                Posts18
Everything posted by loganpratt22
	Hey, I was wondering if you still had the f54 block? I need a set of main caps... Text me if you have those. (443) 844-7041 -Josh
	Hey, I have a 1974.5 260z in Charles Town, WV if you're still interested..? Josh
	From the album: Harness and ECU Harness 3
	From the album: Harness and ECU Harness 2
	From the album: Harness and ECU ECU 2
	I have both of these for sale if you're still looking. PM me. -Josh
- 1 reply
		- ecu
- engine harness
					(and 4 more)
					Tagged with:
	I have an extra 240 tb if you're still looking. PM me
	I just pulled my SU carbs today and will ship if you're still looking. PM me if you're interested.
	  WTB: Engine (And/Or) Engine Wiring Harnessloganpratt22 replied to TheDeadZed's topic in Parts Wanted I have a complete wiring harness from an 83 zxt if you're still looking. I also have a couple ECUs if you need one of those as well. PM me.
	  Wanted- 280x dizzy, collar and plate with o-ringloganpratt22 replied to nitekillerz's topic in Parts Wanted I have this whole setup from my 260z if you're still looking. PM me. (Los Angeles)
	I have an E88 head from my 260z here in Los Angeles. PM me if you're still interested.
	I have one if you're still interested. PM me.
	I have a set of SU carbs. I just blew the head gasket and am finally going to swap the L28ET in. Carbs are in excellent condition. PM me if you're interested.
	I have a short shifter if you need one... PM me.
	  240 vs 280 strut insulatorsloganpratt22 replied to stav2201's topic in Brakes, Wheels, Suspension and Chassis Does this only work on the rear? What mods/swaps can I use to equally lower the front if I swap the 240 strut insulators onto the rear?
	  Advise on suspension neededloganpratt22 replied to docjim's topic in Brakes, Wheels, Suspension and Chassis I have a set of stock 260Z (1974.5) springs that I am replacing with Eibachs if you're interest in them. They're on the car currently so I can send pics of the ride height so you can see that they're still tip-top.
	  L28ET Plastigauge Main Bearing Clearancesloganpratt22 replied to loganpratt22's topic in Nissan L6 Forum Thank you!
- 2 replies
		- Plastigauge
- Main Bearing
					(and 6 more)
					Tagged with:
	Can anyone tell me the acceptable main bearing clearance for my L28ET build? (F54 block) I have a Chilton Guide and it is definitely mentioned to check that they are correct, but the actual acceptable clearance measurements are not listed. (2nd error/omission that I have found so far...) Anyone help please?
- 2 replies
		- Plastigauge
- Main Bearing
					(and 6 more)
					Tagged with:
	  L28ET Rod Oil Squirters and Piston Alignmentloganpratt22 replied to loganpratt22's topic in Nissan L6 Forum Thanks Mr. Bob! I have the Chilton Guide, but the diagram (3-77 Fig. 202) is a misprint... It doesn't have the identification markings as its label says it should! I figured it would be the same arrangement as 84-88 model, but wanted to check here to be sure! Thanks!
