SuperDan
Administrators
    15
Everything posted by SuperDan
  1. 180 downloads
    Here's the calc for Z internals and CR's and stuff.
  2. 162 downloads
    This is a solid model of a header flange for a P90 head. The file formats are STEP, and IGES. I can post in other formats if you would like, just PM me and I will save my file in something you can use. Also attached are some solid models for a header design. This isn't the one that I went with, but it still looks pretty cool. Note that the flange is attached upside down and uses the wrong bolt pattern for the middle flange (my mistake). Use the flange only file for flange dimensions. Contributed by:zguy36
  3. 13 downloads
    This is the adapter I used in this thread http://forums.hybridz.org/index.php?showtopic=81658 Contributed by: Derek
  4. 126 downloads
    Ground Control Camber Plate template as drawn and designed by Zzeal in his original thread here: http://forums.hybrid...ad.php?t=152601 I scanned in a copy of the template to .pdf format. I taped it to a standard 8 1/2 x 11 piece of paper and fed it through my nice top-feed scanner at work so that it wouldn't reduce or enlarge the size at all. I confirmed that the size doesn't change by printing it from Adobe Acrobat, you just want to make sure after clicking print that in the "page handling" section of the print window that under "page scaling" to select "none" and uncheck "auto-rotate and center" and it prints out perfectly 1-1 to the original template made by Zzeal. One more tip, you'll probably want to print it on the thickest paper your printer can handle so that when you cut it out it isn't super flimsy like it will be if you just use regular printer paper. Contributed by: junglist
  5. 92 downloads
    Derek's EDIS Install Instructions Contributed by:Derek
  6. 28 downloads
    This is from a company called engine parts plus. The pdf also includes dimensions and casting numbers for majority of the engine. Contributed by:turborust
  7. 35 downloads
    LS Block / Head / Cam Chart Contributed by:turborust
  8. 61 downloads
    1980ZX FSM Electrical Diagram Contributed by: LineC
  9. 32 downloads
    Full manual from tear down, inspection to reassembly. (pdf file) Contributed by:turborust
  10. 68 downloads
    This is a 23 page word doc with a write up on Ackerman, static toe, and Anti-Ackerman and their effects. Figures referenced in the text are at the very end of the document. Print and read might be the best way on this one. Contributed by: JMortensen
  11. 164 downloads
    Since I just finished a swap, I decided to document what I wired, and how. I was going to sell it on ebay but decided not to waste my time...lol. This is for wiring an 82-83 into a 75-78 as far as I can figure. Year models may vary so check your manual and wiring diagrams!!!!! I'M NOT LIABLE FOR DEATH AND DESTRUCTION. unless I choose to take credit. Option: You may omit the ZXT Fuel Pump Control Module by simply grounding the negative side of the fuel pump. Contributed by: cygnusx1
  12. 393 downloads
    ADAPTERS FOR 280ZX TURBO CV Shafts onto 280Z STUB AXLES & INNER FLANGES MAY WORK WITH 240Z INNER FLANGES TOO - CHECK DIMENSIONS! Contributed by cygnusx1
  13. 136 downloads
    Ron Tyler style diff mount in google sketchup
  14. Hmm. I cannot replicate this problem. I have tried it from work using IE8, from home using IE9 and another laptop using Chrome (Version 23.0.1271.64 m) and it all works fine.
  15. I did some database tuning last night that seems to have resolved this. If you are still seeing really slow post times please let me know. Thanks! Dan
  16. Hi All, Please reply to this post if you are having any issues with the new forum software. If you get any error messages please post that also as it helps alot. The one outstanding issue that I still know of is slowness when making new posts or using PM. After you hit "Post new Topic" it seems to just hang. Most of the time it will post but either takes forever or does not update the screen with the new information. I will be working on that later tonight. Thanks, Dan
  17. Should be fixed now. Thanks for the heads up.
  18. SuperDan
    SS style hood
    From the album: SuperDan
    SS style hood
  19. Sure, I suck at and hate doing graphics stuff.
  20. Yes, put a bolt in it. Here is a pic of my 72 with a 4L60E and were I cut to make clearence for the pan and servo. Also keep in mind, the cooler fittings are real close depending on the type of elbows you use and need clearencing too. http://forums.hybrid...11-img-5659jpg/
  21. Put me down for 1 of the next 14mm style kits you make.
