RTz
Administrators
    23
Everything posted by RTz
  1. Yeeeuuuup. That's not a flame is it?
  2. Not picking on you but... if the OE manifolds had 38mm runners, this thread wouldn't exist. An N42's runners are under 32mm! The runnners shown in the above manifold are 1.5", or 38.1mm. While I'm happy with the results, and its still way early in the game, I have no reason to go larger on a street duty motor.
  3. Playing with numbers.... Bone stock L28e makes a devastating 48 Hp per liter. Installing a Braap head, header and exhuast, re-tuning the L-Jet, while retaining the stock cam/stock intake, nets you loosely 68Hp/liter... for a 40% gain. Not bad. I've seen these very results time and again from a Braap head. Further, the LJet is still manageable becuase the torque curve, while higher, still has the same overall shape. The exception is at the top, where the 'brick wall' is now more defined. The intake manifold is done. 200hp is approaching the limit on an untouched OE EFI manifold. For Rebello's hot street engines, again loosely speaking, 98+Hp/L is the norm... for an *additional* gain of 44%. This is with a serious cam, peekier, noisier, and harder on the valvtrain, coupled with a real induction system, and turning more RPM. This is a fairly nasty motor, whereas the first 40% feels like a refinement of stock... broad power and silky smooth. Yeasterday I was talking to Rebello about a specific cam, and coincidentally, Dave had just finished up dyno testing a Braap head. I'm not at liberty to disclose the numbers but lets just say I commited to one about 5 minutes after I got off the phone. Which leads to.... In the end, its *still* about the head. The induction/exhaust and cam is what make it work. Its the woman that makes the dress, not the contrary. Keeping it in perspective... at a whopping 48hp/L, almost anything has the pontential to improve the power. What an aftermarket intake manifold will normally do for an L-series is allow the engine to breath at higher rpm. RPM is where HP lives. And if its a good manifold, it won't cost you much bottom end grunt... *that's* the tricky part.
  4. Video of stand-off injectors, BMW M3 (S14)...
  5. Judgement day is just around the corner... July 14th is scheduled dyno day for the above manifold.
  6. You are correct, a better option would be a cold air intake. There are a couple reasons this car was done this way. If you'll notice, the engine compartment has been completely smoothed and painted. The removal of the AFM leaves an unattractive bracket. Due to time constraints and this car being a show car first, it was done this way, in part to hide the bracket (sits directly under the filter). Next winter's project is to relocate the battery, remove all excess bracketry, and re-spray the compartment. I might argue that, depending on where your 'at' right now. If you are currently injected and using an OE manifold, you'll notice power dropping off pretty seriously by 5500 rpm. The manifold is the leading contributor. Runners are *tiny*. Even on a bone stock L28, this manifold would wake up the top end. A couple 'gotcha's'... you will need some sort of programmable EMS as the factory L-jet would be 'lost'. Valves *will* float with stock springs. Right now, this motor, with a mild cam and matching springs, is pulling to 7300rpm... where its beginning to float valves. This manifold wants to spin! See where I'm going with this?... the issue will become one of mechanical limitations. If you address those, even on a stock cam and head, I believe there is plenty of room to justify a manifold upgrade. Just my dos pesos.
  7. I can't speak for Justin, but there is a possibility that I will make a few, with some minor cosmetic and performance enhancements. Here's the catch... they won't be inexpensive. To be profitable, $1200 to $1300 is looking like a realistic figure. Still game?
  8. As Justin has it drawn, its wide open for any type of flange. I built a Ford Crown Vic. flange, at 65mm. Bolts on in a similar fashion to OE (vertically oriented throttle shaft, though).... Keep in mind, one of the things that make this manifold work is the TB size. Not from a CFM perspective, rather an emphasis on a smooth transition from the TB to the inner walls of the plenum.
  9. With Wolf V4, the only option was hard cutting fuel. Wolf V500 is a bit more refined. The primary choices are Hard Cut Fuel, Hard Cut Ignition, Both, or soft cutting ignition. The soft cut can be tuned and staged with a hard cut. For example, you can cut '4 in 8', cutting every second event. '6 in 8' would be approaching a hard cut, and '1 in 8' the opposite.
  10. I'm leaving up to the Divine. I have listed it pretty steep... maybe it won't sell. The downside is, if I keep it, it will hinder my Datsun development. Thank you. Its one of my favorites as well. Its a terrific handling car AND a realistic daily driver. Tough combination to beat.
  11. I may have missed it, but somehow I was under the assumption you were going to use an aftermarket ECU? A vacuum line to the regulator is not mandatory. There are benefits but, most often, its not a *requirement*... depends on the specific 'build'. Not with a standalone (and factored in up front). Yup... if you don't plan in advance, but it sounds like you're the kind of guy to do just that. Not really. Resolution helps. I've run monster injectors on small engines. With the right EMS, its realistic. Because thats not the right answer Where are you right now? You're down to physical fuel delivery, correct? This is a small hurdle. Tell us more about your objectives and maybe the collective wisdom of HZ will save the day
  12. It would seem that way. However, the occasions I've used it, were in fact, sharply focused dents, less than .125" dia. In reality, I suppose it depends on the guy doing the work... just like anything else.
  13. Without seeing, its hard to say, but it sounds resonable. I've had great success with paintless dent removal.
  14. Great! For catalytic equipped cars. Check the switch at the E-brake handle.
  15. This 280zt has A/C... http://home.comcast.net/~jgkurz/z/album/index.html He's a member here... jgkurz. PM him if you have any questions.
  16. Yes... with key on, hazards off, the GY wire at the flasher should be 'hot'.
  17. Below is a schematic of '78 turn signals. Notice that power distribution is separate from the Hazards (two separate fuses and flashers). Turn signal power is routed through the hazard switch (so the hazards can interrupt turn signals). Then through the flasher. Then the combination switch, and out to the bulbs. I would start at the fuse, and follow the above path. There are no relays in this system. The only thing you should hear is the flasher.
  18. Its time to sell the BMW. Last night I took a couple of final pictures, for the ad. and sentiment... . . . .
  19. ...You mean like clowns in a circus??? OTM: Your prices just went up.
  20. Dear SuperDan, I respectfully ask you to revoke Braap's Admin status. He's impossible these day's... won't talk to me, and when he does, its COLD. Spouts off "Red vs. Blue" and "Your either with us or against us". I had a talk with his wife to see if she's noticed any change.... she say's he wakes up in the middle of the night, sweeting and shouting "BAN HIM". I'm really concerned. Sincerely, Ron
  21. Pile?.. I have no pile... my junk is spread OUT....
  22. A few adjustments to my new home...
