Miles
    37
Everything posted by Miles
  1. Lone I priced the Toyota conversion here in Sacramento using parts purchased from a Nissan dealer, Southern Auto parts and Auto Zone. To buy rebuilt Toyota calipers and install stock rotors with new bearings and seals is only going to cost about $250.00. I am going to keep the MC stock, but I am concerned about two things: 1-will there be a problem suppling enough volume with the stock MC and 2-if I go to a larger bore on the MC will I then have problems modulating the brakes and/or will they grab at the bottom of pedal travel? Cost-wise rebuilding the front brakes with stock parts costs about the same as the Toyota conversion. Either way I just want to do this once right the first time.
  2. How well does the Toyota brake upgrade work. I have a new master and master vac in place place in a 72 240Z and ready to do the Toyota brake upgrade, but review of the forum on this subject indicates some folks are happy with the Toyota conversion and some have had problems. Given new stock rotors, new master and master vac can I expect a bunch of new problems with the conversion or will I see some improvement?
  3. I am considering Eibach progressive springs. Looking for a good price. MAS wants about $279.00 per set. Do you know of a better price or source?
  4. I just finished installing a SBC and 89 World Class T5 trans into my son's 72 240Z. We used the Motor sports Auto (MSA) conversion motor and transmission mounts. The tranny mount was designed for the 700R auto trans, but it worked just fine with the t5. Using the Camaro bell housing the shifter comes right up the stock hole in the tunnel with a little trimming on the drivers side. The advantage of the MSA tranny mount is that it fits up in the tranny tunnel and you can move it up and down within a range of several inches to fine tune the angle of the ouput shaft. I just put an angle finder on the end of the output shaft while my son jacked the tranny up until I got the angle I wanted. We then bolted the mount in place. The differential is off horizontal by 2.5 deg. We have road tested the car and the drive train is smooth as silk with no vibrations. MSA does not put the engine as low or as far back as the JTR mounts, but this is fine for a daily driver. It depends on how you are going to use the car. Overall I would rate the installation of the SBC and T5 using the MSA mounts fairly easy. The hardest part was converting from a R100 diff to the R200 diff. You can get lots of help doing your V8 conversion through the folks here in the HybridZ forum. Cheers
  5. Are replacement dimmer/TS switches available for the 240Z? The white plastic connector on the back of the switch disintegrated. Volt meter shows power to the red/white and red/yellow wires that attach to the back of the dimmer switch. Have no low or high beams. All other lights work. Also, where is the article on headlight harness replacement by BLKMGK? Thanks.
  6. Does anyone else supply a fuel safety switch besides Summit? What is the Summit cat. no. for the saftey switch. I may install one using a relay. How about an inertial fuel/power shut off switch?
  7. The car is on the ground and road tested. It shifts perfectly using Lee's hydraulic set up from a Ford F150 and a Camaro slave. problem was that I failed to mention that the drive shaft was not installed when I tested gear changes after the clutch was installed. Once the driveshaft was installed the grinding in reverse disappeared.
  8. Pete Re: Drive shaft angles. I measured the tranny level at the output shaft with an angle finder at exactly 90 deg with the car level. The differntial measured at the input flange with the car level was about 92.5 deg from level. I road tested the car, but did not take it over 20 mph. No vobrations at low speed. Hope it will be ok at hwy speeds as I have seen some of trouble some of you have had with this.
  9. After 8 weeks of work and help from hybrid Z we now have our 72 240Z on the ground and running. The major components include: 82 Camaro radiator with Flex-A-Lite 150 fan, 74 sbc 350 w/performance cam, MSA block hugger headers, MSA motor & trans mounts, Holly 4bbl carb, Ford F150 clutch master, Camaro clutch slave, 89 Camaro World Class T5 trans, and 78 280Z R200 differential, 91 Acura seats. Cost to date is about $4000.00 including the cost of the car and all of the above. We still have suspension and brake upgrades to do, but I think this puts us over the hump. Note the MSA mounts were very easy to install. The MSA trans mount allowed very easy leveling of the trans which is phased almost perfectly with the differential. They are within about 3 degrees. The hardest part was the R100/R200 changeout and the mustache bar. Road tested the car with open headers and it was second best feeling in life. Thanks for all of your help along the way
  10. Thanks for all of your input. I was going to rip the engine and trans out, but will wait until I get my driveshaft cut and installed for some road testing. If after more tweaking of the hydraulics/linkages does not solve the problem then I pull the clutch apart.
  11. I just installed a t5 with all new clutch components as part of a 72 240Z sbc v8 conversion. I am using a Camaro slave driven by a Ford M/C with a 1 in. bore. I am getting 1 in. of fork travel at the point where the slave connects to the t/o arm but the trans grinds going into reverse. Any help would be appreciated.
  12. Has anyone in the forum used a Ford fuel shut off inertia switch instead of the oil pressure switch set up given in the JTR manual? The inertia switch seems like a simpler approach to shutting off the electric fuel pump in the event of a crash. Do any of the Speed shops offer an inertia type fuel shut off switch?
  13. Just finished installing a 350 sbc and T5 Wc trans in a 72 240Z. What is the best/easiest throttle cable to adapt to the 350 and 240Z? Also, I can get a pair of 75 280Z seats for $75.00, but will they fit in the 240Z?
  14. Lone I have installed a r200 too and next week will be installing a T5 in place of a Saginaw 4 speed. It will be several weeks before I can road test the car. From what I have read here in the forum, it's almost a given that I'll have to do the mustache bushing mod. I am also considering going to a hard front diff mount.
  15. Just want to check my understanding of driveline phasing. Basically, the angle of the transmission center line and the differential input shaft centerline must be parallel. So, if the angles of the trans and diff sum to 180 deg then they are parallel. For example, from the book Practical Engine Swapping, if the diff is 80 deg nose up and the trans is 100 deg down then everything sums to 180 deg and is properly aligned in the verical axis. Right? So much for vertical alignment. Has anybody had a problem in the horizontal axis of driveshaft alignment?
  16. Davy Thanks for the email. I spent about 2 hours going through old HybridZ posts on this subject. Didn't find anything on tweaking the rear mount of the T5 when the Camaro bell housing is used. I am assuming that using the Camaro bell housing will place the rear mount in a level position and the shift er pointing towards the driver. Question: does the shifter angle make for awkward shifting? As for the hydraulic MC and slave units I plan on using a Tilton 13/16" MC and the Camaro slave. Several old posts indicate this combo works well. I have a Corvett bell housing as well so if the Camaro BH doesn't work I'll go with Corvett as a back up.
  17. I have a 89 Camaro T5 WC tranny and bell housing. The bell housing tilts the tranny towards the drivers side. Will installing the T5 with the Camaro bell housing work in a 72 240Z? Has anyone done the T5 and Camaro install in a 240Z? Any special tranny mount considerations? Also, I am thinking about using the Camaro slave cylinder if I use the Camaro bell housing.
  18. Miles
    R200 Swap
    Thanks to your help at HybridZ I just completed swaping a R200 into a 72 Z. During installation we notice that the nose of the differential is skewed to the left/drivers side a few degrees. The R200 bolted in ok after wrestling with the mustache bar and tightening all of the mounting bolts. Has anyone seen this before and could it be a problem?
  19. I am having a problem installing a 78 r200 mustache bar in my 72 240Z. The bar is supposed to go behind the vertical transverse mounts with the mounting bushings facing forward. Problem is when I try to slip the bar inbetween the gas tank and the two vertical transverse mounts there is not enough space to move it into position so it will slide up onto the mustache bar mounting studs. it seems like I need to remove the rear transverse mount in order make room to slide the bar behind the vertical mounts and then onto the studs. what is the SOP for installing the mustache bar?
  20. I am having a problem installing a 78 r200 mustache bar in my 72 240Z. The bar is supposed to go behind the vertical transverse mounts with the mounting bushings facing forward. Problem is when I try to slip the bar inbetween the gas tank and the two vertical transverse mounts there is not enough space to move it into position so it will slide up onto the mustache bar mounting studs. it seems like I need to remove the rear transverse mount in order make room to slide the bar behind the vertical mounts and then onto the studs. what is the SOP for installing the mustache bar?
  21. Sanity check before we lug the R200 up the mustache bar. We installed a 78 R200 mustache bar with the mounting rings facing the front of our 72 240z. Is this the correct orientation of the mustache bar or should the rings of the 78 bar face the rear in a 72z? Please yes as it was a b--ch getting the bar installed.
  22. Why stock mounts? They were free. We are re-doing an old Scarab 350/240z conversion and plan on updating all of the bushings as we go through the car. What is the best source for the bushing kits? BTW is there any easy way to get at the driveline flange bolts?
  23. Re: replacing bushings in the mustache bar: Today I bought a set of bushings from the Nissan dealer and had a shop press them into my 78 R200 mustache bar. By the way, my 78 R200 mustache bar has a slight upward twist to it. is that normal?
  24. Will a T5 WC bolt up to a 81/82 camero bell housing which currently has a 4 spd Saginaw bolted to it? iam told that I need a 83 or later bell housing.
  25. I have a 240z 350 and plan on replacing the R-180 with a R-200 (the 350 chewed up the R-180). It apears that the axle flanges are not compatable. Do I have to change the axles or is there some other alternative? Is there a way to determine what the gear ratios are for a given R-200 rearend?
