Everything posted by duder280z
	Agreed on the backward setup. I was just referring to the APS Audi setup that nizmozed was talking about, it must have a pump.
	No they won't work with the drain under pressure. They must be running a small scavenger pump like STS does. This quote is from the STS web sight " The oil is then scavenged from the turbocharger via an electric oil pump which returns the oil to the engines valve cover." A simple and effective solution to low the low mounting point oiling issue.
	It seems to me that this setup would have pretty short IC piping with a top mount IC. I've seen some front mounts that have some really long piping. Even if it is longer, the idea that the length of pipe reduces response is mostly a myth. The amount of piping would have to be a lot to really reduce the response time unless you're running a really small turbo and/or giant intake piping. Getting the air from point A to point B really has nothing to do with response time, it's how fast the system can get up to pressure. STS turbo has been running rear mount turbos for years with awesome results and the intake piping runs the full length of the car (and usually through an IC as well). They are pretty well known for great spool up times and good throttle response. On this setup I'd be more worried about the exhaust plumbing and the heat created by it. Just my $.02
	I wouldn't be so sure... With a way less than optimal setup, mine mashed through last winter way better than I expected! Great doughnuts and sideways action Good luck with the move!
	Wow, way to resurect an old one! I'm glad you did though, otherwise I may have never seen the only G-nose Z that I have ever liked! That thing is amazing
	Beautiful! Those rims are SICK! The fronts could use some center caps, but sick none the less I actually liked it better with the black accents, but to each their own...
	Yes the 240 bumpers will fit. I've never done it myself, but it is a very comon mod. I believe it just bolts up, might require drilling a hole or two. There are also aftermarket options, but the 240 bumpers are the best IMO.
	You could probably make one, but they are easily obtained and really cheap. I got a couple of 'em when I did mine, I figured they were so cheap, why not get a spare. Might have been $1or $2 each. I got mine at autozone. I wouldn't try to silicone, that could get real messy real quick.
	With mine, the valve and springs inside were pretty much shot. It wouldn't have sealed right no matter how clean it was. I don't think it's so much a design flaw, as stuff just getting worn out.
	It would be more involved, but I would think you could still plug up all the ports internally, then just bolt the outside stuff back on to pass the visual.
	You pretty much remove everything that can be removed without cutting. That includes the round part on the bottom and the section in the middle.
	Glad to hear your making progress! If there are no other major vacuum leaks, the BCDD delete will cure the RPM drop issue for sure. It is pretty obvious what it is when you take the TB off. It is a roundish, cylinderish sort of thing that looks a bit like a starter solenoid. It is also the only thing hanging off the bottom of the TB, so get a new TB gasket (should cost $1 or so) and just dig in. Don't be shy, anything that is on the under side of the TB that can be removed, goes. There will be 3 or 4 air bleed holes that will need to be plugged. Plug them with anything that will seal the hole and not come loose. I used screws and sealed them in with JB weld. I tapped the holes (that I could) with threads for the screws, but that is probably overkill. After that you will probably have to adjust the big idle screw on the top of the TB when you get it back on the car, but that's about it. My car idles at a perfect 800 RPM now. Before it would go all over the place, up to 1300.
	I had high and inconsistent idle issues till I just removed the BCDD. I had to take the TB off, remove the BCDD valve and plugged up all the holes with screws and JB weld. Idles great and consistent now.
	+1 For 2K you should be able to find a much more solid car. He's dreaming if he thinks that rust infested thing is worth that much. Typicaly on an old Z, if the rust is that bad on the surface, it's a total nightmare under the paint.
				hey guys need help with first 280z
duder280z replied to bryand2's topic in S30 Series - 240z, 260z, 280z
EFI bible. It's the most valuble tool for trouble shooting and general info for the efi system I've found. Try this link http://www.atlanticz.ca/zclub/techtips/efisystem/280zfuelinjectionbook.pdf It sounds cheesy, but I've had AMAZING results with the CRC product called "guaranteed to pass" fuel system cleaner. A shop I worked at had a shop truck that was made out of an old ambulance and it never passed emissions once in it's life. If you stood behind it while running it would make your eye's burn it ran so rich. The company pumped money into it every year trying to get it to pass, it never did. Until I told them to try guaranteed to pass, if it doesn't work you get your money back anyway (CRC actually does guarantee it). With that stuff it passed no problem. If you try it, follow the directions exactly though. It's totaly worth the $10 to try. Wow, that was more of a rant than intended, but really, it has worked for me on every old piece of crap I have tried it on. Oh, is your car origionaly a CA model? If so, it'd be a good idea to make sure the catalytic converter is still there and working properly. The rest of the country didn't get a cat from the factory, so we don't have to worry about it. -
	Um, yeah, if you have a 77 with the origional L28, it doesn't have an O2 sensor. My excuse for only getting 11-12.5mpg in my '77 is the turbo conversion done to it in '86, and 4.11:1 gears. It uses the origional computer and has band aids on it to richen it up. When I bought the car it got 9mpg, so I've made a little progress, but I really need to just go megasquirt. A rising rate fpr will help too....
				Still unsure about which engine swap to go
duder280z replied to RaDeuX's topic in S30 Series - 240z, 260z, 280z
While the KA is a decent motor, good luck producing 250hp without boost or a ton of money for NA performance. Converting a KA to boost can make a great running setup, but will most likely cost $2k+ (on top of the cost of the motor) to do properly. It would be cheaper to just do the SR swap in the first place. Regardless, it sounds like he's going with a L28ET which has been proven on this sight to be the best bang for the buck for that power level. My question for the OP is, does the $3k-5k budget figure include the price of the car itself? If so, good luck, it will be a hell of a learning experience. -
	I just got a truck (83 Nissan 4X4) to drive while I do some long overdue work on the Z. I've been DDing the truck for a few weeks, today I drove the Z for the first time since and WOW! Going from slow I4 with wide gear ratios to I6 turbo with low gears and closer ratios is drastic! My car really isn't that fast, but it feels like a rocket compared to the truck! Sure helps me appreciate it more when I drive it.
	I've seen the stock holsets run 30-35psi on the cummins no problem, plenty reliable. I think maybe the issue is related to higher exhaust temps more than boost pressure. It sure will be cool to see what Phil's car can do with a GT35R on it though!
	Dude, that looks friggin awesome. If you get a chance, some pics in the sun would be killer. What a great color! Very nice!
				Just got my 240z. pics inside
duder280z replied to Jaspendlove's topic in S30 Series - 240z, 260z, 280z
The shifter looks like the pickup truck shifter mod, except they forgot to cut the top off. Pretty goofy the way it is now. Looks like you got a pretty sweet deal though, nice paint. -
				the devil inZide (the longest z story worth reading)
duder280z replied to Negafen's topic in S30 Series - 240z, 260z, 280z
zspecialties.com -
	It shouldn't make a noticable difference, leave it as is. One thing to think about though, is that foam filters don't breath nearly as well as cotton gauze(K&N or AFE) cone filters do, especially when dirty. I actually have moved my lisence plate to cover mine up, after this picture was taken, so that it doesn't get dooshed in the rain (western Washington). It still sucks cold air so it didn't make a difference.
				Armand's SR20DET 1971 Series 1 240Z (Pics)
duder280z replied to Armand's topic in S30 Series - 240z, 260z, 280z
In my experience everything I have ever said DOES get used against me. I've tried the honesty thing, only worked the very first time I got pulled over and should have been arrested. He let me go that time, but ever since honesty has only helped them screw me in court. Kudos to you though for getting away with it. Sweet ride by the way, very nice. -
If you need to get anything for an old Z car in western WA your best bet is Z Specialties in snohomish. (360)668-2979 or (206)363-3577 Oliver is the specialist/owner and he really knows his stuff. Good luck man, I hope to hear a happy ending to this nightmare.
