Part of my plan for this weekend was to install my new Kick/Speaker Panels recently introduced by Derek here on hybridz. I had these in mind for my silver '73 240Z, which already has speaker panels in the kick panels, though I've never really been happy with them.
Info on Derek's panels can be found here: http://forums.hybridz.org/index.php/topic/94564-vacuum-formed-kick-panel-speaker-pods/
New kick panels as they were received.
The items sitting on the bag in the top center are for relocating the hood release mechanism. It needs to be offset higher to clear the speaker enclosure. I have hood pins on my car, so this bracket won't be needed with my install.
Out with the old...
5 1/4 kicker components installed in universal q-logic panels. As I said above, I was never really happy with these q-logic panels and gladly replaced them with Derek's.
One small snag... I was having a difficult time getting the driver's side panel to fit due to the dead pedal. I wanted to install them without cutting, but couldn't find a good way to do this. I started to trim the bottom corner for dead pedal clearance, but instead decided to take an inch off the top. The top part is not going to be visible with the panel installed anyway and provided just the clearance I needed to get the panel up and over the dead pedal.
Here's what I trimmed:
Driver's side test fit after removing 1" from the top:
Kicker components installed in their new home. I decided to mount the crossover unit on the top part of the panel.
Everything together and installed on the driver's side.
Good legroom and still have use of the dead pedal:
Next is the passenger side, which was a little more challenging but still easy overall. Again, out with the old...
This set of relays caused a bit of a headache. They're attached to a bracket that has 3 bolts holding it in place, which Derek accounted for in his panel design. The top one was a little difficult to get to in my car.
I got the top bolt loose, but decided to leave it in place and again decided to trim a portion off the top. For the passenger side, I trimmed just below the slotted hole that Derek had provided for the top relay bracket bolt.
Test fit of the passenger side after trimming the top:
It fits well and the cut portion is not visible, though the dirtiness of the inside of my car is. I also appear to really like blue wiring and can't recall exactly what I was thinking when I did that 7+ years ago (or so).
Components installed and panel sitting in it's home.
Right now, this panel is only being held in by the two lower bolts that hold the relays up top. I'm planning to put a few more fasteners in at the bottom corners on both panels, but ran out of time for the day. I also need to find a new location for the passenger side crossover.
I'm extremely pleased with these new panels. Installation overall was simple and they provide a much-needed option for installing speakers in the front of early Z cars. Great job on these panels, Derek! I'll be contacting you later for 1 or 2 more sets
