coil. (Tare weight zero'd)
  17. http://forums.hybridz.org/showthread.php?t=123389
  18. RTz
    RPM Shift lights
    Yup. Yes, as long as you understand a couple things... 1) the ignition outputs only pull to ground, so you'll need to provide a power source on the opposite leg. You can use 12v like you suggested, providing a properly sized resistor is used. 2) The drawback to choice #1 is potential risk of the voltage regulator going belly up, sending too much voltage to the LED (and blowing it). In my case, it would be a pain to replace a popped LED. An alternate choice is to use one of the regulated outputs on the V500. There is a spare 5v and a spare 8v power source built in for such occasions. These are regulated so you're reasonably assured a stable voltage regardless of system voltage.
  19. Let me be the first to say that I'm very pleased. The 'quietness' is a good (albeit somewhat flawed) meter. Along with the build up of cobwebs in the shed, its been a long while since any member was permanently banned. The temporary suspensions have also been reduced to a minor rate. Not bad for 16,0000 members and only a handful of active staff. My hats off to you guy's!
