37
Everything posted by Miles
I get steering wheel shimmy when braking to a stop in my 72 240Z. Is it caused by warped rotors or worn suspenion parts? Thanks Miles
Would 180 lb/in. front and 200lb/in. rear spring rates be too stiff for a street 72 240Z V8? Arizona Z sells these springs for $89 per pair. I'd like to hear from anyone running close to 180 front and 200 rear spring rates in a V8 Z. Hows the ride? This is very subjective, but on a bone jarring scale of 1-10 (1-soft to 10-skate board) what is your ride like? Thanks Miles
Bleeding new brake master cylinder
Miles replied to QWKDTSN's topic in Brakes, Wheels, Suspension and Chassis
Pete Would it be possible to get those last remaining bubbles of air out of the MC using a vacume type bleeder? -
Anyone out there experienced with replacing a window regulator in a 72 240Z? My manuals do not explain the steps clearly. Any advice would be appreciated. Thanks Miles
How to install new shocks 72 240Z
Miles replied to Miles's topic in Brakes, Wheels, Suspension and Chassis
Once the strut is out of the car and the spring is removed using a spring compresser, how do you get the old strut cartrage out of the strut? The nut has three holes on top. Do I need to buy a special tool to unscrew the nut? Thanks Miles -
We have two 72 240Zs. One is stock and the other has a 350 sbc. Both cars have stiff steering. Is stiff steering typical for the 240Z? Thanks Miles
Replacing Shocks and Source for Springs
I was just looking at the Arizona Z Car website. they sell a set of 240Z springs 180 LB/in. front and 200 LB/in. rear for abot $160.00. Has anybody tried Arizona Z Car for parts or bought their spring kits? Thanks Miles -
Mike What spring rates are you using front and back? Thanks Miles -
How do you remove the old shocks in a 72 240Z? Do they screw out with a pipe wrench? Do the struts have to be completely removed from the car? Also, what is a good source for springs? We are looking for 150 lb spring rate front and 175 lb spring rate rear and not more than a one inch drop. The car has a 350 sbc. Thanks Miles
Do I have to pull the trans to replace the rear seal? Thanks Miles
We used a W.c. Camaro T5 five speed trans for our V8 conversion. There seems to be a lot of trans fluid coming out of the tail stock of the trans when the car is parked on a slope. Do I need to replace a seal or did I just put too much fluid in the trans? Thanks Miles
We used a 82 Camaro radiator with a Black Magic electric fan for our V8 Install. The radiator is the one shown in the JTR book. Now that summer is here we are finding that most of the water in the radiator is venting out of the radiator cap which is rated at 15 psi. Can I safely go to a 20 psi cap with the Camaro radiator and not risk blowing a seem? Thanks Miles
Soft Brake Pedal on new brakes
Brakes are working. Put some city miles on them and they stiffened up. Bled them one more time and got a few bubbles out of the right front and right rear. Now that the brakes are done we were finally able to open it up and experience the full potential of a V8 Z. What a ride! Thanks again for your help. Miles -
I bled the brakes on our72 V8 240Z using the above procedures, but the pedal is still spongy. Adjusting the rear brakes manually helped bring the pedal up, but I am having trouble getting the right and left sides adjusted evenly such that one wheel will lock up. I am going to back the adjusters out and readjust the shoes again. Hard stops from 25-30 mph will not lock up the fronts only the rears. I assume this is partly due to the new pads or the proportioning valve. My Haynes manual says that if you can't lock the front brakes at 30 mph the proportioning valve should be replaced. I note on my other stock 72 240z daily driver that I can not lock the fronts either. Is this normal for 240Zs? I am considering replacing the proportioning valve in the V8 Z with an adjustable unit from MSA or Summit, but don't have a clue how to connect it to the stock hard pipes. If someone has installed an adjustable proportioning valve in a 240Z I could use your input. Thanks for all of your input. I'll just keep grinding away at this til I get it right. Hope to have the brakes resolved soon so we can make it to the next northern California (Rio Vista?) Hybrid meet in July. Miles -
Just finished complete 100% rebuild of front and rear brakes on a 72 240Z including a new master cylinder using all stock parts. Noted that brake pedal was soft with original old brake parts. The pedal is still soft with all new parts. I know the pads and shoes will have a springy feel for a few hundred miles. I bench bled the MC. I have checked all connections for leaks and found none. The pedal is still soft and pumping does not stiffen the pedal up. Perhaps I did not bench bleed the MC correctly. What is the procedure to bench bleed the MC? Thanks Miles
Lone How does the Ford starter solinoid help? Do you install it in series with the B+ cable to the starter? We have a lot of advance dialed in a sbc 350 and when the engine is hot it takes a bit more cranking to start. I was thinking of going to a gear reduction starter some day. Thanks Miles
AZGUY I used the MSA kit to install a 350 sbc and 89 Camaro T5 trans in a 72 240Z. Very easy to install. There have been a number of posts in the forum recently on the MSA and JTR mounts. Click on my photo site below to see installation pics. Miles
Ross I was about to purchase metal master pads for the 240z, but the KVR pads sound better. Do you have to heat up the KVR pads before they become effective? I am using stock pads now and they suck. Miles
Allignment Problem? Pulls to the Right
Lone I'll try the Elk Grove Chevy dealer when I have the bucks. Did the dealer deliver the engine? Thanks Miles -
I was having the same problem with my son's 72 240Z V8. So I replaced the master cylinder, rear wheel cylinders, rear shoes etc with new original Nissan parts. I have bled the brakes, including a power beed, five or six times and finally got all of the air out this morning. Proper shoe adjustment helped stiffen up the pedal. If you replace the MC be sure to bench bleed it. Check for leaks at all of the hard line unions including the connections to the MC. I sprayed brake cleaner on all of the unions I could reach and wiped them clean. Pumped the brakes a few times and sure enough there were some unions leaking brake fluid. Hit the leaking unions with a 10mm tubing wrench and all is well. Miles
Mike On Ford and Chevy brakes I used to adjust the shoes until the wheel would not spin and then back off the adjusters a few clicks until the wheel would just turn with some slight resistance. I'll try that approach. Thanks Miles
Just rebuilt my 72 240z rear brakes with original Nissan parts: cylinders, shoes, springs retainers etc. I also replced the old master cylinder with a new Nissan master cylinder which I bench bled before installing in the car. I am going to rebuild the front brakes next week with all new parts. The existing pads are almost new. I had the system power flushed and bled after I did the rear brakes with silicone DOT 5 brake fluid. The rear brakes now have about 150 miles on them, but they are still spongy. Pumping the new master cylinder does not firm up the pedal and bleeding reveals no air bubbles. A hard emergency stop will lock the rear wheels and requires almost full pedal travel. It feels like there is still air in the system. Any help would be appreciated. Thanks Miles
Highrpm Thanks. I'll add this to my do list. Miles
Eibach Progressive Springs for V8 Z
Mike How does your car ride with the 225 front and 250 rear set up? On a scale of 1 (soft) to 10 (skate board) how would rate the ride for city driving and occasional hammering the pedal out of the hole? Thanks for all the info Miles -
Mike For street use would 200lb/in front and 225lb/in rear be about right for a V8 Z? Do you have a source for springs and shocks? Thanks for the warning Miles
