Everything posted by Daeron
Picture of stock fuse layout for a 75 280Z?
Daeron replied to Daeron's topic in Ignition and Electrical
Muchas gracias senor! -
Looking for a good 1975 L28 complete in NorCal
Daeron replied to autoxR's topic in S30 Series - 240z, 260z, 280z
well, I would mine through craigslist in a 100 mile radius, maybe even post a couple of wanted ads.. certainly wanted ads here and on any other forum you can find. you ARE in california, it shouldn't be THAT hard to find a spare engine.. Good luck man! -
I cannot believe how much difficulty I am having trying to find a picture of the fuse panel cover of my car..... google cant find one, either on the web or on hybridZ, OR on zcar.com. The freely downloadable FSM is lacking the BE section, and I am lacking my haynes manual since it fell apart on me ages ago and wasn't much use anyhow. Any help here? This sort of information should be something you get hit in the head with daily, like the firing order in my sig...
Blue's TechTips electrical page has links to wiring diagrams for all S30 models.. as well as countless other great resources once you start winnowing through it. http://atlanticz.ca/zclub/techtips/electrical.htm
Last time I was tested, I rated "above average" myself...
I am about to go testing and picking apart my electrical system, which is step two of the resurrection of my car. Step one was splicing in a fusible link block to replace the burnt wires, and I am fairly confident that I have achieved that with solid results. Now, whenever I have a battery connected to my car, the right turn signal is solid on, and the headlight circuit is fully energized and functional. Regardless of key position. Obviously the ignition switch gets tested first, but practically EVERYTHING in the circuit seems to be intricately tied to the "interlock relay" and I cannot, for the life of me, find a location for this malfeasant unit in the @#$*@#ing book. I want to eliminate this pesky, Nader-gratifying subsystem from the vehicle entirely, since I plan on relaying my starter function ANYhow, fully independent of the ignition switch other than for a starting signal. Any help finding this box, and any insight into how one might go about removing it without simply installing an aftermarket wiring harness, would be appreciated. I have my wiring diagrams handy, and will almost certainly find a way to plow though it on my own.. but home re-engineering projects (especially of an electrical nature) are best approached with an abundance of knowledge, not a dearth.
http://www.atlanticz.ca/zclub/techtips/efisystem/280zfuelinjectionbook.pdf Right click, choose "save as," and read it. Read the first section all the way through, the start over and read it a second time. If you are feeling spunky about graduating from Datsun EFI School cum laude, then read through each diagnostic check and then go back and read the entire first section a third time. Then, when you have a problem, go read the relevant portions of the first section, and perform the relevant tests according to the flow charts. Every... Single.... Problem... that your fuel-injected L28 could possibly have, is covered in there, more accurately than you could even hope for from HybridZ. Granted, wiring problems get difficult to track down.. but if you pay attention while you read, you realize that ALL testing of any components is supposed to be done at the ECU plug, and not at the component. Checking a component at the ECU plug not only checks that the component (AFM, TPS, whatever) is functioning right, but it also tests the wiring at the same time. Download it. Print it. Staple each page to the ceiling above your bed so the information trickles down into your brain by osmosis and haunts your dreams. (Stay AWAY FROM ME, EGR MONSTER!!!!!) Most of this information is also in the Factory Service Manuals, available for download here. Please be kind enough to utilize these resources to the fullest before asking questions of the general HybridZ populace; the purpose of this community is primarily performance oriented, and stock running questions get tiresome to answer over and over again. If you DO have the "newbie question" then having researched your problem (read: being able to say "I read the EFI bible but....") will GREATLY increase YOUR odds of getting a helpful answer. Go now, in Peace, to Wrench and Tune the Z.
Odd hesitation problem, efi guru's look....
Daeron replied to john kosmatka's topic in Trouble Shooting / General Engine
thermotime switch. find the EFI bible. It answers all your questions. http://www.atlanticz.ca/zclub/techtips/EFI&fuel.htm -
Install pics of my new Pontiac Solstice Tan & Black Leather Seats
Daeron replied to RB26powered74zcar's topic in Interior
Yah, the color combination is beautiful... It really works with everything else to combine vintage looks with modern looks in a way that maintains the old feel of the interior, but at the same time looks like it just rolled off of a showroom floor. Any plans for custom door panels? if SOOO.... then I know someone who wouldn't mind your old ones -
Let's talk about winglets and canards
Daeron replied to HeatRaveR's topic in Windtunnel Test Results and Analysis
You do not need a smooth, easy transition for air out of your engine bay like you need smooth, easy transitions into your intake port. The problem with lift and air under the hood is one of high pressure. Provide that higher pressure air with a vent-hole to a lower-pressure area, and it will move around whatever seems to be in the way... and with less pressure under the hood, it will make it easier for fresh, cool air to flow through the radiator. -
First off, let me make it clear to you that I am most assuredly NOT a fan (aesthetically speaking, anyhow) of the "wide-body" look on a Z. Secondly, your wide-body kit looks DAAAMN good. x a billion. Thirdly, and I am no expert.. but my impression on the air dam aerodynamically speaking, is all fantastic.. I cannot recall right now if a similarly shaped airdam/flare combination was actually tested, but I would say that to start dickering around with the shape you have now, based on info learned from other shapes, MIGHT be fumbling around in the dark. In other words, I would say that what is already on the car is such a departure from what was tested, that to implement ideas that seemed to work well according to the aero tests on it, may be an exercise in a vacuum of knowledge. More photos please!
You're only using one turbo? Are you sure its big enough? okay seriously, though... where did you get that pic of the turbo'd V8Z? whose car is that?? where can i see more????
Cut Main headlight/turnsignal, etc harness- How to fix...
Daeron replied to Challenger's topic in Ignition and Electrical
Tell your friend to keep his hands off the dikes. -
subaru EA81 and EA82 as well (80s 1.8 OHC and OHV) NGK BPR 6ES-11 is one of my oldest friends......
I don't understand why this is an issue. The Brake/Tail light bulb is a dual filament bulb. Install slightly less than half of your LEDs powered by the Tail light wire. Install slightly more than half your LEDs powered by the Brake light wire. KISS, right?
what are you charging someone for one of thse cleaned up manifolds?? We have a whole PILE of EFI manifolds that I could easily do this to rather than sending them off for 40 cents a pound (IF we get all other metal out of it first..)
N42 heads are all the same, yes. Same valve guides, same valves, possibly cam differences is all I can think of, and I can't answer that off the top of my head. The heads themselves are the same, though... there is no mystery like "early E88 versus later E88" or "P90a with solid lifters" or anything like that. All dquare exhaust ports, same combustion chambers, etc.
Cast Intake Manifold dimensions-How Big can you go?
Daeron replied to Xnke's topic in Nissan L6 Forum
One of the primary differences in the various SU manifolds is the shape and aspects of the walls that divide the single channel first into two, then one of those channels dividing into two more. The shapes inside of the manifold are slightly different. My point is, the "10 hp" claim is based on more than sheer size. Trust me, when I get to it, I will add a TON of data to this post. I want to do the same thing you are doing, and I have about 12 EFI manifolds and i dont even know how many SU manifolds (at least 3 or 4 i can easily get my hands on, likely FAR more.) -
okay well,, im sticking my foot out on this one, but couldn't you simply re-ring the engine? Pull it, put it on a stand, pull the oilpan, remove that piston and con rod, and put new rings on it? I mean, sure, its hackneyed.. but it would repair your car.... Otherwise, find a Junkyard. Chances are about even on finding a $1-200 engine here versus a local junkyard... unless Northern California has gotten as bad as South Florida has with these cars. -
sounds like some magical freakin stuff. TonyD.... Are you for real?? You sure you aren't some twisted sort of computer program, being run from the scanned memories of Mr K, Pete Brock, Bob Sharp, and Paul Newman???
God, I hope I don't muddy the waters here. I've learned a good deal about BOV vs Bypass valves, and how they work in tandem with the wastegate, in recent months, and cleared up a few misconceptions *I* had had, that it appears may be affecting you as well. SO, I will go ahead and try to explain since I feel like your mis-understanding is similar to what I had held... I hate talking about a subject I understand only abstractly like this (no real turbo exp. to speak of here) but here it goes. The short version is, your wastegate allows exhaust gasses to bypass the impeller wheel. When the wastegate opens up, the turbo loses the force spinning it and generates less pressure. The Bypass valve (whether it is a recirculating type or a blow-off type) eliminates excess pressure on the charge side that has already BEEN built up by the compressor wheel. The wastegate is step 1, and then the bypass valve is step two. Bishopsrock, I am not entirely certain why the stock routing is the way it is... but it appears to me, from the diagram, that the "pick-up" for the BPV air circuit actually comes off the piping nearer to the manifold inlet, then gets routed down there to those two bypass valves mounted on that Y shaped pipe you picture. It gets popped off by one or both valves, then runs out into that Y-pipe, into the tube crossing underneath the IC, and thence back into the turbos, if I am not mistaken. In other words, the air actually moves down thru some tubes, from near your manifold inlet somewhere (look at the diagram, i've never seen a skyline) down to the two BPVs, then into the Y.. the intercooler is only involved b/c the air has in fact already gone thru it. I suspect that they did it the way they did to vent cooled air, straight back into the outlet of the turbo where the air is hottest, rather than venting warmer air there. Plus, proximity to the throttle plate in the point where your blow-off occurs, is good, when you are trying to eliminate the pressure hammer caused by closing the throttle abruptly after accelrating on boost. Where are you recirculating to? you said "vent back into the MAF," by that you don't mean anywhere in front of the hotwire in the MAF, do you?? If so, then that air is being metered, then dumped to before the meter, and then being metered again.. essentially, the same situation as if the bypass valve was an atmospheric blow-off valve.
75 280Z with stock A/C, what's it gonna need?
Daeron replied to Daeron's topic in S30 Series - 240z, 260z, 280z
:iospalo:Let's go digging.... bring it out, and take it back in... except I want it about FORTY degrees, COOLER. (Tool reference, great band) So I was turning these questions over again in my mind, and I want to revisit this thread. Despite hearing others say that converting their Z's AC to R-134a seems sufficient for them... I just don't know. 90% of the reason I want an AC is to be able to get in the car after, say, being out in the sun at the beach or fishing, and just turn it on full blast and get a smack of air at 32 degrees fahrenheit in the face. (Well, not literally that cold, but you get the picture..) So whatever, I will make up my mind on the refrigerant being used.... Anyhow, in reviewing the thread, I realized that I had missed my original thrust in the post by getting sidetracked into the possibilities of retrofitting newer components into the vehicle. My big question originally is.. What are the odds that I can go to the car, pull a vacuum, and have it hold? Am I probably looking at replacing many seals and O rings simply because the system has been, sealed to the best of my knowledge, but simply at atmospheric pressure for so long? (I've had her for 8 years now and it was dormant LONG before I got it.) I understand that the receiver/dryer almost certainly has to be changed because it is a wear item.. but seriously, how would I proceed in reviving the system? Should I just get my brother to pull a vacuum on the system, and if it holds for a few days, buy a new receiver/dryer, and get some R-12? Or should I replace a few easy-to-reach seals first, should I check the oil? I've been reading the A/C section of the 76 FSM I have handy... Also comparing to the 74 on my PC b/c the car is a 75 and the 75 FSM I have in PDF is missing the AC chapter. So I understand most of the procedures and what is involved.. I am simply not yet confident that I understand everything that I may run into. When I reached the section on compressor overhaul I started skimming, and only noticed a few seals involved.. It just seems too good to be true to think that I might be able to get by with simply replacing the dryer, buying some Freon, and charging it up. Is this THAT outrageous a possibility, and if so, what is most likely to be problematic? TTBOMK, the answers are thus: (given that the receiver/dryer needs to be changed) 1. Compressor shaft seal 2. A few random O-rings like line seals and silencer O rings that are easy enough to get at 3. Evaporator Expansion valve Beyond that, as long as my lines themselves, and the two coils (condenser and evap) are intact... it should just go, right? -
I ran a search on "air conditioning" and for some reason this thread came up first.. so I may as well update it with the news that I have patched in a Maxi-Fuse panel out of a 94 Caddy Deville into the car, but thus far have had zero success in finding my short. Must work on it more tomorrow; I ran out of daylight the other day.
Z-ya and I had that idea about exactly at the same time.. he made a cryptic remark to a wacky intake manifold idea, and I PM'ed him with a guess right off the hip. I *think* we both may have been inspired by the same comments from TonyD. Unfortunately, I haven't had a chance to play with anything yet, but I have immensely enjoyed his manifold porn I also have access to several stock manifolds, both EFI and SU manifolds but am more familiar with my stock of EFIs... I haven't gotten around to it yet because I am not spending much time up at the family shop, but a thorough inspection of all the differences in the manifolds I have is on my "to-do" list, largely for just this purpose. I am mentally busying myself (have been all day) throwing ideas around for a plenum/divider of sorts for this setup, and pondering all day what could be done to improve everything, and where... My impression is that it shouldn't be very difficult to build a rather compact plenum box that would evenly and equally distribute things into the throttle bodies, and then to work some more on the manifold itself to get it ideal. I may end up cutting a set in half along the horizontal plane and do some serious re-working, basically using the manifold as stock........ ...but thats all ideas batted around thus far. I won't see fruition on any of this for a long time, so I hate to talk about my ideas out in the open lest someone else build my car before I get to. -
does the compression in the bad cylinder come up when you add oil to the cylinder? If not, your problem isn't rings, its either a bad headgasket, or a sticking or burnt valve. I may be missing a few other possibilities, but I wanted to make sure you realize a single, dry compression test showing low numbers on one cylinder does not, by itself, diagnose anything.
