at-jefft
Everything posted by at-jefft
  1. O Jeez. Funny and horrifying at the same time. Keep up the good work.
  2. I just got a bfh (Big F***ing Hammer) and that seemed to do the trick. PS Have fun with the spindle pins!
  3. Ya, When the ignition or timing is off my carbs sneeze at me. Have you checked your timing? (with a timing light)
  4. I don't know why, but I did have to make noticeable adjustments from cold to hot settings.
  5. is that all on the stock bottom end?
  6. If it is leaning out on accelleration, then turning the mixture knobs on the bottom will work.
  7. Glad nobody was hurt. Also interested in your brake situation.
  8. I have some of the bullet style mirrors I will sell you, they are in chrome though. There is a thread that gives exact measurements on where to install. I should come up in a search pretty quick
  9. tack cloths? Also where are you buying this from?
  10. Aziza- am I crazy or do you only have 3 lugs on your front wheel?
  11. Just covering the basics here: but did you bleed the m/c?
  12. http://cgi.ebay.com/ebaymotors/jdm-style-fender-mirrors-datsun-240z-260z-280z-etc_W0QQcmdZViewItemQQhashZitem20ae5b5102QQitemZ140364173570QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
  13. at-jefft
    flame throwers
    Ive seen kits that disrupt the spark to a plug wire, and then ignites the unburned fuel via a sparkplug in the exhaust. Supposedly, when the fuel is unburned in the cylinder, it strips oil from the cylinder wall.
  14. I'm going to be replacing my oil pressure sender tomorrow, because I don't get a reading on my gauge. I looked in the fsm and It says to reinstall using conductive sealer on the threads. What is conductive sealer? I know dielectric grease is non-conductive so I'm lost on this. Also where can I get replacement nipple connectors? Right now my temp sender has the wire wrapped around it and my oil sender has some sort of spade connector. Thanks Jeff
  15. The fuel gauge in my 260z (early) doesn't work. I'm looking for a working condition gauge to replace it. I believe the 280 gauges with the volt portion will work, correct me if I'm wrong. Thanks, Jeff It will have to be shipped to 60126
  16. thanks for posting. Its always interesting to see what people make with simple mods.
