Out of the 5 megasquirt installs we did last year there was one that never functioned correctly (Chris's car), some of you probably remember the description.
Resets all the time in the beginning, tried several noise filters at alternator, by MS, by coil, etc. Tried not hooking up alternator. All the usual stuff that everyone sees and tries with reset problems. In the end it seemed like moving the MS box helped some.
Well, here is what my friend (Mike) found yesterday....
Mike took back the suspect MS box and decided to check it for cracked solder joints, because the history of the resets shows that they come and go with no reason. Sometimes Chris can drive the car for months with no problem (it is his daily driver), other times it resets several times in one day.
When Mike popped open the case last night he found the processor was not plugged into the socket, one whole side was hanging out and just barely making contact enough to work sometimes. We are sure that the processor has been in this state every since the unit was built (built by Mike, not DIY or anyone like that). Anyway we are waiting for the updates now, but it may take several months to verify no resets every happen again. If they do, the next thing we are going to do is re-flow all solder joints, because it was soldered by him and was his first solder job.
The processor not being seated in the socket correctly seems to be the cause of this one, you guys also be careful that one or two pins don't bend under the processor when it is seated, I have seen that before.
At this time the only conclusion I can draw is that the other 4 units I built work fine to this day, I have had professional instruction with soldering and have been doing it for 10 years in my various hobbies. The one unit that Mike assembled is suffering reset problems. I guess the moral of the story is to have DIY or someone else build your MS unit if you are not sure you can do a good job soldering and assembling the other parts of the unit, seating the processor
These resetting problems are so frustrating that it is not worth saving the money to assemble yourself.
