01vincer6
Everything posted by 01vincer6
  1. Looking for a 1972 240z passenger side rear quarter panel. Change plans for fender flares and need good panel. The new sectioned replacements available are to small to cover the area..
  2. I almost bought the fenders but they are mostly fiberglass right?
  3. Ya Facebook Retrospec if you want quicker responses.. Mine shipped out in about 4 weeks through them. Palm Composites I ordered the carbon door panels on a Friday and had them by Thursday.
  4. I have the front air dam and cowl in carbon. Not a bad product but their lead time is nuts. Palm Composites is better quality but less available atm.
  5. I mounted mine to the outside of the headlight bucket and not the inside like you have pictured.
  6. Crazy to see how much time is involved making carbon parts. Excellent work
  7. Contact zcardepot.com. I think he might be able to offer something.
  8. Heading out of town but will get it removed when I get back.
  9. Sorry I will try to remember tomorrow.
  10. I have one. Let me see if I can get it removed today.
  11. http://forums.hybridz.org/topic/123686-14x7-minilite-clones-with-radial-tires-rear-15x7-with-slicks/?do=findComment&comment=1156190
  12. See my post with wheels and slicks. I also have an r230 vlsd
  13. Thanks cgsheen. I ran the black yellow to a relay then to the starter solenoid. Started up without a problem. I will post the final wiring layout for anyone wanting to use this new jegs 20 circuit with an msd ignition when I get finished.
  14. I think I have everything figured out. Reading old schematics while hungover is not the easiest thing to do. The Black Yellow I will test continuity to see its purpose.
  15. Just figured many others have done this and had a simple answer. I didnt think you needed to add a resistor to the green white and an accessory relay.
  16. http://forums.hybridz.org/topic/53862-confusion-wiring-up-the-alternatorignitionstarter-with-pictures/ This one says the White/red goes to the ignition power .. Jegs 20 circuit is what I am using. 555-10405.pdf This car has a zz383 with carburetor. Using MSD ignition box and blaster coil..
  17. I have found alot of mixed information probably due to the different wiring colors per year.I need to know what wire goes where from the ignition 6 pin connector. I have from the switch 5 wires on the connector. Black/Yellow, Black/White, Green/White, White/Red, Blue/Red. My new Fuse panel requires a (Coil) IGN wire,(Ignition switch Accessory) ACC, (Ignition Power) Bat. I believe the Black/Yellow goes to the Ignition (Coil) wire and the Black/White goes to the (ignition power) Battery wire. Does the Blue/Red and White/Red go to the (ignition switch Accessory) ACC? Also does there need to be a relay between the ignition power and the fuse panel?
  18. Just mounted my speedhut gauges. Finally got to use my crack free dash also! I used the old gauge plastic bezels and epoxied them to the dash then mounted the gauges to them. For the tach and speedo I used the speedhut billet adapter which were epoxied also.
  19. I went over to his shop and looked at them. Very good quality and sturdy. I am going to get a set of the 240 version when they come in.
