canfield 195 heads
*2.055 intake/1.60 exhaust valves
*65 cc combustion chambers
*200cc intake runners
comp cams 12-770-8 extreme energy mechanical roller:
*RPM Range: 2,200-6,200
*Int. Dur. @ .050 inch Lift: 236
*Exh. Dur. @ .050 inch Lift: 242
*Adv. Int. Dur.: 274
*Adv. Exh. Dur.: 280
*Valve Lift with Factory Rocker Arm Ratio: 0.564 int./0.570 exh. lift
*LSA: 110 degrees
comp cams roller lifters, high-tech pushrods, springs, retainers
arp 12-point poly locks
canfield guideplates
silvolite keith black hyp. pistons
*0.30 over, 3.48 stroke, 4.155 bore
crane gold 1.5 roller rockers
arp bolts throughout (engine kit plus head bolts, main studs, flexplate bolts, converter bolts, oil pump stud, etc.)
summit stage 2 5.7 rods
chevy cast 350 crank (welded up and turned back down for the 400 block)
weiand team g intake manifold (rated for 2800-7200 rpm)
holley 3310 vaccuum secondary 750 cfm (silver finish with black metering block kit)
cloyes hex-adjust true roller timing chain
melling m55a high volume oil pump
milodon oil pan (with windage tray, oil baffles)
milodon timing cover
march performance serpentine kit
For exhaust:
s&s headers, modified to be tri-y's by tim240z
magnaflow mufflers
