RTz
Administrators
    23
Everything posted by RTz
  1. Les, Haven't heard from you... you still need a timing map? ron@primeems.com
  2. Another way to say it... the centrifugal SC's boost goes up with the square of its speed. Hence, double the RPM is 4 times the boost. So, if you want max. boost to be 10 psi and max. operating RPM is 7000, then at 3500 you're only getting 2.5 psi. Furthermore, you still have all the parasitic drag at low RPM... without the boost to go with it. I'm with Pete... I don't fancy centrifugal SC's.
  3. Mike, Don't forget '74 1/2's had the larger tranny tunnel for sneaking the exhaust up a little higher after installing a T56, and the lower core support being lower for getting a little more radiator up there.
  4. Justin, The dimensions on my manifold page don't help?.... http://forums.hybridz.org/showthread.php?t=117607 I can provide you with .DXF's if it makes it any easier.
  5. '74 1/2 260.... All the 280 'features', with none of the EPA hassles
  6. Les, Your point of view doesn't seem to mirror my own. Here’s how I see it... On November 29th, you emailed me and asked if I had a timing map for an LT1. On the same day, I returned the email. I explained that, while I don’t have a map, here are the necessary numbers for you to plug in the appropriate places. I also included my phone number and told you to call me if you had any questions. If you did not receive my email, I apologize. These things happen. Let me know if this is the case and I will resend. If you did in fact receive it, you should have called me or email'd and said “Hey Ron, thanks for the help. I could use a little clarification though, etc, etc”. By not responding, I was left with the assumption that you were happy. Why would I think otherwise? If you still need help with the map, PM me and I will build one for you. All that is requireed is a little communication. Deal? I would venture to say, in Australia, V8’s are the minority. This doesn’t mean they don’t care.. V500 has *eight* injector channels and *eight* ignition channels. Not many of the midrange systems do. It normally requires about double the money to get into a system that can make the same claim. What you're witnessing is simply a reflection of the popular market. Not embarrassed. Apologetic, maybe, but not embarrassed. Don’t forget, Wolf is an Australian company. They have a very respectable reputation in their homeland. They only recently decided to make an effort to grow in the US. This takes time. You can’t just twinkle your nose and have dealers instantly appear all over a country the size of ours. This feature is partially marketing. The problem with this method is that YOU have to set the target value. If you stick with the common ‘12.5’, more often than not, you will leave power on the table. Some engines respond well to a flat 12.5... some don’t. Some like to run leaner down low and richer on top. Some are opposite. Either way, you still have to do proper testing/evaluation to find out what YOUR motor wants. The reason we spend the money and take the time to install these systems is to wring out more performance than OE, yes?. In 99 cases out of 100, you will not BEAT the factory numbers with simplistic tunning of ‘target values’. Since you already have an LM1, this is still very easy to accomplish with Wolf. Using the arrow keys... , the pulse-widths increase or decrease incrementally. This can be done with an ENTIRE load band, or just an individual cell. Holding down the shift key will make larger jumps. With this strategy, you can have a drivable initial map within minutes. I hope this helps you. If you have further concerns, don't hesitate to email me.
  7. A little more than asssuming. A heat gun pointed on the element raised temps to 160-ish. Pulling the heat gun away, the temps lingered, dropping about 1 degree per second. AS SOON as I touched the brass mount, the temperatures starting coming down semi-rapidly. Even though the testing was remedial, I feel pretty comfortable saying that the attachment surface can influence the readings. I agree. This is why I think every position is a compromise. Its comes down to which compromises you're willing to live with. Agreed. But ALL of that air is gone within 2 crank revolutions. Its gone before the engine even starts. I don’t see accurately reading this condition as one of the important compromises. Although, I will concede the manifold is probably substantially hotter in that scenario and thus, the new incoming air should be slightly hotter. Understood. I would be 'with you' if it weren't for the influence that I see coming from the mount point.
  8. Those coils are definitely Denso. Not certain what application, though. $20 say's the pin-outs are the same... A Engine Ground B Logic Ground C Signal D 12v
  9. Braap/Hanson, As you mentioned, dwell might be compromised. The way I see it... its common practice to taper off the dwell at higher RPM. Peak ignition demand is typically at peak torque... no need to ask the coils to be fully saturated when demend is lower. This just makes them run hotter (due to increased duty cyle) and shortens their life unnecessarily. I would be very surprised if Ford designed EDIS with a fixed dwell. That said, if you’re cam driving EDIS, it would think the engine is at half actual speed. This scenerio *might* put the programmed dwell in the wrong RPM range. Then again, it might not. Only testing will determine that. It would be interesting to map an EDIS system.... add it to your list Braap
  10. This manifold is heavily influenced by its throttle body. A scenario I wanted to avoid.... ...When a TB is attached to a 'flat plate' the incoming air has a tendency to separate directly after the TB, leading to turbulence (which can lead to uneven cylinder distribution). My decided approach was to use an oversized TB to attack this two fold. First by slowing the air down, and second by allowing the walls of the TB to closely match the inner walls of the plenum. Using a 65mm Ford TB (‘95 Crown Victoria) I was able to keep the taper after the TB within 10 degrees... . Another 'feature' I wanted to avoid is protruding velocity stack's. As demonstrated by "turbobluestreak" in this CFD.... ...there is a high pressure area that develops between the TB and cylinder one. Certainly this does not happen with all internal velocity-stacked manifold’s. My point is simply... without laborious testing and expensive test equipment, it can be risky.
  11. What info are you looking for?
  12. Anyone find it amazing, per this poll, that one out of every three Z's doesn't run?
  13. I'll knock $100 off retail to anyone donating $25 to HybridZ in the preceding 12 months.
  14. Tim is right... there is nothing to re-flash. If you're the creative type, you can stuff a Wolf V500 in the OE case.... Let me know if you need one of those
  15. At this time, I have two running/driving Z's (one 260, and one 280). Also have a couple 240's in 'the back 40' that are rather naked at this time.
  16. Thanks guys. I've ended up spending a surprising amount of time with the previous owner and his wife. They are very genuine people. I think, even better than the car, I will have made friends.
  17. I was never able to get the 1 1/8" bar to work for me (autoXing). Not saying it can't work... just say'n, after many combinations, I had many failures.
