MONZTER
    29
Everything posted by MONZTER
  1. MONZTER
    10-22-06_019
    new P-90 turbo head, Completly welded up and re-designed/ Chambers being roughed out on the CNC
  2. MONZTER
    10-22-06_007
    more rough cutting. .015 tool offset will alow for seats and guides to be installed and then re-machined to final depth
  3. MONZTER
    1-4-06_062
    current L-24 NA, check out the motor mounts. Yes those urethane bushings are what they look like
  4. MONZTER
    1-4-06_061
    I dont know how many times I have broken the screws for the timing guides, so I retapped them and used 8mm 12.9 grade SHCSrews. No more problems
  5. MONZTER
    1-4-06_025
    L-24 block and big valves = eybrowing the tops of the bores
  6. MONZTER
    1-4-06_018
    welded up and re-shaped N-42 head 36cc with stainless undercut valves @10.7:1 on top of flat top L-24 pistons +.015 out with .050 head gasket. Pump gas and no knock. total advance down to 29 degrees, super fast burn
  7. MONZTER
    1-4-06_004
    kept the ports small for the 2.4 engine
  8. MONZTER
    1-4-06_003
    welded -N-42 on the daily driver
  9. MONZTER
    normal_0557
    8 inch wide Panasports 20mm offset 245-16 F+R no flares, w coil-overs
  10. MONZTER
    050805_017
    not much stock left to the intake for the NA b-car. roughed out
  11. MONZTER
    Rear_Sub-Frame
    pro-e drawings and actual parts
  12. MONZTER
    Rear_Strut
  13. MONZTER
    rear_Assm
  14. MONZTER
    Front_Strut1
