at-jefft
Everything posted by at-jefft
  1. EDIT: Don't Use Showcars-bodyparts.com
  2. Ya, I spent probably close to an hr with a propane torch and it did almost nothing.
  3. What I had to do with my S30 suspension was put bolt the hub to the spare tire. Have someone stand on the spare tire and them put all my weight on the pipe wrench on the gland nut. Also you gotta make sure the hub/ suspension doesn't turn. PB Blaster is your friend. Good Luck
  4. Yup, Where are located?
  5. haha, Guessing by the email its 280zForce / Justin Hodges. Edit: Yup, the link to photobucket uses the 280zforce username.
  6. I think its a Bricklin http://en.wikipedia.org/wiki/Bricklin_SV-1 (fun fact, They seem to have used 240z tail lights)
  7. Z-Zap is the term you can use to search http://www.xenonz31.com/s30/zzap.html
  8. I don't know about the struts #. I think they are different numbers actually. I'm not sure that all 4 would fit in reverse.
  9. The tokico springs should say F and R on them after the part #.
  10. 74-75(possibly 76 look in the chassis sticky) use the C-pillar mounted belts. I don't know if you can mount the strut mounted on the c-pillars.
  11. Swapping quarter panels shouldn't be a problem. The only difference is that everything after early 260z don't have side cut outs for bumpers. I'm nearly positive its only a cosmetic difference and shouldn't be a problem.
  12. Hey Everyone, So yesterday I noticed that my headlights were not working(highs and lows). My side markers and turn signals still work though. BTW its a 260z I pulled a headlight and used a test light to see if there was power going to headlight. All 3 wires in the connector had current(no ground?). This made me think that the bulbs were burnt out(I had left my lights on a week ago). I got a new one from vatozone and no luck. So I am stumped. I have power to the bulb but no light? How can that be? Thanks, Jeff
  13. Well this sheds light on why the PO of my car felt the need to spray paint over perfectly good paint on my hood/hatch. probably would have looked decent if it was actually automotive paint and wasn't about as rough as 80grit.
  14. Its not completely on on side but I probably could have done that one better.
  15. Alright, so today I decided to scrap fixing the spare tire well. I would have to replace at least half of it with new metal so I'll be looking for a better one to weld in. I cut two pieces of 20ga to practice with. I butted them up against each other and welded them up. They were clean and as some points I turned the voltage up a notch. Pics: (Used a 60grit flapper disc after cutting the excess off with a cutoff disc. (Penetration and when I changed the settings) (Penetration where I used my normal settings)
  16. Ok, from what I gathered from the last 3 posts, I'm going to start chamfering the joints, turn up the voltage, and clean the workpieces. I'll post my results after I do some work tomorrow. Thanks everyone.
