Spooler
Everything posted by Spooler
AZC vs Datsun parts LLC big brake kit
Spooler replied to ECUAdam's topic in Brakes, Wheels, Suspension and Chassis
I am running the Imagine wheels from Motorsport auto 17" rims. 17" is a must for the bigger rotors. -
I have put over 70,000 miles on the AZC Willwood brake kit front and rear. The only issue I had daily driving was keeping the brakes warm when cold and rainy. I had to make sure I tapped them a couple of times on the interstate to keep them warm. -
So I heard these cars are rated to 27mpg highway?
Spooler replied to osirus9's topic in S30 Series - 240z, 260z, 280z
I do not see what year car you have. Anyhoo, If you have the 5 speed tranny, you should get 28mpg on the highway no matter how you drive. Most common part failure that would cause this issue is the head temp sensor or Head temp sensor harness. It depends on what year you have to where the head temp sensor is located. Early year models are in the thermostat housing and the older year models are between plug 5 and 6 on the head, passenger side. Another thing to check is you injector harnesses. If they are corroded and green, get some replacements ends and splice them in.- 59 replies
I put on my Lonewolf intake, and 90mm TB
Spooler replied to big-phil's topic in Turbo / Supercharger
Funny, after that introduction to the " I am at 6:10 min. in I figured you would be on it a little harder......LOL At the end I saw why, the old blue light special. -
How much to weld in new floor pans and frame rails
Spooler replied to Negligence's topic in S30 Series - 240z, 260z, 280z
I had both of mine done for 1900. All hand made to look factory with new frame rails, also custom made. After he was done with my car, he said the price was going up!!!! LOL -
It could be the Air regulator, 7th injector (cold start injector), head temp sensor, fuel pressure regulator, or you may have a vaccum leak somewhere. Had this happen before but it has been a while. Pull the plugs, are they gas soaked or fouled?
Rear Wheel Bearing Spacers, need help !!!!!!!
Spooler replied to snarpee's topic in Brakes, Wheels, Suspension and Chassis
What kind of car you got????? 240, 260,280?????? -
260Z seatbelt interlock. Defeat
Spooler replied to Pharaohabq's topic in S30 Series - 240z, 260z, 280z
Just went through my system today. I blew my right knee out about eight months ago and finally recovering from knee surgery on Oct. 16. The link to the Datsun manuals were Key. Everything I needed was in the PDF file. Think I finally have it squared away, we shall see. Bad connection on C5. Dielectric grease and she should be good to go. -
Phil, you got it squared away yet? Waiting to hear it purrrr through the gears.
Wilwood versus 4x4 vented .. pro's vs con's
Spooler replied to proxlamus©'s topic in Brakes, Wheels, Suspension and Chassis
Buy what you can afford. Overkill on brakes is a good thing. I had the solid rotors and Toyota 4x4 calipers up front with the 280zx rotors, calipers, etc. on the back with a adjustable proportioning valve. I hated that setup. This time I just went for the gusto and bought the Willwood setup and used the upgraded MC. Haven't looked back since and enjoying the setup. The vented fronts and 240sx rears may be real good. I just didn't want to take a chance on that setup. I am hard on brakes...LOL -
I have ran my liquid cooled turbo through the heater hoses for about 10 years, same turbo. The only thing you will need to buy is an H pipe adaptor so if your heater valve is off your coolant will still flow to the turbo.
That is exactly what they used it for. The bike I used to own had one. It was a Honda CBR 954RR.
Cool, Thanks. -
Yes I have one. I see the relay in passenger side kickpannel. I am almost sure mine has been disabled. The problem is I get a low voltage at the starter trigger wire (10.5 volts) hence the no start. If they make the relay stay on all the time I may have a bad contact on the relay. I really need a Datsun wiring diagram. The place that I worked as a tech (Nissan dealer) threw there old Datsun manuals away cause someone deceided to clean up.... go figure.... Even my older fellow Tech's couldn't believe it. -
I have this intermittent no start on my 1975 280z. Anybody have the wire colors to check. My red pushbutton switch is gone, hence the screwdriver in the car...LOL I think i see where it used to go on the passenger fenderwell, I am just not sure. Link to the book would be great. -
Good rule! I won't buy from someone without a high post count. I know I don't have alot of posts compaired to some, but I will get there.
Removed fuel rail, questions about injectors...
Spooler replied to Challenger's topic in Fuel Delivery
Last time I tried to pop a couple of these caps off when they did come off they cracked into pieces in my hand.... 6 new injectors later all was well. -
Hmmmm, Nissan dosen't have the turbo injectors anymore??? I got a new set of 6 from them a couple of years ago. -
It sounds like the fuel injection relay has gone out. You can get one from zcarparts.com.
Are your plugs wet with gas???????? If not, you have a fueling issue. This sure sounds like a fuel pump took a dump. Another thing. If your plugs are fowled with gas I have had a fuel pressure regulator on top of the fuel rail stick, flooding the car out. Pull the vaccum hose off and tap on the regulator. If you can get it running again then that is what is wrong. Not a common issue but it does happen 1/100 times.
Yeap, those numbers look good and are not too far off from each other.
Nissan 5spd trans Vs. BorgWarner t-5
Spooler replied to john kosmatka's topic in Turbo / Supercharger
Nissan 5 speed better than the T5. Now that is a joke. I roached 4 NA 5 speed trannies. Parked the car and found me a T-5. I have had no other issues since. The NA Nissan trannies normally just flat out explode at the worst possible time. Yes, the Nissan trannies shift great, etc. They just won't hold up. That's why I went through so many. 7 psi of boost and the NA tranny was fine. I turned up the boost to 12 psi and it was all over but the repair bill so to speak...LOL -
I ran mine like that for 5 years.... No issues. I have since installed the oil cooler adaptor and cooler.
The bottom one is brown in color. This looks like a stock turbo injector. The top one is not a Nissan injector. Not sure what car it is for. -
Locking lugs / lost key
Spooler replied to 2eighTZ4me's topic in Brakes, Wheels, Suspension and Chassis
If that dosen't work, drill it out, getting bigger and bigger. Place the car on the ground with a 2x4 underneath the wheel, lug nut on the bottom, and lift up( with only that one lug nut on). It will snap the stud. I have had to do that before for a customers Pathfinder that the stud started spinning. Worked like a charm. I acutally just kicked the tire at the top with my foot and snapola....
