Miles
    37
Everything posted by Miles
  1. we are experiencing the old problem of the differential yoke hitting the emergency brake lever arm on hard acceleration. So we installed a solid front differential mount and now the diff yoke is firmly against the emergency brake lever arm . What is weird is with the original rubber front mount the yoke hit the emergency brake only on hard acceleration. With the solid mount the yoke is jammed right into the emergency brake lever.Has anyone come up with a way to move the emergency brake lever arm away from the yoke? I was thinking that by using a longer linkage to the cable connection I could move the emergency brake lever towards the front of the car. Thanks Miles
  2. Eric I did follow the artical, but that passenger side drum would not budge. I tried repeated heat, hammering and even dry ice to no avail. The driver's side drum was deeply grooved so I decided to just go ahead and do a 100% rebuild on the rear brakes including new drums. The stuck drum was also deeply scored as the previous owner evidently couldn't get the drum off either and let the shoes wear to the metal. When I am done all front and rear brake components will be new except for the hard pipes. Thanks Miles
  3. Got the drum off. Don't do this if you have good drums...I drilled all the way around the hub with a 3/8 drill bit being careful not to score the hub. The drum finally pulled away after I drilled the last hole. Lots of rust on the hub. Found that the shoes were soaked with brake fluid and the adjuster was jammed. Original plan was to rebuild the front brakes first. At this point I think I'll just go ahead and rebuild the rear brakes. Learned some things about Z brakes. The cylinders and the stock shoes are different on the left and right side. The after market shoes (Raybestos) I bought are the same for both right and left sides. The seem to fit ok. I tried to buy stock Nissan shoes but none could be found locally. Once I get the rears rebuilt I would like to try the Ferodo "Green Stuff" shoes and Metal Master front pads. Anyone out there using the Ferodo shoes? Miles
  4. Lone The engine was previously built. I read somewhere in the forum that there is an additive you put in the gas and in with the oil that is supposed to free up lifters and clean up deposits in the piston ring grooves. If someone knows of a good additive let me know. The Ford solinoid: just splice it into the wire going to the starter? Also, I like the idea of a cut out switch on the ignition wire to help cranking a hot engine with lots of advance. It would serve to frustrate the car theives too! Eventually, we are going install a new crate engine. Thanks Miles
  5. I'll try the heat approach today. Thanks Miles
  6. Just got the exhaust on the 350 sbc and now I am hearing a ticking noise from under the valve cover for the first time. Could this be a sticky lifter or something more serious? I cranked in a lot of advance on the 350 sbc which resulted in great throttle response. However, when the engine heats up it is hard to start. The starter labors to crank the engine. It will start if I hold the pedel to the floor, but it takes awhile. I retarded the timing and it starts ok when hot. How do dial in the advanced timing and not have the starting problem? Thanks Miles
  7. Step one is to get the Jags That Run (JTR) manual. There is a JTR link on the Hybrid home page.It will cover most of the questions you have about transmission options. In our conversion we used an 89 Camaro world Class T5 five speed trans. The shifter comes up through the stock shifter hole and it is very smooth. You can see the shifter details on our photo page below. We are also using the R200 differential. We have just over $5000.00 in the car so far and have done everthing except the exhaust ourselves. Still have brakes, suspension and paint to do. Having a shop do the conversion would have cost big bucks. Miles
  8. Denny I'll give it a try. Any safety issues? That passenger drum is close to the gas filler hose. Have you done this before? Miles
  9. I had the same problems as you are (lean sag/backfiring). To richen the mixture turn the mixture adjusting wheel at the bottom of the each carb clockwise looking from bottom up or counter clockwise looking top down. Start with screwing the mixture in all the way until it stops on each carb and then back it out in full turn increments. Make each carb has the same number of turns. Mine runs best at three turns out (in lean direction). It no longer back fires, but I still have a slight lean sag on partial throttle. I suspect a hose is leaking and I know that the throttle shafts are warn on my 240Z. Mine no longer back fires and starts easy. I am going to live with with a lean sag at partial throttle until I do the V8 swap this summer. Also, there are some good carb tuning tips I received from other members in the L6 section of the forum. Look for my posts on backfiring. Miles
  10. In the process installing new shoes on the 240Z. Driver's side drum came off easy. The passenger side drum is stuck as if it were welded to the hub. Any tips would be appreciated. Thanks Miles
  11. We did the R200 diff swap into a 72 240z awhile back. I was checking the rear brakes recently ans noticed that the 78 280Z mustache bar we installed has a slight warp towards the back of the car so there is a 1/4 to 3/8 gap between the bar and the vertical transverse arm mount on the drivers side. On the passenger side the bar is flush against the passenger side traverse arm mount. The car we got the mustache bar from did not appear to have any rear end damage. Is the slight warp of the mustache bar on the driver's side normal? Second question: Is there any way to remove the mustache bar with out pulling the differential? Thanks Miles
  12. I have been considering doing the Toyota brake swap using the MSA kit. Does MSA supply the small hard pipe that connects the caliper to the flex line? Also, has anyone else experienced the problem with the brake pedel going to the floor? Other people who have done the Toyota swap indicate they get about 0.5 in. of slack in pedel travel. Can that extra pedel travel be adjusted out some where in the master cylinder linkage? Thanks Miles
  13. Kendall You might want to check with MSA about the headers. The MSA "shorty" block huggers look like Hooker headers to me. The MSA headers provide a nice clean fit and there is plenty of clearance between the header and the steering shaft. Per the JTR (Jags That Run) manual you could also machine a pair of ram horn style chevy headers. MSA: http://www.zcarparts.com/ Miles
  14. Fairlady 327 Unfortunately, there is not enough room to mount a mechanical fuel pump. We are using an electric fuel pump wired to the elusive stock "green wire". I found that the green wire starts taped up at the gas tank and terminates in a taped bundle just behind and to the left of the 72 fuse box. I did not install the JTR oil pressure cut out switch for the fuel pump. I am going to use an inertial cut out switch that chops all power in the event of an accident. I would have prefered a mechanical fuel pump.
  15. Thanks for the feedback. we are going to try and finish the car so we can make it to the next MSA meet in May. It is my son's car so I'll have to beg him to let me drive it once in a while. That is OK as I have a very clean stock 72 240Z daily driver I am going to convert this summer. I plan on using a crate engine for my conversion. I would appreciate any advice you have on crate engine sources. I want a "ready to drop in" complete 72 300 hp sbc. My plan is to have the car ready and take a week off from work to do the engine swap. Miles
  16. Here is progress we have made since August last year. Still have suspension, exhaust, brakes and paint to do. Thanks for all of your help along the way. See pics at: http://www.netsnapshot.com/pickalbum?IanZ Miles
  17. I upgraded to a new photo site and will add more photos of conversion details soon: http://www.netsnapshot.com/pickalbum?IanZ Miles
  18. Miles
    short throw for t-5
    We are using a B&M short throw shifter on my son's Camaro T5 in his 240Z V8. Very nice @ approx $164.95 in Summit catalog. Miles
  19. I have updated the photos on my web site: http://www.geocities.com/ian240z/ian240zv8.html Note that the B&M shifter comes up in the stock position. I'll try to add the tranny mount photos next week. Miles
  20. I installed a 74 350 sbc and a 89 W.C. T5 five speed manual trans in my son's 72 240Z using the MSA motor and tranny mounts. The distributor is approx 1.5 inches fron the firewall and the engine is lowered, but not as low as the JTR position. The mounts were easy to install. One advantage to the MSA tranny mount is that it bolts up inside of the trans tunnel rather than flat against the floor as with the JTR mount. The tunnel mount allowed me almost infinate latitude in setting the angle of the tranny output shaft for proper driveline phasing. The tranny was moved up and down with an angle finder attached to the tailstock and when the correct angle was dailed in we bolted the tranny mount to the tunnel. The T5 shifter came up through the stock shifter hole and only required a slight amount of trimming of the drivers side of the tunnel next to the drivers leg. We have had no drive line vibrations with this set up. we are using a B&M shifter on the T5. For cooling we are using a 82 Camaro radiator ($50.00) with a Flex-Lite Black magic electric fan ($250.00) and with a 160 deg. thermostat. Engine runs cool right at 160 deg. Rearend is a 78 280Z R200. We had a local shop make the drive shaft for $65.00. I have a 72 240Z that will be converted using the mounting kit MSA kit.
  21. Here are some pics of my son's V8 conversion to date. Only have a picture of the motor mount at this time. Next time I am under the car I'll add a picture of the trans mount. Hope this works: http://www.geocities.com/ian240z/ian240zv8.html
  22. Here are the MSA part numbers for the engine and tranny mounts: These part numbers are for 70-78 Zs 10-1821 V8 engine & trans mount kit $197.00 includes: 1821ENG V8 engine mount 1821TRNS mount For a 79-83 Z use part number 10-1822 The V8 conversion Kit includes chevy motor mounts and a rubber trans mount that bolts to the MSA tranny bracket that bolts up in the tunnel. Also the kit includes all mounting bolts and instructions which are not readable. MSA was very helpfull in explaining how to install the mounts. Just email MSA or call them. Note that the tranny bracket and rubber tranny mount are intended by MSA to install a 700R auto trans, but the bracket and rubber mount bolted to the 89 W.C. Camaro T5 trans perfectly without any mods. I also used the MSA shorty block huggers part number 10-1830 @ $169.95 These headers provide good clearence between the header and the steering shaft. I'll try to post pictures of the motor mounts etc on the forum if someone can tell me how. I have photos of the engine mounts, but will have to dive under the car for some tranny mount photos.
  23. DAW Very helpful. Thanks for the info. Miles
  24. Which way do you turn that nut on the bottom of the SU carb to make the mixture richer? Looking from top down, is clockwise rich and counter clockwise lean? I dialed in max advance and it helped some and increased power some too. Thanks Miles
