Everything posted by wickiewicked240z
				1971 240z restoration PICS
wickiewicked240z replied to wickiewicked240z's topic in Body Kits & Paint
As far as aftermarket parts no upgrades. haven't mess with the car much it's running pretty good. Got it tune 265hp @14 psi 322torque. Most of my time is going to my other build 1971 datsun 521 truck I'm swapping a 3sge beams engine. -
	Which turbo where you running? I think they are standard gap for a l28et. Head is a stock p90a head other than solid lifters. Shawn from Church Automotive who is a well know tuner in southern California said I could go higher but he wouldnt recommend it on 91pump gas. He also said engine was running pretty good.
	1971 240z with L28et, ms2,edis-6 coil on plug, intake manifold similar to the senza pari group buy one,stock t3 turbo,pallnet fuel rail. What guys think.... Pump gas 91 octane.
So decided to go with edis-6 since my 12-1 diyautotune stock 82 turbo dizzy was having sync problems. Now so far is much better. Also went with coil on plug. -
				Is this the correct way to wire for edis&vr sensor
wickiewicked240z replied to wickiewicked240z's topic in MegaSquirt
Thanks Matt for the help. I all ready purchase most of the stuff to make the conversion to edis. -
So my ms2 is already wire for vr sensor. I would need to remove q16 and wire js10 to ign and make sure no other wire is at ign. Correct? -
Yes I bought it from diyauto tune but had it wired for direct ignition coil. But know I'm going to run edis with crank trigger wheel. -
	is this the correct way to activate EDIs on a MS2 3.0 board The red is what needs to be done correct? On the wiring guide it says to jumper tach select to XG1(but theres all ready jumpered tachselect to vrin) do i add another wire from tach select to xg1 Jumper opto out to tsel But to wire the vr sensor it says to tachselect to vrin(which it is already) wire TSEL to VROUTINV on the other section of the guide it says to wire it to opto out
	$2.95 in sunny southern California
				L28ET Won't Start
wickiewicked240z replied to Lead Foot's topic in Trouble Shooting / General Engine
				L28ET Won't Start
The wires connected to the l28et coil are a blue wire for rpm gauge I believe and black plug with a black n yellow wire. That plug goes on your ignitor thats bolted on your coil bracket. -
				6 ohm 25w resistors where to buy.
wickiewicked240z replied to wickiewicked240z's topic in Non Tech Board
I'm going to give the Honda resistor box a try. Heading to the junk yard tomorrow to get 2. -
Someone said to use 10w 6.8ohm resistors. Jimwolf technology sells them -
	I'm building my megasquirt harness I'll be using stock l28et injectors. (82 l28et engine) Where did you guys buy the 6 ohm 25w resistors I can't seam to find them online.
	No its something I put together. I should get it polished.
				AZC vs Datsun parts LLC big brake kit
wickiewicked240z replied to ECUAdam's topic in Brakes, Wheels, Suspension and Chassis
I know the actual person who makes the kit and controll arms for Datsun llc...his name is Juan krecs engineering great guy. -
	Manny are you jorge's friend?who lives few blocks from me. I think he was talking to you on the phone when he was helping me out with myl28et swap.
				grounding locations for ecu.
wickiewicked240z replied to wickiewicked240z's topic in Trouble Shooting / General Engine
I got her to start not on all cylinders though.
