wayverippah
Everything posted by wayverippah
Hi all, I'm looking for a single 280z front hub. Let me know what you got!! Thanks
Modifyed Miata power steering rack for 240Z
wayverippah replied to BoonZ's topic in Brakes, Wheels, Suspension and Chassis
Kudos to you and your work! Just curious... Why not just grab a Subaru Forester rack and Celica outer tie rods? Pretty much bolt in.- 13 replies
- bump steer
- 260
(and 4 more)
Tagged with:
Kameari makes those I think
Ah I misunderstood. I thought the OP was staying around stock power levels. After looking at the swap links you provided, I still think it's going to cost the same (if not more) than the tried and true L / RB / LS swaps already done... Hmm... Thinking about getting an Oddessy now Interested to see how this turns out!
I don't want to poo poo over your idea, as I admire the ambition and thought behind your swap. But if you're only going to be in the 200-270 range, why not just stick with the L28? You can get it in that range for not too much penny (which is the reason you wanted to go with the Honda vs the other Jap brands right?). You can also get a clean VQ35 for ~700 with the added benefit of having other outfits like McKinney doing all of the fab work for you.
I used a RestoMod Air system. Has a more modern feel to it than the VintageAir products.
If you rivet it, be sure to use good seam sealer and rust prevention. That transmission tunnel will see a decent amount of water. Best bet would be to tig a patch over it.
77 Datsun 280z Engine: 6.2 LS3 N/A (cammed) Transmission: T56 Magnum Rear end ratio: 4.11:1 (R200H From an R34) Additional info: Shorties, Borla ATAK mufflers Observed fuel economy: 26mpg in 6th crusing at 70 (it's a shame I never drive it that slow...) ~18 in town I had a turbo'd 5.3 LM7 in it prior and had roughly the same MPG.
Twin turbo Cummins 4bt. Fits right in!
TheRetroGarage - 240Z - SBC - TwinVGT
wayverippah replied to theretrogarage's topic in S30 Series - 240z, 260z, 280z
I'd grab a junkyard 5.3 for a few hundred bucks and pop the turbos on it. They are built like tanks and plentiful. The stock internals and heads will get you to 600 easy. I had that setup until I switched to an ls3. Another thing to keep in mind is that with your hp/torque goals, you're going to have to upgrade your rear end. The diff may or may not hold up, but your stub axles and half shafts are going to shred to pieces. I had Wolf Creek CV's, Whitehead stubs, and an open r200 and they held up to the 600hp. You'll need to convert the gas tank to EFI. If your caging the car, then you'd probably be more interested throwing in a fuel cell. Good luck with your build!!- 12 replies
- TheRetroGarage
- SBC
(and 2 more)
Tagged with:
78 280z RoadKill Rotsun 2.0
wayverippah replied to rajien2's topic in Gen I & II Chevy V8 Tech Board
If its a 77, you shouldn't need to swap out the diff (it should have an R200 in it). The weak point will be the half shafts and stub axles. A 350 will fit no problem. Not sure if the mounts will work, but GM has always been good about making their parts interchangeable. You'll need engine or boost management of some sort if you're going to turbo though (even with a carb). There is info in the v8 section for getting it installed, and I would head over to LS1tech for info on carb turbo setups. -
I grabbed a set of fiberglass fenders from a junkyard and they fit perfectly. (Even better than the original fenders IMO). The mounting holes had been cracked and damaged after removal, but wasn't that difficult to repair it. I've found that the junkyards in the northwest & northeast have a lot of fiberglass fenders... Probably because of the rain...
77 280z.
ACDelco 45A7010 fit mine perfectly.
What are you using for a diff/rear end?
wayverippah replied to VSnakeByteV's topic in Gen I & II Chevy V8 Tech Board
I've got a cammed LS6 in mine. Don't know which Z you have, but an R200 diff will handle the torque perfectly fine. The weak point is the half shafts. I personally went with the Wolf Creek CV setup and the Techno Toy Tuning rear Wilwood brake conversion and they are fantastic (and relatively easy to install). Check the FAQ's... All of the information you seek is already there. -
If you wouldn't mind sending me some pics that would be great. Tried to PM you but I guess you're full Thanks!!
Looking for a set of 240z headlight buckets in good condition. Let me know what you got, Thanks!!
Different front hubs?
wayverippah replied to wayverippah's topic in Brakes, Wheels, Suspension and Chassis
Yeah same car. They thread in fine, just need to drill out the rotors to get it to fit. Might find a used hub to replace it with... Thanks for the info guys!! -
Hi all. I just pulled my front struts off of my 77 280z to do a coilover install, and found that the bolts connecting the hubs to the rotors are different between the driver and passenger side. The hubs are identical in measurements minus the bolt size. Is this normal or am I missing something?
Also looking for a good body shop in the DFW area... (As are many others). Most of the classic body shops in our area won't touch a Z because it's an import, and the other places just aren't up to standards.
I'm looking for a 240z front bumper. it doesn't matter what material it's made of, as long as it's in decent condition. Thanks!!
Anyone have an idea where to buy just the brackets for the front sway bar? I can find bushings all day long, but not brackets... Thanks!!
I'm looking for both drivers and passenger side fenders for a 240z/260z/280z. I don't mind some surface rust, but definitely not cancerous. Let me know what you got, thanks!!
