Two foot surgeries later, I can work on the car in spurts before having to take a break. Here's what I've done over the last few weeks.
Finished making the TR6060 from Oz into a T56 Magnum (only better).
Got my twinplate clutch in. Went with a Spec twin, and I'll be using a Tilton slave to avoid the disaster that plagues the Spec TOB's.
The Spec and like most other twin plate clutches use a thin flywheel that isn't compatible with the standard bolts we buy. Not wanting to grind on ARP flywheel bolts, or buy a set that someone else ground away on I went through the ARP catalog and found these. ARP Part number is 204-2801. Requires a 12mm triple square to install.
They're the ideal bolt for this flywheel. Standard bolt is the 12pt,
Overkill Z's reproduction of the Betamotorsports crossmember. It required a bit of flex on the factory motor mounts to get it to bolt in all the way, but it fits much better than the CX Racing mount.
However, install on a 280Z is a little trickier than I initially thought. Turns out the cups for the tension arm are a bit different on the 280Z and interfere with the crossmember quite a bit. The driver's side isn't too bad, and requires a small trim. The black sharpie tick mark you see is 13.5" away from the firewall. I wanted to get as close to that mark as possible.
The passenger side on the other hand, required a lot of trimming. I would have to cut into the reinforced area to get to my 13.5" goal, instead I'm settling for 14" from the firewall, which will put the back of the block 1" away.
Now I'm off to get some more c-clamps because my harbor freight wood working clamps aren't going to cut it on the next step of the project.
