Allright, you graph cleary shows that your clutch was not slipping. A dyno dynamics unit is sensitive enough to show 1 missed ignition event on 1 cylinder at any rpm. It will show a slipping clutch and there will be no doubt.
Do you know what they used for ramp rate? If you can find out, do so. It should be somewhere between "150" and "175" for that car. Any lower than that and they are too low. ("150" = 15.0 km/h per second acceleration)
Now, the big questions. Was the mounted in ground or above? Where the knurled rollers in front of, or behind the drive wheels? If they got lazy, or do a lot of FWD cars, they may have had your car on the dyno backwards. That's fine for lower power cars, but usually ~250rwhp is where you'd change over. Maybe they were lazy about it. That combined with the burnt straps (tell them to order new straps dammit, they are just asking for trouble) could have caused your wheel slippage.
If the dyno/car is facing such a was that the knurled roller is in front of the drive wheels and not behind, you should be able to turn out 400+rwhp WITHOUT STRAPS on that dyno. Loading up the rear of the car is not necessary in any case if you have straps.
Anyway, see if you can find those things out. My guess is they got lazy and put your car on backwards, with the knurled roller behind the drive wheel. (causing your car to unload the knurled roller under power, ever so slightly) That combined with the strap problem likely let your wheels spin a bit...
