mas28O
Everything posted by mas28O
  1. Put some tires on you Z and you will be in the 10's. I know that Sergio's ls2 280z was making 409RWHP and ran 10.8@132. You might be able to run 134mph with your setup. Mike
  2. Take you ecm to Newtech in Hayward or Synergy in Freemont to have the ecu flashed. Mike
  3. ls1 MSD wires are the best to use. You are able to bend them out of the way of the headers. Mike
  4. Sure. I will be in Mexico later this year. I will have to see all of your projects. Mike
  5. Still building cars when I can, and playing Dady.. My new car Ls3 416
  6. You will have a low and hi fan wire in your engine harness. They should be labled for you. They will supply a ground to switch the relay. You will need to have the ecu flashed to a lower turn on temp for the fans. You could just use one relay and hook it up to the high speed on the fan. This will keep everything semple in your engine bay. Put your motor in, I want to hear it run. Mike
  7. Stan I had some problems with the Volvo relay sticking. They are not rated for the Taurus fan. You might want to run a 50amp relay, that is what I use now. Call JTR they have the 50 amp relays in stock. Mike
  8. I used a c6 oil pan on my RX7. The pan needs some work to fit. It might fit the z-car better.
  9. I think I have the old camber plates for your car. I will take a look next week. Mike
