Thanks RebekahsZ. Where did you end up getting your bleeder from? I was looking at purchasing the ones offered by speedway motors but doesnt appear to be a speed bleeder.
So I'm ordering the last bits needed to get the motor in and was going some research on the clutch line. I have seen people use anywhere from a 32 to a 48 inch clutch line. What's the shortest length I can order and still be safe? I tried looking up part numbers that were provided in some threads for the 48 incher but it appears that it no longer exists. I'm about to order this one http://www.summitracing.com/parts/rus-655100 but I am not 100% sure that it will be long enough. Thanks in advance!
Why an ls2 intake? I've read that even though the ls2 is 90mm, the ls6 is still superior in an NA application and you won't see much of a difference in a boosted application.
David, I can also vouch for Rags. He can probably do the swap in his sleep. If you are looking for a reasonably priced ls1/t56 I may have one for sale next week.
Thanks for the picture. I guess the only way it will work is by making the radiator shorter. Where did you get your radiator? I'm looking for a good radiator with the filler neck on the side.
Hi Craig. Actually your pictures you emailed me is what caused me to think of trying this. I'm thinking I might be able to do the same without having to modify the rad support and instead going under it by getting a shorter radiator and/or tilting the radiator back. Thoughts? I'm not there yet in my build but I'm hoping to be there soon.
Jeff
Has anyone tried tilting the radiator back/down and snaking an intake straight over the radiator with something like the corvette K&N intake? I'm no where near that in my build but I do plan to try this. I'm not too crazy about having three 90 degree bends in my intake.
Ok thanks guys! I don't need to worry about the rears as I bought the whole T3 rear end assembly so they come assembled already. I have camber plates in the front but not in the rear. I wonder if I'll have a problem with lining the front and rear up but I doubt it.
