37
Everything posted by Miles
Nice! Back in 2009 I couldn't find a rebuilt 280z booster so I was going to buy a booster repair kit, but later figured that I might need special tools. I was able to find a rebuild shop in my city to rebuild my 280z brake booster. The shop specialized in rebuilding truck brake components.
- 1 reply
- 1
Replacement Door Mirrors for a 1972 240z Nissan The old MSA door mirrors fell apart and I wanted to find a better replacement. After doing some research I found that GM part #987460 refers to the classic chrome outside rearview door mirror used on 1955, 1956, and 1957 Chevrolet passenger cars would be a good fit. I found a kit that provides both left and right mirrors at United Pacific: Item No.110745 Exterior Mirror Bundle for 1955-1957 Chevy Passenger Car (Pair) which includes: · Polished stainless steel mirror head & chrome plated arm with identical design as original. · Convex mirror with wide angle optics for R/H side. https://classic.upauto.com/exterior-mirror-bundle-for-1955-1957-chevy-passenger-car-pair-110745 I purchased the mirror kit at Amazon for $57.69 https://www.amazon.com/United-Pacific-110745-Exterior-Passenger/dp/B07CSM82R6/ref=sr_1_5?crid=3D4VKZQDPPL45&dib=eyJ2IjoiMSJ9.Ji_ewCdOZDHJk5NTl-hJJNFlKNsQBt5lpAOLKHcRoK31x-GRce_gxezK_VKJFo0J9IkZHkDcZBC1uO-yqa9wAikFa3d3ppFs1Z_e9oMH7GHS0hSYXVCL3mPH2KdHlNipyinC19rlSI2bJ2OSt4dOu31VkbQgttxV3F9sjOnvlwdEzUBrH0x35XHZypqXaZKhHaGVoA8HQfe6yph6tpYjD9i1U7980UgA3v1My4M_ZeA.60nOt1lFZGTfNCnWtHJyTgcmFLSL1-4Gz3NCXbznMr0&dib_tag=se&keywords=car+side+mirrors+chrome+metal&qid=1783662323&sprefix=car+side+mirrors+chrome+metal%2Caps%2C189&sr=8-5&ufe=app_do%3Aamzn1.fos.9fe8cbfa-bf43-43d1-a707-3f4e65a4b666 See pictures.
Note that this applies to my 1972 V8 240z which uses a Motor Sports Auto (MSA) / Jags That Run (JTR) style hood release bracket. The stock hood release cable tends to fail with age. If the cable breaks you will be very sad. So I decided to replace my failing hood release cable with a Lokar Hood Release Cable kit. I installed the hood release handle where the driver’s side vent control was mounted. The vent control mounting bracket is rigid and lines up the hood release cable with the stock hole in the firewall. The vent control was moved to the left of the Lokar hood release lever and bolted to the underside of the dash. Installation required making two brackets from 2” x 2” x 1/8” aluminum angle one for each end of the cable. The release arm on the stock hood latch release mechanism required modification because the Lokar cable stop would not fit into the stock cable connection. I removed the stock cable connector on the release arm and replaced it with a spare Lokar throttle cable end and ball pivot. This allows the attachment point on the lever arm to swivel as the release arm moves to release the hood latch. Summit p/n: Lokar Hood Release Cable Kits HR-1100U $129.95 https://www.summitracing.com/parts/lok-hr1100u Summit p/n: Lokar Cable Fittings WCA-1034 $33.95 https://www.summitracing.com/parts/lok-wca-1034
- 1 reply
- 1
Nice placement in your engine bay. It looks like you just ran a positive off the battery terminal (?) to your box and all the accessories are using the chassis for the negative side. It is B+ only. No ground. It connects to the + terminal of the battery. Accessaries draw fused power from the fuse box. Each accessary is grounded to the chassis.
Picked this up from local hot rod shop for my 240z SBC 350 project about 13 years ago. Circuits: Electric fan relay Fuel pump Radio and amplifier Power windows Summit Racing/parts store etc probably have this fuse box.
Just use a 1979 280xz MC as it bolts on and it has the correct metric threads in the output ports. The downside of going to a larger bore MC is that the pedal will be stiffer and requires more foot pressure to stop. This can be corrected on the 240z that uses a 7in. dia. booster by going to a larger 81/2 in. dia. 280z booster. If you do this booster swap you will need to swap the 240z booster push rod into the 280z booster so the booster push rod connects to the brake pedal like stock. My brake set up: Brakes are excellent. · Front:1979 Toyota 4x4 pickup S12+8 calipers with 240z stock solid rotors. · Rear: 1989 240SX calipers with 1984 non-turbo 300ZX solid rotors. Modern Motor Sports adapter bracket (NLA) · Master Cylinder: 1979 280ZX 15/16. sourced from Arizona Z Cars · Booster: 1977 280Z. Barely fits between throttle bracket and clutch MC (Wilwood Compact). Brake feel is excellent. · Brake Pads: Carbotech AX6. Excellent cold bite and does not fade when hot. Perfect daily driver pad.
Ads popping up continuously make it impossible to read Hybridz on my Android phone. They pop up with every selection while trying to navigate to a post. They pop up after selecting a post to read. It has become like an advertising link farm. Do I have to install an ad blocker to read posts on my android?
1978 Datsun 280z No Acceleration Above 4000 RPMs
Miles replied to Kad77's topic in S30 Series - 240z, 260z, 280z
Go to ZTherapy and buy this video: “JUST SU’S” British HS6 and Hitachi “SU” https://ztherapy.com/just-sus/ Watch the video until you name every part and understand how the SU works. You are experiencing a lean condition. Note that the throttle shaft on the SU tends to wear out allowing air to leak into the carb causing a lean condition. This air leak makes proper mixture adjustment impossible. Contact Ztherapy for the fix. -
Chevy 350 Auto to Manual transmission swap
Miles replied to Mefromstatefrom's topic in Gen III & IV Chevy V8Z Tech Board
Going auto 700r4 might be easier. The JTR book explains it. Done by many members here so there is lots of data. -
Buy this book first There are a lot of details about the 240Z V8 auto to manual conversion you need to know before you start the project. Purchase and read the JTR V8 conversion manual. You can buy it here: https://jagsthatrun.com/collections/jtr-v8-conversion-manuals/products/copy-of-v-8-conversion-manual-for-volvo-200-series -
1989 Camaro T5 mated to SBC 350 Basics 1. T5 transmission: The 1989 WC T5 transmission is tilted 15 degrees towards the driver. The 15 deg tilt is absolutely no problem, I have done two just cut away the trans tunnel as in the picture below. The tilt is not noticeable once center console is installed. Unless you want to make a special transmission mount, you will need an 89 Camaro T5 bell housing, driveshaft, flywheel, clutch pressure plate/disk, throw out arm, throw out bearing, clutch slave and a 7/8" clutch MC. Note that there is a V8 and a V6 version of the T5 transmission. They have different spline counts. You will need the V8 version. 2. Bell Housing: 1989 -90 bell housing for V8. Verify that the pivot ball is in place as that part is NLA. 3. Flywheel: 158 tooth flywheel: https://www.summitracing.com/parts/zzz-50-6516 4. Clutch Kit: Zoom High Performance Clutch Kits HP1675-1A https://www.summitracing.com/parts/zzz-hp1675-1a/applications/ 5. Clutch Hydraulic Components: Camaro Clutch Slave: Napa sells the Camaro clutch slave. https://www.napaonline.com/p/NCF73110 Clutch Master Cylinder: Both Tilton and Wilwood make 7/8in. clutch master cylinders. The Wilwood unit is more compact allowing use of a larger brake booster. Tilton 74-875U: https://www.summitracing.com/parts/til-74-875u Wilwood 260-10374: https://www.summitracing.com/parts/wil-260-10374 6. Clutch Hose and Fittings: Hose: -3 A/N SS hose. Length TBD Roll pin to A/N SS line adaptor Russell 640281 (connects -3 A/N SS line to the Camaro slave): https://www.summitracing.com/parts/rus-640281 MC A/N SS -3 A/N line to 1/8in NPT adaptor Earls 961603ERL (connects -3 line to the MC): https://www.summitracing.com/parts/ear-961603erl 6. Starter: Hitachi gear reduction starter or similar unit. 7. Complete 240z brake and clutch peddle assembly swap. 8 MSA/JTR transmission mount See my post of 12 June 18 second post down lots of pictures -
My kit from Modern Motor Sports (out of business) used rear 240sx calipers and rear 1984 non-turbo 300zx rotors. I should have said rear. Have fun.
- 7 replies
- 240z
- disc brake conversion
(and 3 more)
Tagged with:
I solved rear end clunking in my 72 240z by replacing al of the rubber bushings with polyurethane bushings including the mustache bar mounts and solid mounting (MSA mount) the nose of the differential. Of course the differential is still a little playful, but every Z I have owned had a "loose" differential that would clunk when engaging the clutch. I learned to engage the clutch smoothly. No problems in 20 years. SBC 350 v8 Camaro WC T5 trans 78 280z r200 differential Chequered Flag stainless steel stub axles. Replaced the stock stub axles because the wheel mounting flanges were warped causing my rear 240sx caliper brake pads to rub on the rotors. Over heating rotors drove me nuts until I put a dial indicator gauge on the flanges and rotated the axle. Evidently the flanges are soft and can become bent/warped just hitting a curb or a pothole. Not a problem for drum brakes, but with disk brakes the rubbing can cause rotors to heat up.
Driver's window glass falling off track
Miles replied to fusion's topic in S30 Series - 240z, 260z, 280z
" I do not have the window frame installed yet. " Install the window frame and adjust as needed. All frame bolts must be tight as they pull the frame into the correct geometry. Here is a book that I used to to do two 240z restomods. Gives details on how to disassemble, restore and reassemble a 240Z. Lots of pictures with step by step instructions. How to Restore Your Datsun Z-Car by Wick Humble available on Amazon -
Installing hatch glass- not working
I never had success with Vintage Rubber hatch or windshield seals on two 240z projects. I ended up using stock OEM seals. I recall getting the OEM seals from Courtesy Nissan and Motor Sport Auto (MSA). The problems I had with Vintage Rubber were deformed corners making it impossible to install. I used the rope trick and installed the stainless steel center trim in the windshield and hatch seal before installing the seals using the rope trick. Also, Vintage Rubber door seals were too thick making it impossible to close the doors. I went to Pep Boys and bought generic door seals that squeeze onto the door opening pinch welds. The problems with Vintage Rubber seals has been known for over 20 years. Lots of info here on HybridZ. There is a company that makes the windshield and hatch seals without the center stainless trim. -
Another option would be to use the 1979 Toyota 4x4 pickup front calipers for solid rotors which are plentiful and cheap. Using Carbotech AX6 pads with the Toyota calipers works well with my set up: 15/16 MC 9 inch dia 280z booster. Swapped the 240z brake pedal push rod into the 280z booster for stock connection to brake pedal. Front: Toyota calipers for solid rotors. Used SS braided line to connect hard line to caliper to eliminate the Toyota "S" tube. Rear: 89 240sx rear calipers with 1984 non-turbo 300zx rotors Carbotech AX6 pads front and rear
Might check with Carl Beck at Classic Z cars. Scroll down to Carl's post. https://www.classiczcars.com/forums/topic/44384-sumitomo-mk63-caliper-question/
If you know the thread pitch of the bleed screws, could using "speed bleeders" be an optional replacement? http://www.speedbleeder.com/main.htm https://www.summitracing.com/parts/ear-280040erl The Sumitomo MK63 looks like a slimmer version of the Toyota 4x4 pickup calipers. Is the Sumitomo MK63 a direct bolt-on replacement for the stock Datsun calipers?
Try contacting the guy who wrote this: https://www.jdmjunkies.ch/wordpress/2021-01-17/240z-the-guide-to-sumitomo-mk63-brakes/ Looks current and there are commenters at the end.
My kit from Modern Motor Sports (out of business) used 240sx calipers and 1984 non-turbo 300zx rotors.
- 7 replies
- 240z
(and 3 more)
Tagged with:
SU carb question....SM needles, 5.5 turns down.....wow
Miles replied to A to Z's topic in Fuel Delivery
If the SU carb has an air leak, it will create a lean condition for which no amount of tuning will correct. The problem with the SU carburetors is that the throttle shaft becomes worn and allows air to seep past the shaft and into the carb causing a lean condition. You can try contacting ZTherapy who specializes in SU carbs and parts. Also they sell a video called "Just SUs" it explains how to repair and tune the SU carb. Just SUs video covers: 4 hrs of advanced college level theory of operation, diagnostics, tuning, surgical Weber removing and disposal. Covers all years of Japanese Hitachi "SU" and 1.6L-2.0 Volvo HS6 1 3/4" SU (HS4, HS2 same). Our newest video, 4 years in the making. Directly replaces the first 1.5 hrs of ZTV01. Heavily updates and corrects info from ZTV01. Part one is inspecting and installing new ZT carbs and "Tuning for Dummies". Part two is "Installing and Tuning a ZT Master Tuneup Kit for Dummies". Balance of tape is answering common questions, racer tech and mods, airflow studies, horns, cold air box, etc. We address the Q+A sessions from the 2000 MSA and LSV shows-I worked hard to answer your questions on this video. If this does not answer every issue you ever had about the mighty SU, call me! If you still don't get a satisfactory answer, demand your money back!!! Ships free with new ZT carbs and the ZT MasterTuneUp kits. Available in single play mode on two 2 hr SP tapes for $20 or on one single EP mode tape for $15 (lower video quality). DVD available for $25 https://www.ztherapy.com/ -
The best performing pads that I have tried on my SBC 350 240z. I have tried all of the Porterfield, Hawk etc pads and they suck in comparison. My brake setup: Carbotech Ax6 pads work really well with this setup. Front: 1979 Toyota 4x4 pickup calipers for solid rotors. Direct bolt on. Rear: 1989 240sx rear calipers 1979 280zx 15/16 in. master cylinder 1978 280z 9 inch booster. Notes about Ax6 pads: Excellent cold bite which is great for a daily driver. Dusty at first, but I don't care. Stopping performance is what is important. No sign of fading!!! No noise Buy direct from Carbotech. Carbotech staff is helpful and courteous.
