Exposed
    15
Everything posted by Exposed
  1. @Greeko, Thanks, and I ended up grabbing the intercooler, rad and fan locally. I'll have to grab the tubing for the intercooler from somewhere else though as no one here seems to carry anything. I found some time to mount things up recently and tested out some paint in the engine bay.
  2. Don't mean to hijack the thread but would love a thread or some guidance on how to build your own wiring harness. The ECU pin outs are so confusing
  3. The engine looks good. My personal opinion is save your money and just build your own mounts. Even if you can't weld and have to get someone to weld them up for you it'll still be cheaper. It isn't hard to do, just my two cents though.
  4. would like to see more pictures of the car, loving the exhaust though.
  5. Welcome to the forums, I bought my 1JZ from Montreal in Canada and had it shipped to me. All I did was google and research the company, I called each one that peaked my interest and asked questions. If your satisfied with how they answered your questions check for reviews on them. Just don't jump into buying the first thing you see. As far as everyone else I'm not to sure but a quick google search pulls up a lot of results on venders. I ended up buying a used harness off of someone on ebay and I'll have to wire it myself to the Datsun, from what I've seen it seems to be split between spending the money and buying a new harness or using the one that comes with the engine and wiring it up yourself. In my opinion it comes down to what do you think is reasonable for a wiring harness and are you willing to pay it. There are ECU pinouts everywhere online for 2JZ & 1JZ motors it just takes time, patience and some research if you aren't familiar with wiring everyone together. Again a quick google search will bring up several different harness manufacturers some require your core harness and some don't, pricing usually reflects that. Hopefully someone else can chime in about the single turbo manifold. A lot of the guys posting build journals have some good information check it out, from what I've seen most are willing to help you out with any questions you may have.
  6. that front lip looks great, really liking it. @Dat73z I was thinking it looks a bit off as well, I would like to see some more pictures. On the pictures you posted it looks like the lip has a bit of a peak in the middle while the MSA one doesn't. I could be wrong though, please keep us informed if you do find out anymore information on this.
  7. So will I was waiting for the new parts I had order I end up pulling my dash. Bad news is the dash is cracked, luckily its only one small one so I might just reupholster it. I'm currently planning on switching up the existing gauges. The speedo and tach is 5" and the other guages are 2 5/8" or 52mm if I'm not mistaken. I'm not set on any particular brand of gauges as of right now but was thinking of getting something with a dial for my speedo and tach and digital for my other gauges, was thinking of getting something with a white or purple light to it. Does anyone have any recommendations or reviews on products they've used before? Came in to work today to find my intercooler has finally arrived, the core size is 12.5"x 22"x 3.5". Now im just waiting on my rad and fan which should be coming in tomorrow morning.
  8. Found some time over the weekend to drop the engine and transmission into the car. I had be reading up on different mounts that were for sale (not many I might add) that wouldn't break the bank. I ended up fabricating my motor and transmission mounts and got them welded up. Just a heads up to someone planning a swap like this, it isn't to hard to make your own mounts and it's really cheap even if you have to pay a professional welder to weld everything up for you. Placed an order on a radiator and an intercooler and now its a waiting game.
  9. @DriftBoss, they dont sell any for an automatic and I'd prefer not to mess around with trying to swap something like that from a manual to automatic. I was going to try DrTweak and see if he would do it. On a side note, I was checking out your build and saw you brought your drive shaft to a shop. Did they just extend it for you or did the splines need to be swapped out for something else? @dexter72, I've gathered a bunch of diagrams from there thanks for the suggestion though. I was able to find a cheap used engine bay wiring harness for an automatic on ebay for a couple hundred so i snatched that up quickly. When wiring your interior (dash, and all that other fun stuff) is there a main connection typically from your battery to your fuse box then from your fuse box to the other stuff or does it get routed from one of the existing wires from the ecu connection? The good news is I'm repairing some panels on the existing car where there was rust and I'll be doing a mock up for the motor and transmission mount within the next couple of days.
  10. Finally got around to taking some pictures. I'll post some pictures of the cut wires on the harness, any info on where they go would be awesome. In the mean time i guess I'll be going through other forums/ build threads and seeing if anyone is in the same boat.
  11. Thanks for the responses, I've got in contact with wiring specialties already they said they don't make them for auto's.
  12. Hi everyone, I recently purchased a '72 240z and was able to grab a 1jz out of a soarer with an automatic transmission localy for relatively cheap. With that being said I'll be posting pictures and asking questions as time goes on. So what better time to ask than the present. Pictures will follow shortly. Has anyone been able to use an automatic transmission on there 240 1jz build, and if so how did you make the connection with the wiring harness? I was hoping to get a complete wiring harness but can't find a supplier who makes them for automatic transmissions.
  13. killer build, I cant wait to get my engine to start. I might have missed it but what did you do for a wiring harness and how was it to install if you bought a premanufactured one?
