Everything posted by pallnet
You will have to get a different flasher. They make them that are direct replacement. The LEDs do not draw enough current to pull the flasher and make it flash. Most auto places carry the flasher you need. I want to say that I bought mine years ago from pep-boys. good luck pallnet
Sir Wrong section. http://forums.hybridz.org/index.php/forum/73-parts-wanted/ That is where you want to be. pallnet
UPDATE: All rails paid for before todays date were shipped and either arriving or in route. Thanks fellas!! I have (3) barbed L28 fuel rails with cold start on my bench that are almost completed. I will be running off (3) 11mm L28 fuel rails later this week. A gauge can be added to any fuel rail order. I currently do not have complete 11mm O-ring seal kits in stock so please keep that in mind. I will update whem this changes. Emial me with your questions and as always I will do my best to help your fuel rail needs. pallnet@hotmail.com
Sir Iwill be around, just hit me up by email. thanks pallnet
Sir I just ran out of 11mm injector seal kits but they are on order. for a little while there I ran a special where the seals were included with a rail purchase. I will have more in about a week. All rails i had for sale recently have been sold. I will be in the shop this weekend if the metal arrives by Friday. My plans are to make some barbed rails first then 11mm rails right after that. I will post what I have for sale when they are made. Thanks pallnet
Sir Barbed rails are basically replacements for the stock fuel rail. It cleans the intake up quite a bit and makes it much easier for future service work. I include a cold start port and fittings so you can retain the cold start injector if you have one. All mounting hardware, brackets and fittings are included. You will have to relocate your fuel pressure regulator and I highly recommend replacing fuel hoses, fuel filter, injector seals and fuel clamps while your replacing the fuel rail. Thanks pallnet
Tony Just let me know when you are home and about to ship them. I already knew this project was special and couldn't be rushed. I hope you have a safe trip back. Sit tight George, you will love the finished product.. Thanks pallnet
Sir "3: pallnet or equivalent 11mm Supra injector Fuel rail for the L series." I have this. Email me. pallnet@hotmail.com
UPDATE: I'm back in the shop. I made a bunch of barb, 11mm and 14mm L28 fuel rails the past few days. I shipped a bunch of them but I have a few left that were not for anyone. (2)Barbed rails with the cold start feature. (2)14mm Rails with a gauge port in each. (1)11mm Rail. I can add a gauge port and a liquid filled black faced gauge to any of these for a small additional charge. I also have injector seal kits in stock. Email me if I can help you with your needs. pallnet@hotmail.com
http://forums.hybridz.org/index.php/topic/99098-pallnet-fuel-rails/ I can make what you need. Thanks pallnet@hotmail.com
UPDATE: Good news, the pipe is repaired and the hole is filled. This means I an back in the shop building parts. I will post a few here in my next post. Thanks pallnet
UPDATE: Not a good one but I will have it sorted this week if the weather is not against me. A pipe busted under our the slab of our home. My friend and I started by pulling up the hedges and bushes infront of the house. Then it has been a "dig fest" this whole weekend, I'm hurting in places I didn't even know I had. We found the pipe that is split about 6-8 feet under the foundation. Tomorrow after I get off of work and if the weather is on our side we will be cutting the pipe and putting a new section but the pipe is cast iron so it will be some work. However If the weather is crap then I will be in the shop finishing up the rails I have almost completed. Thanks pallnet
phillip_20774 Sir Your order is almost ready to ship. Tomorrow's cleanup and packing then it's ready to be dropped off at the shipper. Thanks pallnet
Sir I don't mind answering questions, info is free. I have machined -8 and even -10 barbed rails for people in the past. The larger bore acts like a surge tank where it holds more fuel directly above the injectors. Most people who buy the larger bored rail are doing so for big power builds and the last thing they want is to run lean, the larger bored rail is only part of the equasion. -6 Is large enough for a stock setup, there is no need to spend the extra $ for the larger bore unless you're doing so for a certain look. I am a certified automotive master tech now and to be honest with you, I wish every car had a fuel pressure gauge on it. That would make my job a little easier. It is a needed tool for tuneing and a very valued tool if you ever have to deal with any kind of strange running condition that could be fuel related. At the moment I don't have any rails that are ready to ship, they sold. I do have supplies on hand to make more barbed, 11mm and 14mm O-ringed rails. I'm having a busy week at work so I will start machineing more this weekend. I do have a custom rail on my bench right now that was shipped to me by a very well known member here on hybridZ. The goal is to duplicate the rail, remake the brackets and send the copy off to our mutual friend in England. That's what's going on at the moment. I'm replying to PM's now. For some reason I didn't get emails letting me know I have PM's. I will check more often from this point on. Thanks pallnet
UPDATE: I have a few different styles of fuel rail (11mm, 14mm and barb) in different stages of completion sitting on my bench. Email or PM me if you need one, I'm working package deals ..... I took a break from working on rails this past week so that I could finish repairing my pirogue but I'm back to the other side of the shop now. Thanks pallnet
hello. i joined just to ask about ur l28 into s13 swap. ive started doing the swap and ran into clearance issues on the oil pan and the crossmember. do you have a writeup? sorry i dont know how forums work yet. any help is appreciated keep up the good work.
Sir They are getting harder to find now days. If you look hard enough you might find a whole car in someone's yard. The cranks used to go for around $200.00-$300.00 some time back. Good luck with your search, they are rare. I hope you have a nice independence day, it's not just a holiday. Thanks pallnet
Sir Yes the $125.00 shipped for an 11mm rail is correct but I'm no longer offering the free gauge hole by itself although the threaded hole is free with the purchase of a gauge. However I am offering up free 6AN end fittings with each of the 11mm rails from this batch. Email me so I can tell you what to put in your paypal transfer. Thanks pallnet@hotmail.com
Update: I have (1)barbed rail and (2)14mm rails still for sale. I'm machineing (3)11mm rails early this week. Email or PM me if you're in the market for a new custom fuel rail. BTW: if anyone is keeping up with my war with the local crawfish population. Today we hauled in a good bit. I had my little helper with me. I was useing traps and nets but she liked useing a stick/string and bait. I gave her (6)nets to run and she did great. I can't wait to teach her how to make parts. Thanks pallnet
Tony Dude it's too late, I put a major dent in the crawfish population here in my area. I'm going Saturday morning and what I catch is going in a washtube with a fishtank bubbler. I have plans of going Sunday as well but to a different area and boil them that evening for some of the family. My traps work great. I would try to raise them but we have snakes, birds, cats and coons that would get in there and kill my crop. I know, it's all food.... I'm glad to be back in the game. I made a few rails to use that 460cc injector but I never realy tooled everything completely to make more then a few. Later pallnet
Sir I have a 14mm rail with a gauge hole tapped in the side that's just waiting to be boxed in your name. I made it in a batch a few weeks back when I ran the gauge hole as a freebe so I will still honor that. Do you need a gauge? I can add one in the order for the cost of the gauge. Email me for the info. Some info for the other guys. Sit tight fellas, I will be turning out some more 11mm rails shortly, I had to bump them back a few days to a week. They're demanding that I spend even more time at work(Toyota) right now. Thanks pallnet
UPDATE: (1)Barbed rail is left from this batch. Rails will be shipping out early this week. Thanks pallnet
UPDATE: Ok, (2)barbed rails are left from this batch. I will be running 11mm rails early this week coming, I will post when they are just about ready. I have (2)14mm rails on the shelf if anyone needs one. Both have a gauge free hole, the gauge itself is extra. Thanks pallnet
UPDATE: I have (4)barbed rails with cold start that will be completed by Saturday and ready to ship out after then. I do have black faced gauge in stock and one can be added to the rail order. For those that don't know, this is a stock type of replacement fuel rail for turbo and non turbo "L" EFI engines. It reuses your stock injectors. Barbed rail with cold start, fittings, custom bent brackets, stainless hardware(no gauge and no hole). $155.00ea Insured and shipped in the USA. $175.00ea Insured and shipped outside the USA. Or Barbed rail with cold start port, fittings, custom bent brackets, stainless hardware (1)black faced liquid filled gauge. $175.00ea Insured and shipped outside the USA. $205.00 Insured and shipped outside the USA. For this sale of 4 rails I will include a set of 6AN end fittings and injector seals for FREE!!! Email me to claim your custom fuel rail. pallnet@hotmail.com Thanks!
Sirs I will produce a few barbed rails early this week and then some 11mm rails will follow. Yes I have gauges, some seal kits are here and more seal kits will be here this week. I love this time of the year here in the south, someone is always cooking something big and good for dinner. My good friend Howard and his wife called my wife and I over to theyre place because Friday while I was working all day, he was out catching blue crabs (he caught over 6 dozen), he iced them down and this evening we ate like kings... Early tomorrow morning Howard and I will be takeing the kids to meetup with another friend and some of his family. There's a large drainage canal that's full of fat crawfish that has our name on it. I own 25 crawfish traps and 24 crawfish nets, that's not counting what the other guys have. BTW: If you need deep water crawfish traps, I make my own so I would gladly make and sell them to you. After all that I will be back on rails. Thanks fellas
