I got the msq file you mailed me and I see problems from the start...
You have a theoretical required fuel of 8.4(white box), which may be OK, but tell me what size injectors you are using so I can verify that.
You have simultaneous injection and 3 injections per cycle which causes you to have a real required fuel(gray box) of 2.8 (NOT good).
Go to alternating injection and 2 injection per cycle, this brings up real required fuel to 8.4 in this case. That is much better, now you are not having the impact of injector on/off time enter in to tuning as much as you were with 2.8 required fuel.
Here is the section from the tuning manual:
let me know what size injectors you are running
here is something else you have wrong(from manual):
you have PWM time threshold set to .1 msec instead of 1.0 msec
I would also change EGO control to only be active above 1200rpm instead of 600rpm like you have, that way your NB sensor is heated up better.
Also turn of AFR target tables until you get the engine to idle and run
Here is the HUGE one I see: You have no ASE (after start enrichment), that is why it starts then dies. You only have it set to 50 cycles and barely have any percentage. Change to seconds instead of cycles and start with 15 seconds and up the percentages to like 15% at 40 degrees and slowly work that percentage down.
YOUR TIMING TABLE IS SCREWED:shock:
your going to blow up(at least blow a head gasket) if you run it that way, totally backwards, you have timing at like 17 degrees under no boost and then it increases to 31 degrees under high boost, you want the exact opposite
TWO important things: read the tuning section of the manual again for setting the constants up correctly and look into the sticky at my starting timing table and compare it to yours. Notice how it is completely backwards, KABOOM, heh heh:lmao:. Pay particular attention to the MAP values, it doesn't matter which direction they are put in to the table, but it certainly matters that you have less timing at 170kpa than 100kpa for instance.
The last question for you: Why on earth are you hacking up an msq like this instead of downloading the one I put in the map sharing sticky for MSnS_Extra021u code and using it to start with??????? That one at least has ballpark settings for ASE, Warmup, spark, fuel, etc etc.
If my tone in this emails sounds mad you are taking it wrong, I got a good laugh looking through that file, and I'm just confused why you didn't start with known settings.
