It looks like I will be firing up my 454 with supercharger next weekend to break in the cam. After that I am going to switch over to the EDIS setup. In making the final setup on my engine for the crank trigger wheel and VR sensor placement I noticed an oversight. With the original plan my VR sensor will not be able to fit within .1" of the trigger wheel like it needs to. The setup on the front of my crank was going to be like this: harmonic damper > 2V pulley with supercharger register > 1" spacer with supercharger register > EDIS wheel(fits nicely over supercharger register) > supercharger pulley The idea being that I would machine 1/4" off the spacer (leaving the 2" register at original length) so the EDIS wheel would stack right in, really easy, but..... That puts it directly against the supercharger pulley which is a larger diameter than the trigger wheel. That doesn't leave me any room for a VR sensor unless the overall diameter of the sensor is less than 1/4" (width of my EDIS trigger wheel) Now it looks like I will need to run 2 half inch spacers with the EDIS wheel bweteen them (still be maching 1/4" inch out of one to allow the trigger wheel to sandwich in). My big question since I do not have a VR sensor yet: what is the overall diameter of the sensors available? I need to make sure that the 1" space I have between the 2V pulley and the supercharger pulley is enough to fit the VR sensor in between.
The only thing I would worry about is the driveshaft angle, and if that worried me I would measure the angle at the rear of the transmission with it in the stock location and with it tilted. If it was less than 2 degrees I would just run it, but that is me. At worse case put a .8 spacer on both engine mounts and the tranny mount, if that doesn't interfer with anything else. Then you maintain the same driveshaft angle and oil levels. It just makes me giggle everytime I think about it, shimming the engine to fit in a big turbo, priceless
Forrest, have fun with the bike. I picked up the GS1000 this summer and me and the wife went on a 3 day trip going over independence pass here in Colorado. It was one of the most fun times we had this summer. She said recently that we have to go on at least one more trip through the Colorado mountains before I decide to sell the bike. I use to be the type of person that worried, then in the last year I realized that a short life full of fun is better than a long life full of none. People tell you that kind of stuff all the time, but it actually soaked in to me. I am not saying be crazy, just like you said, don't be older regretting that you never bought a bike.
MSII installed running in 78 N/A 280z stock wiring
mobythevan replied to twoeightythreez's topic in MegaSquirt
link added to the must read threads, thanks for the writeup -
so that means that you cannot get timing set correctly when you follow the setup procedure? Set fixed timing to 10 degrees and then use a timing light to set it to 10 degrees. So it always moves on you? Can't be set to 10 because you cannot turn the trigger source far enough? OR trigger angle is setup wrong? From reading the post it sounds like you made the circuit change and expected timing to fall into place without having to be set again. I am just trying to decipher where you are at and what you have done to set up the timing correctly.
You will have to look up the spec, but that sounds correct. Then when you put the vacuum back on the manual should also tell you approximately what pressure to expect(20psi sounds low, but look it up??). When you rev the engine it should fluctuate between the two.
I can't think of any big reasons, at worse case you can always instantiate a small processor core in the FPGA to handle overhead and coordination of events. I work with FPGAs at my job. I considered using an FPGA when I first started looking at megasquirt 3 years ago. The reason I considered it was because I had some old test boards here at work that were scrap, so I could use one for free. I still have one of the boards, it was designed in MArch 1999, it has an ORCA 2T26 part on it and 96 I/O that are routed to two pin headers. The problem is that it was never designed with analog to digital circuitry on the board so I gave up and just went with a more tried and true setup. But don't let that discourage you, it is a lot of fun to work with FPGAs and design your own controllers. Over the years I have been able to work with ORCA parts, Xilinx parts and Altera parts. You mentioned the spartan series, that would be a great choice for this project. At one time or another I have tried everything for making my car computer, even etching my own double sided board. It was all fun and good learning, but in the end I went with the better quality boards and kits from Bowling and Grippo. It is just really time consuming and expensive to do one off PCBs that are quality units. But if you can start with a developement kit that gives you the FPGA on a board and fits your needs for I/O you are miles ahead.
Check over your fuel system and fix the pressure problem so that it is up to spec according the engine manual(30-40psi, i don't remember exactly off hand). Just because you bought new parts does not mean they are good parts. Check the voltage at the fuel pump, make sure it is not low voltage because of small wires or bad grounds/connections. If you still have the old FPR swap it back in and see if the pressure changes. If the FPR is working correctly the pressure will rise in the rail when you give it throttle. The longer pulse width will not lower the fuel pressure in the fuel rail.
Sounds correct. From looking at your diagrams I wouldn't do anything with R43 and R57 because they are in a part of the circuit that is no longer connected or used, so if they are in right now or out right now, just stay that way. Once you remove R26 and Q16 they no longer matter one way or the other.
fair enough
You have to set dwell control. Since you are using the v3 board and coil driver, it will not control dwell for you. The only time you can use a fixed setting like 50% or 75% is if you are driving an ignition module or box that will control dwell(like 4 pin HEI module or MSD box). Let us know if that helps. Try the settings I used on the TPI V8, it had a blaster coil. Go to the "spark" tab and the go to "dwell settings" select dwell control cranking dwell = 6 running dwell = 2.5 minimum discharge =1.5
oh, so you are running v3.0 board. The easiest test is to take off the lid of the megasquirt case so you have access to the coil driver. Fire up and wait for the miss, then spray a little bit of freeze spray on the coil driver to cool it down and see if the miss goes away. That is an easy way to determine if the coil driver is overheating. Let us know what happens and then we can determine a better way to cool the driver. What coil and dwell settings are you running?
We had an engine with an 8 pin HEI module that did not have heatsink compound on it. It would do exactly what you say, run great for a few minutes, then start to miss, miss more, then die. We suspected the module for quite a while, and then noticed when we removed it that it didn't have the grease to allow it to cool properly.
The only reason I see that FPGA's aren't used more is handling analog to digital conversion. The processor works better for that. But if everything was digital or the processor is used for that function and then like you say everything is sent over to the FPGA in digital format then it could be used.
it brought $400, interesting You guys have to go back and read the extra paragraph that he added at the bottom, pretty funny stuff, what a whiner
I just noticed today that the piece of paper with my summit oil pump for the big block says it requires a steel pinned sleeve for the oil pump drive shaft or it voids the warranty. What is the story with that, is it really required? I can't use my stock oil shaft with the nylon sleeve? Looks like it only around $10 to get a shaft with a pinned sleeve, but I have to wait on another part to get shipped in.
remember that in the beginning before MSnS_Extra was even available and we were just using Magnus' MSnS code there was no setting for dwell. The HEI modules had to be heatsinked well. Then as Extra code come into play the eventually added selections for 75% and 50%, then finally you could set dwell (cranking, running, minimum). Even with the magnus code my HEI module worked fine, I believe that was at 100%???
MT/MSnS-E “RESET� issue, and 029q config for MT....
mobythevan replied to BRAAP's topic in MegaSquirt
here is a very short web page that talks about resistor plugs, I haven't searched the megasquirt manual, but I bet there is something in there about resistor plugs (I'm off to look) http://www.hondata.com/techksparkplugs.html I searched the manual and did not find any info on spark plugs and wires, however by searching the site the consensus was to use resistor plugs or resistor wires to keep noise down, so that supports the findings in this thread. -
what kind of dwell control were you running before when the ignition would not work? for reference
I saw that car since I watch for local stuff, but I won't even consider buying it and its only 20 miles from me, nasty. Well, if it goes for $75 I might bid, but he thinks the wheels are worth $500 .
It may just get moved to non-tech, but I don't see a problem otherwise
So do you ride those horses? better post a pic of that too
So does that mean that it works correctly now, with the pullup and everything set like in the sticky?
I think I have seen one of those cars before, they come with a diaper dispenser in the glovebox
