Hi everyone.
SO.
I finally managed to get my transmission off my 87 Z31 Turbo.
I took off the clutch to reveal that it's a UNISIA unit, which I believe is standard OEM. It's practically brand new. Nothing wrong with it. Infact, I'm considering just cleaning it up and putting it back on depending on what I can withdrawl from the hybridz mainframe of brains (you guys!).
Anyway.
I noticed 10 days after getting my car on the road and driving for maybe... 100 miles that going into gear while rolling was getting harder and harder. 10 days before that it was FINE. no grinding at all, not synchros yelling at me. Even trying to pull the the transmission out of gear was starting to feel "unnatural". It always had a clunk to it.
When I'm at a dead stop, it goes in just fine. No forcing required whatsoever.
It started to act up so I bled the system via gravity. Still, same problem. SO I decided to push out the pedal adjustment rod. Now I have the throwout bearing hitting making funny sounds. But still, same problem.
SO today I bought the transmission attachment for my large jack, got under there, pulled it off with my friend, and I find that the clutch is fine, except that the pilot bushing has a gouge in it. on the outer face of the pilot bushing there seems to be a scrape/gouge mark that shows the brass/bronze being eatin away. The input shaft that slips into the bushing also has a gouge at the hilt of the piece that inserts into the pilot bushing.
The input shaft has about 0.5 mm of play in all directions. I'm not sure if that's even worth mentioning, but I will. It's not as if it seems to be really bad or anything... somewhat normal for a 21 year old transmission.
The transmission even spins by hand in all gears. I drained the tranny fluid and purged it with some ATF poured through the shifter hole with the drain hole opened. I drained the ATF into a can and then poured the ATF back into the ATF bottle using a paper towel as a filter. There were TINY particles, but nothing to be alarmed about. No chunks. nothing more than say... the thickness of a hair.
The magnet on the drain hole plug had a lot of shavings on it too, but again, I figure 21 years of slammin' gears isn't going to be anything less.
My dilemna is now trying to find out what the problem is.
A friend of mine said that as he had his hand on the shifter while the car was idling, he could feel a spinning motion through the shifter. I know I felt it before too at one point. I'm not sure whether to suspect that gouge in the pilot bushing to be anything of concern
perhaps some driveline shock?
I'm kinda depressed now. I was hoping it was going to be like YAY, A SPRING BROKE, TIME TO FIX CLUTCH... now i'm not so sure.
I got a taste of Z's for the first time, and only drove it for 10 days, and ... now nothing
