Everything posted by jasper
http://www.ebay.com/itm/Gas-Turbine-Engine-Rat-Rod-Jet-Car-Rocket-Hot-Rod-SR-71-Datsun-280zx-/150819504364?hash=item231d8b00ec&item=150819504364&pt=Motors_Aviation_Parts_Gear&vxp=mtr
Consulting a Lawyer is a good idea. Getting checked out by a doctor, also a very good idea. Very important; Just because the responding officer didn't write her a ticket, doesn't mean YOU can't. A cop can't write what he doesn't see, or can't back up. Go to the police station, and file complaints. Examples;reckless driving, carless driving, cell phone driving, tailgating,etc. Provide witnesses names.......subpeonas will be issued. Once found guilty, the insurance will be a slam dunk. I used this strategy when some clown ran a red light, and totaled my '68 GTO convertible. Calm down, protect your health, and protect your interests.
Just cannot get a seal at the cast iron flange
jasper replied to BlueStag's topic in Nissan L6 Forum
Read your whole post, can't figure out where your leak is ?! Be less wordy, and more precise. FYI,..high temp silicon works wonders...... -
I also have the Hella Supertones, on my 190E2.6 Benz. People seem to pay a bit more attention to their "irritating" sound. They're good, but they really didn't impress me. I'd like to try some Fiamm "Highway Blasters". I had Fiamms on my KZ650 back in the 70's, and I was impressed. People MOVED when I hit those horns. I might try some early 70's Eldorado horns, not in sync with a Datsun's look, but plenty loud and LARGE sounding.
If you start to take apart the engine, without having a SOLID diagnosis, your only course will be to visually inspect every moving part until you locate the cause/source of the noise. If you lack the knowledge to identify the noise, it's possible you lack the knowledge to identify the culprit during the visual inspection. This can be tricky, assuming you don't find an obvious/catastrophic failure. Typically a rod knock is; "loud" on start up, and then decreases. Responds to snapping the throttle partially open being louder, more pronounced. Holding the throttle partially open may reveal a "sweet spot" where the noise is very pronounced. Carbon on top of a piston can cause a "rod knock". If the noise is present at idle, pulling a plug wire or shorting cylinders will lessen the noise considerably. Also appilies when rpm is at the "swwet spot". sounds similar to wrist pin and or piston slap. Is said to have a "double knock" type of noise. A cracked flex plate can sound JUST LIKE a rod knock (auto trans) etc, etc. If this beyond your ability get a professional opinion.(keep trying) As long as you don't take the engine apart, diagnosis is probable. START by removing the engine belts, to eliminate any rotating accessory noises/possibilities. Step on the clutch to eliminate the possibility of internal transmission noises.
First, please explain the symptoms/noise, and how you determined how/why this is a rod knock. If indeed you have a rod knock, many times it can be "repaired" by replacing the bearing inserts,and sometimes cleaning up the crank,(all in car)......cheap! I have done this personaly a few times.......none have come back. Tell us more............
Fuel pickup issue on '73 carbed Z, where to start?
jasper replied to tommott77's topic in Fuel Delivery
I would drop the tank, and do a full inspection. Refurbish if needed. Maybe upgrade, do a search on sumps and baffles. I would pay particular attention to the fuel pick up tube. Maybe bent, or the end rusted off, and now short. May also have rust/pinholes sucking air. -
The dopes at Rock Auto can't get it right. I also ordered the inners ( from Rock Auto)....years ago..same result. They paid return shipping, but never fixed the listing!! Do a search, there is info and options.
260z cannot find idle below 3k rpm
jasper replied to ApexGoblin's topic in S30 Series - 240z, 260z, 280z
Some pics of the installation may help. -
cold hard cash plays bass fiddle to no one
jasper replied to nelsdanger's topic in S30 Series - 240z, 260z, 280z
Very nice. -
Suspension related however not the Z
jasper replied to c4220's topic in Brakes, Wheels, Suspension and Chassis
From what I see: Slight over inflation, more wear in very center. Outside edge wear, hard cornering, and or toe in. Inside edge wear, toe out,and or negative camber. Or a combination of the above. This assumes you have maintained the same tire pressure over the life of the tire. If they were run low for a while, you will wear both inside and outside edges simultaneously. The front tires on a FWD car always take the worst beating/wear, even if the alignment is perfect. They don't look bad for 40,000 miles, considering your "at" the thread wear indicators. What are the DESIRED Factory Specs for toe and camber?? -
I pay $150.00 a year. $18,000.00 + agreed value. My other Z is $50.00 a year, $5000.00 value. Check them out. http://www.americancollectors.com/
lfa style wheels... could i, please?
jasper replied to onyx_riddle's topic in Brakes, Wheels, Suspension and Chassis
You probably already planned for this, but, the link shows wheels for a 5 lug setup. Stock is a 4 lug. Maybe I missed something? -
Don't use JB weld. If you do seal up the hole, use a non permanent silicone sealer. IMHO,reverse lights are a safety issue. I would make sure they are functional.
Power braking an engine is an acceptable test. It reveals stall speed/slipping in an automatic trans, and brings to light ignition short commings,etc. I don't think JSM is anal, I think you lack experience, and knowledge.
To be honest, all seem to be Bland/Winebago like, IMHO. Now for the constructive part........ Maybe you could use this lighting behind a clear/smoked/colored cover, with a design ??. Similar to a 80's/90's Firebird set up
Sorry, not for sale. Anyone have a nice set of velocity stacks for sale?? I'd be interested!
Try Dave. http://forums.hybridz.org/index.php/topic/103757-weber-dcoe-linkage-custom-billet/page__p__970287__fromsearch__1#entry970287 Hey Dave, I have a set of phh40's if you need to borrow them for R&D. Nice and clean!! 2 manifolds also.
Need help with my Clutch & Transmission ('77 280Z)
jasper replied to TheCrazySwede's topic in S30 Series - 240z, 260z, 280z
Your clutch is not fully disengaged. Look for leaks in the hydraulics, bleed system. Check the adjustment at the pedal. Follow FSM diagnostics and adjustments. -
My sister emailed me this. No clue where it came from. A woman calls an import parts warehouse and asks for a 28-ounce water pump. "A what?" says the confused parts guy. "My husband says he needs a 28-ounce water pump." "A 28-ounce water pump? What kind of car does it fit?" "A Datsun." As he writes down "Datsun, 28 oz. water pump" the light in his head goes on. "Oh yes ma'am. We've got 28-ounce water pumps. We have 24-ounce and 26-ounce water pumps too." "Finally," she says. "You're the first place I've called that knew what I was talking about." "Yes ma'am. That's because we're a full service parts warehouse. It's our job to have the parts you need, like a 28-ounce water pump," he says, smiling, as he jots down customer pick-up, Datsun 280Z water pump, part number . . .
http://forums.hybridz.org/index.php/topic/91432-su-identification-parts-wanted/page__p__865408__fromsearch__1#entry865408
Call your local Auto Glass shop. A new windshield should be available for well under $300.00.
You need to do some home work!! All 3 carb choices are in a different realm. Start searching and get a direction, and focus.
The owner passed away, car went through a few hands without a title. Not stolen. Spent the last 12+ years in a garage. It now sits in my driveway, in New Jersey. Anyone have any experience with Broadway Title sevice?? Now taken over by GNT aka GetNewTitle OR, how did you get a title??? Note, photo enhanced a bit by my son.
