jasper
Everything posted by jasper
  1. Now on Ebay. http://cgi.ebay.com/ebaymotors/1972-datsun-CHOPPED-240Z-/250803461189?pt=US_Cars_Trucks&hash=item3a650d1c45 With more pics.
  2. I personaly, could never love another.
  3. Looks kind of neat,but maybe an inch or 2 too much?? Must have taken A LOT of effort. I'm thinking he sunk the windshield down into the cowl area. http://www.datsunclassifieds.com/showproduct.php/product/6088/title/chopped-240z/cat/1
  4. I have never seen belt tooth profile NOT match, gear tooth profile. In stock form, if the belt is OVER TIGHTENED, things get noisy. In my opinion, the gear is not compatible with the current belt.
  5. Learn how to solder, and repair it. Quick, cheap, and easy. Be careful with the gas. Don't use one with a flame.(electric)
  6. I'm a sucker for a good violin. My personal favorite. I am also very impressed with the stance, and RESTRAINT you have used with the amount and choice of acessories. More is not always better.......your's is just right. Chromodora wheels???
  7. Fuel in the float is the problem. Repair or replace the float. Readjust float level. Problem solved, no need to "rebuild".
  8. Pulling the choke lever back "closes" the choke, adding fuel to the mixture. At the same time, it increase curb idle speed.(like stepping on the gas pedal) This will compensate for a lean condition, GENERALY caused by a vacuum leak. While the engine is running with the choke on, go under the hood and listen for hissing/whistling/sucking noises. Most probably a vacuum leak. A vacuum leak can also can also be found by spraying carb cleaner strategicaly. Listen for an immediate increase/change in engine speed/noise. Good luck.
  9. A choke is CLOSED when it is ON. A choke is OPEN when it is OFF. The console lever is rearward when it is ON. The console lever is forward when it is OFF. The 260Z as built does not require the "holding" of the CHOKE in any postion. What exactly are you holding ON??? Note;refers to standard terminology...NOT necessarily enrichment circuits.
  10. Describe the CHOKE??? How about a picture??
  11. The pleasure was all mine, Pierre. I wish we had more time, so as to see your Z car, and chat. Too bad we don't live closer,(60 miles + tolls!!) Thank you for your generosity . I really enjoyed meeting you also. Please post a few pics of your car....Tommy
  12. Pm'd,.phone message left. Consider it taken,I'm in NJ but my sister in lives in Staten Island. Pick up truck at the ready. Thanks..A LOT.....Tommy
  13. No more iac (idle air contol valve). Drive by wire. Throttle position determines idle speed. (great for traction control) I don't even pay attention to customers with MPG concerns. (Toyota) RARELY does anyone DOCUMENT their mpg. The ECM's are very sophisticated, and would know if something was amiss. What has the weather and temperatures been like for the past several months? Have the fuels been reformulated for temperature changes? Has E85, or oxygenated fuels been in use?? Are you the only driver? More traffic than usual, Driving faster?? Do you now warm your car up on cold mornings,maybe to deice?? All these things ,and more, kill mpg.
  14. That's why they call it WONDER bread. Also very useful for plumbing repairs.
  15. The white car belongs in the.... There were enough CLOWNS involved.
  16. Flames SHOOTING out of the hood, That SCREAMS DATSUN,,,,,no mufflers needed
  17. That foam fiasco kind of looks like SPEED RACER'S MACH FIVE
  18. On air now.Channel 56 for me. A bit lame, but it's a DATSUN.
  19. You should consider making them. Cheap and easy
  20. Nice car/wheel combo....looks right... Ya got me thinking...... What suspension/spring set are you running???
  21. Maybe a Trail Blazer??? "An SS model was introduced for the 2006 model year. This was the first time a production SUV wore the Super Sport badge.[5] This TrailBlazer came standard with a 6.0 L LS2 V8 based on the same engine that comes standard in the 2005-2006 Pontiac GTO. The LS2 is rated at 395 hp (295 kW) with 400 lb·ft (540 N·m) of torque and can accelerate from 0 to 60 mph in an estimated 5.8 seconds with quarter mile times around 14.2 seconds at 100 mph (160.9 km/h). Other differences entail the use of a 4-speed automatic transmission, a cold air intake package, a 4.10 ratio limited slip rear differential, a ZQ8 sport suspension, specially designed front brakes with brake pads similar to those found on the Corvette, and optional all-wheel drive (via a Torsen T-3 center differential)."
  22. It sounds like overfueling/running rich. What engine/ fuel system do you have? What is the history on the car? Milage? Pictures?
