                Posts108
Everything posted by nscason
	Thanks guys. Good to know.
	Thats the jest of it. I wasn't interested in the hydraulic lifter head what so ever. I needed the other parts and will use the block for a stroker build if all of the rest of my build goes well. But hey, nothing wrong with this perfectly good transitional/hybrid head. So I'm going to save myself some time of messing with a different head and clean and reassemble this one. All I need to do is open up the intake ports to the size of my lonewolf race runner intake manifold. My initial plan was to use the E31 head from a 240z I have with the stock bottom end that I know is good and rebuilt about 8 years ago. The block from my '77, not the motor to the 240z. The condition of that motor is unknown at the moment. It was sitting out in the desert for 20 years. The E31 would have given me a little higher compression from the stock 8.3:1 to 8.6:1ish. I would have had to drill the holes for the fuel injection. Screw it though. I'll go with the turbo head and perfect valve train. hahaha Lower compression means more boost.
	Negative. I removed the lifter base from the head. There was no Insert or even the oil passage hole for the hydraulic lifter. This head that I have has never had a different setup. There was absolutely no signs that the motor has been messed with. It appears that the motor has never been taken apart, rebuilt or even ran hard. The head had the original factory machining marks on the head mating surface. My machinist buddy that has been building motors for 50 plus years, confirmed my suspicions.
	I haven't heard of this or seen it until right now. Ok, so from everything I have known about turbo Z motors, the '81 and 82 zxt's had the p90 head with solid lifters and came only with an automatic. The '83 had the p90a head with hydraulic lifters and the borg warner t5 5speed. Right?! Or is there a blur between the lines? That is what I have come to know for years now. Months back I finally got around to pulling the front suspension, motor and trans out of an '83 zxt at the local junk yard. It had been there far about 3 years and had THE definition of a rats nest under the hood. All you could see was a valve cover. It worked out for me as a junk yard non-die harder deterrent. I got all of it for somewhere in the 300ish dollar range. Not bad huh? haha It helps to take the yard attendant a case of his favorite beer I just barely got around to building my crazy turbo setup for my Z. I had all the parts I needed except for the different pick up tube/screen for the turbo pan with the rear sump. Figured I would tear the turbo motor apart for later use and grab the tube in the process. One thing that I didn't take much notice too was that the "Nissan Turbo" valve cover wasn't all square and boxy like I have always noticed in the past. This one is rounded with nice rounded corners and had the factory black wrinkle coating. Pulled the turbo and manifolds off. Went to take off the valve cover and....... SOLID LIFTERS!!! what the hell?!? Was this car a special edition or one of the first off the line marked as an '83 before the started implementing the hydraulic lifters??? Has anyone encountered this before? Needless to say, my plans for this motor have changed slightly. worked out for me I suppose. I have the factory Intake and fuel rail that I don't need as well of a set of hydraulic lifters from an actual p90a head. The lifters are in pretty good shape, If anyone is interested shoot me a PM. What do you guys think? Crazy huh?
	  Experiences with Aluminum Flywheel on Z'snscason replied to Zlovemachine's topic in Nissan L6 Forum i just got back a 5sdp tranny from being rebuilt and i was going to swap that out from my 4 spd. i was going to slap a 10.5lb alm flywheel and a race clutch (something still streetable, nothing all out). i am going to do this in the next 2 or 3 weeks and have been told by ppl to stay away from the light weight flywheel. reading all of this i am going to through that nonsence out the window. i am going to buy a fidanza and a zoom stage III. i have done quite a bit to my z and it is much better over stock. the clutch is most likely originle and it isnt like i have been nice to it either. will adding one of those afi race dampers help to make an even bigger difference over the current setup? i figured maybe just to go the extra mile with lightening the rotating mass. any of you have am aftermarket damper/harmonic balincer? did it help any? thanks.
	i just head about a hydrolic handbrake that is used for drifting. it doesnt have a button to lock it in the up position. at least thats what i think. i eventually plan on installing the willwood brake upgrades all the way around. i know that it doesnt have any use for a parking brake. you need to use a line lock for that function to work. has anyone thought about using the hydrolic handbrake, or is currrently using one??? i would like some kind of guidence on this new idea. some sort of info before i deside to go with it or through it out the window. thanks for anything you guys have. Nick
	i couldnt agree more. i would rather have a crappy z than a nice looking wagon. even a run down z rolling out of mex turns heads. you arent going to get that with a wagon. i am doing all kinds of body work on mine and it looks like hell. i am still getting ppl that want to buy it. aparently i am not the only one around here that sees not what it is but what it could be.
	think about it though.... subaru wagon.... 4wd. that thing is going to have some kind of cornering advantage over a z. i think for a "500hp" z that was a pretty small course. lets see what happens when they both are on a bigger course. my money would be more on the z. i dunno, just my thoughts.
	i do have a full exhaust system with a cherry bomb glass pack that is waiting to go back on. i just havent had the time to modify it to work with the new header. i had a msa 3into2 on with header wrap. in 2 years it cracked and fell apart from the extreme heat where i live. i have had my car in the west coast z nationals for the last 2 years and out of all of the n/a sounds i like mine the best. close to no restrictions and it sounds great.
	http://www.youtube.com/watch?v=uYrO0deKzlI
	  i know it isnt a Z... does any one have a solid idea what this is???nscason replied to nscason's topic in Non Tech Board oh no doubt about it. it will be A LOT of work. if i get it, i dont plan on having it be drivable for at least 5 years. i have noticed that with this car in particular... what ppl think is from one extreme to the other. i dont really care. it will be mine and one of a kind. i might even be lucky enough to get what i put into it in 20 or 30 years. if i have it for that long and break even, cool for me. hell i might even make something out of it. i am not one so sell my cars though. what kind of gas mileage can i expect out of a beefed up turbo 4 banger? i will most likely run a straight pipe off the turbo. oh hell yea! it will scream. hehehe
	  i know it isnt a Z... does any one have a solid idea what this is???nscason replied to nscason's topic in Non Tech Board thanks for the pics and the info. it helped a lot. i guess ill stay with the vw motor and trans for cost and availability reasons. if i get it (my mind is pretty set, just hope the guy dont want too much) i think ill paint it that nice formula one red with a metal flake. slap some 9" wide tires on the back and run the exhaust though the center where the tail lights are going to go. like the pagani zonda... what do you guys think? one nice big shiny 3" pipe right in the middle of the tail light panel. there is only going to be one cuz it is going to be a turbo charged vdub motor. hehehe 300+ bhp. the pics that are above... i dont like them and didnt picture the car in my mind like that. it will be of my own make and design. new skool touch to an old school car. it will be a sweet ride.
	I know it is a vw kit car. it is off the frame of a meyers manx. it takes a vw motor and trans. it does have the inside tub of a manx. i just cant figure out what it was originally called. the closest i found online was THE SCORPION. other than that i have no idea. does anyone know? have you seen something like it? i want to buy it for my next project and drop in a porsche motor and trans. some one jive me some sort of idea. point me in some kind of direction. thanks. here are some pics. if you guys have any ideas, know or knew someone with one, or have seen one let me know. i want more info on it. thanks of anything you all have to offer.
	what i was told to do buy a pro race mechanic was to get the gasket that i am going to be using and clamp it on the manifold. there is this small can of red dye that you paint on the manifold where you can see the meterial needed to be removed. then before you remove the gasket take a needle and score around the gasket that way there is a physical mark to port out to. i have doen this with my head, turbo manifold and the intake. looks great and will work a lot better. the head i am going to throw on is about half way done. if i can find the pic ill post it later.
	i dont have a turbo yet but, the injectors i have are the black ones which are for the zxt. what temp tstat do you have? 185? when is the last time you looked under the housing? maybe it is stuck closed? just figured i would throw some ideas out there. hope i helped some.
	10seconds of not a whole lot of fun = $5,k. not worth it to me. stupid bastards.
	i dont have a zxt haynes manuel yet. that is on my sh@t to buy list. i dont doubt that it would have it. the one wire was ripped out of mine. if you could give me some info from it that would be great. or anyone else for that matter. i was wondering of its original purpose and the point of having it there. any insight is appreciate. thanks.
	i am in the proses of collecting the parts for a turbo swap. i purchased a turbo oil pan from one of the members here. i noticed that there was some sort of sensor that was located right next to the drain plug. the only thing i can think of would be an oil temp sending unit. i gave MSA a call and they didnt know what it was. as far as they knew there never was any kind of sensor there. from what i have learned you dont need a temp sending unit in the pan. is this a stock piece or is it an aftermarket thing. does anyone have any ideas? i want to know if i am going to want to use it, the space or just completely ignore it all together. if anyone could shed some light on this that would be a great help. thanks. Nick Cason
	sorry i didnt read the big huge thing of writing, but i saw all the pics and though i would share. i am going to the local community college and decided to take an auto body class. so i could learn to do all of the custom work myself and save thousands. there was paint bubbling here and there. i figured it was surface rust. nope. now i have a hole the size of my first on my rear passenger side rocker panel. i know i can get the part from black dragon AKA victoria british i just havent had the money. not anywhere close to the pictures that i just saw. nice repair work. the problem for me is that my car is a daily driver and i have no other vehicle.
	that might be my problem. as far as i know the casing to that wire is fine. to be honest i havent got to fixing the problem partly because it gets to around 120 degrees outside and working on my car in a garage that has no air movement isnt all that great. the only diecent time to work on my car is late at night. starting a project at 9:00 pm isnt all that great. ill eventually get to the problem. thanks for more ideas.
	  rebuilding stock turbos to higher hp! WHAT ARE YOU RUNNING?nscason replied to neorazz's topic in Turbo / Supercharger it should just pull out. there is a small piston ring that is on the end where the terbine blade is. that is mostly what is holding it in there. if you are going to do a full rebuild there isnt that much harm you can do. try tapping the other end of the shaft with a dead blow hammer or a hammer and 2X4. it should pop out. guys correct me if im wrong. i have taken 2 apart and that was a few months ago.
	  rebuilding stock turbos to higher hp! WHAT ARE YOU RUNNING?nscason replied to neorazz's topic in Turbo / Supercharger i used a hammer and tapped the sides alternating till it came off. mine was the same way when i was taking it apart. it separated in about 2 mins with the hammer. didnt do any damage either.
	my z is part way through a lot of body work and looks like something right out of mexicali. working on my car durring the day is hell. dont get me wrong. i love working on my car. i cant stand finding gremlins unless they are making the car not work properly.
