mobythevan
Super Moderators
  1. before this thread goes any farther I am going to suggest that you guys just continue to pursue an explanation offline from msefi.com I don't think it is appropriate on the megasquirt forum here, please post any followups or other discussion in the non-tech area. I am closing the thread because this is not a megasquirt topic, it is a why was I banned topic.
  2. I think that is the last thing that everyone says right before they get the boot I am just a moderator of this group, I don't worry about kicking people, but these discussions never end in a good way when they involve talk of "banning", anything political or an insistence on democracy/freedom of speech. My 2 cents: the topic was quickly deleted from msefi.com because it is a very technical site and I am guessing that any talk of EMP in the past has lead up to a wacky thread, just like this one has been at times. So this time they just deleted first and ask questions later. I am not saying EMP is always a wacky topic, just like the mating habits of baboons is not wacky to the scientist that studies it. But in general it becomes wacky when released into forums like this.
  3. At this point it seems self-explanatory why this topic was deleted from msefi.com With talk covering nukes,terrorists, government conspiracy, aliens, time travel, Mr. Fusion, Faraday cages, etc....... Unless something useful concerning EMP is discussed I see this thread also being deleted, locked or moved to non-tech, but I will leave that up to the administrators.
  4. I have purchased at least 4 megasquirt kits from Jerry, top of the line service, packaging, shipping, etc. I haven't used anyone else so I can only comment on him.
  5. thanks for the update on Hi-Res code. I have been watching it for a couple weeks but haven't put it on my Talon. I think I will do it given your experience. I am running 850cc injectors so idle and warmup has been a bit of a problem.
  6. for reference I always check jameco because their prices usually beat the pants off digi-key, but not always. The only thing is that their website always seems bogged down. Mouser is another big electronics store. http://www.digikey.com http://www.jameco.com http://www.mouser.com
  7. http://www.msefi.com/viewtopic.php?p=117136 http://www.msefi.com/viewtopic.php?p=117560
  8. My car would buck until I set decel fuel cut to 100%. The restrictor sounds like more of a band aid fix that will cause slow MAP reaction times that could affect other areas of tuning. I think I would discuss it more and see if you can just adjust the megasquirt to fix the problem. Also let us know what the reasoning was behind using the restrictor, maybe it is a valid concern in your setup.
  9. According to the equation in Corky Bell's book to go from 400hp to 800hp increases the forces on piston/rod/crank by around 18-20%(I think that was for a V8). So you saying the rule of thumb is to build the bottom end about 20% stronger than you need? just razzin you
  10. I am not in charge of any of that stuff, I was just asked if a megasquirt forum was made would I mind being a moderator of it. I am happy however the administrators might want to restructure.
  11. yeah, thats correct, no HEI with the coil driver.
  12. Correct, there is one schematic in the sticky that uses an HEI module on the input for VR circuits, but that only applies to V2.2 boards. It was never intended that anyone use an HEI module on the input side for optical trigger.
  13. I saw a SBC race engine once that the pistons hit the electrode, but here was the deal. It was a huge domed piston and if the plugs were not indexed to keep the electrode up then the piston dome hit them and closed them down. Unless your running a dome piston like that engine I see no way of the piston contacting the plug.
  14. Also, since Olie05 mentioned it, make sure you have the correct serial cable, straight through or crossover, I always forget which one is correct(check megamanual).
  15. I have problems on my computer because hotsync is always running and using the comm port (for PDA device). So I always have to close it first to free up the comm port. You might check to see if you have other programs running that are using it.
  16. Here is the thread where Tony mentions the project, now you can call him out and see what he has done with it. http://forums.hybridz.org/showthread.php?t=100651&highlight=stealth+conversion
  17. Tony D. was doing some kind of ultra stealth setup that had injectors in the carbs. Not sure what he was up to, but he didn't want anyone to think it was anything but an ole carb'd engine.
  18. will do, I have heard that so figured it is easy for the break in. I was afraid of that, but it looks really good on there. After working with turbos for the last three years I wanted to try a SC. It just seemed like the best of all worlds for a street rod/fun car. It does pain me sometimes to know how much more efficient a turbo could be, but I'll get over it. And since my friend is doing turbos on his SBC will we have a neat comparison between the two rods, one with twin turbo SBC and the other with supercharged BBC.
  19. I went ahead and buttoned it up. I ordered the last parts I need to test fire the engine on a stand. If they all make it in by this weekend it should be running. Can't wait to see how the supercharger works.
  20. Do you have anybody close that has another MSD to swap in?
  21. Thanks for the measurement, I am going to decide this week which path to go. 2 spacers or larger decoder wheel.
  22. when I tore down my BBC last year it has a copper or brass thrust bushing behind the cam gear, about .030" thick. The machine shop said it must have come with the last timing set that was installed. So I put on my new timing set today and was curious to pay attention in this area. I notice that if I spin the engine over a few times and let the cam float to where it naturally wants to be (no lifters installed) the cam gear and cam moves forward a tiny bit. I can just push it back in until it bottoms on the front of the block, you can see that this mis-aligns the timing chain a tiny bit. I would have never even looked at this if the thrust washer/bushing wasn't there when I tore it apart. Is that anything to be worried about? The machine shop measured the surface that the cam gear touches and says it is factory.
  23. The only reason was finding another wheel and whatever cost would be. I'll have to check the diameter again. It is pretty easy at this point to just use two spacers with the wheel I have, as long as the VR sensor fits in there.
