zboi
    4
Everything posted by zboi
  1. You don't need to change anything internally. Typically you would add some top ring gap on a turbo motor, but these motors already have plenty. My build is probably the cheapest high tech option possible, and I am very happy with the turbo's response and power. Back in the day it would be simply swapping some junkyard turbo model parts, but these days they are rare and not worth it. There are many ways to go about it, main factor is budget.
  2. To add bushings to the front mount (they did add that) To properly bush the diff mount (not done) To change the brace so it fits in a 240z without smashing the spare tire(not done) Then a number of things about suspension optimisation such as what was posted in this thread.
  3. I got mega burned by Apex on the rear track attack. Was one of the first buyers of it and back then it didn't even have enough parts to even bolt it to the car. The design of the rear kit is just for looks. Much feedback was given to them in how to improve it, but it was widely ignored. Shame because the cradle design is a good base to start off of.
  4. I was doing some thinking and think that I have discovered an excellent trick to get some higher compression and better piston rod characteristics from a stock dish piston setup. I don't have the parts in my hands to take exact measurements, but it seems like you can take an L28 with dish pistons, swap in 240z rods (2.65mm longer) and then remove about 2.15mm from the dish piston tops. This should get them to be basically a flat top, with depending on head gasket and block deck height, a nice tight clearance. You get the performance benefits of better rod ratio, smaller trapped area between top ring and piston top, and higher compression for minimal costs. Anybody do something like this before?
  5. I saw them selling for $6200 in Europe. They are CNC heads already so I wouldn't expect a whole lot more cost for the DOHC variant. Derek what you've done is cool and all, but my gripe is that you stopped making the head a long time ago. Why not share the files with someone like Edelbrock so they can make a head for the masses. We're at the point where L series are becoming scarce and manufacturers don't even have incentive to make parts for them anymore.
  6. Don't worry PAMS is already testing a real DOHC head on cars and you will actually be able to buy it. I expect prices to be better and unlike this head it will install without a headache and an engineering team.
  7. These are not just bare heads, but unmachined heads. And it's just one not a pair. Yes inflation has been ticking up substantially, but not long ago you could get a pair of assembled ls3 heads for $800. Derek came in here to try and stroke himself for a ten year celebration, but let's all be real this cylinder head was made for himself. Dude wants to keep it for himself too.
  8. Don't fool yourself man, nobody has this head, it's just a talking point.
  9. You ever think about liscensing or giving the design out to a real head manufacturer? Its been so many years thay we have gotten to the point that L series engines are disappearing and becoming less and less popular, and you have only sold 22. You haven't actually done anything tangible for the community. Now if a real company made some heads like this for about the $1000 they should cost, then the world would change.
  10. Ooof 40 and 80 are really bad. Bad results wet would point to broken/pinched ring, but if your really lucky a sooted up ring. I used something called b12 chemtool in my cylinders when I got the motor. It had been sitting outside at the previous owner's place and got some water in the intake. To my surprise it cleaned up perfectly and had 135-140 compression on all cylinders. Valve sticking would be very obvious to spot with the valve cover off, you would see a valve noticeably lower than the rest, unlikely to be the issue though.
  11. Most likely thing to be leaking is the wastegate if it is a cheapo one. Next thing would be to check the blow off valve, normally they are springed at 6psi by default. Depending on what kind of muffling your doing, you should be able to hear the turbo spooling up and screaming.
  12. I'll repeat myself one last time, the issue is with power to the unit. Look at the symptoms, all the outputs from megasquirt are cutting off at the same time. Check your powers, check your grounds, check your relay, use your brain.
  13. You need to be pulling a power wire straight off the battery to the ECM, and then another power wire from switched 12v.
  14. Ok, so heard a clicking sound which was at the same time your tach signal cut too (RPM needle dropping instantly). Is the clicking the fuel pump relay or something else? The tach signal is coming from the megasquirt ECM right? If yes then this is the power to the whole unit cutting on and off. Either from bad power/ground or faulty ECM.
  15. Chinese .63 A/R t04E with the billet compressor wheel. https://www.ebay.com/itm/174278894818
  16. Got everything tuned up a few months back, the car runs great, the power feels like its strongly in the 300s, but I can see that the cylinder head is holding the motor back. Quite sure there is detonation, as my computer keeps thinking there is, and the power is not really increasing at all above about 14psi. I think I will add a flex fuel sensor and try adding some e30 or something. I don't have enough injector to go very high on the ethanol content. Then again, it is quick enough as is. All in all I'm pretty impressed in how much this motor woke up with this setup, the turbo spools so quick that even off idle it feels like a much bigger motor.
  17. Those AFRs are both way off. Most of what your saying makes no sense, and if you don't see that yet you really need to read more of the docs of tuning and megasquirt. I'm pretty sure your just way off with your megasquirt tables.
  18. You sure that is controlling the fuel pump? I would expect it to control the injector instead. Typically the ECU will just command the pump on and off. I've only seen pump duty cycle controlled on really advanced setups. Do you have a fuel pressure sensor somewhere to monitor? Also DFCO shouldn't be used at all with a manual transmission, unless again you have a sophisticated system that can tell what gear the transmission is in.
  19. Can you share your ignition timing chart?
  20. None of those upgrades are worth it. The car will still feel slow after all that unless you go way up on displacement or turbo. That said you can do just the turbo and none of the other things and the car will actually be fast. I spent about $1500 to turbo my engine, check my build, I got a lot done on that budget. You'll end up spending much more than that for much less power NA. That said, I liked my car more when it had the LS, and the LS swap is pretty easy.
  21. You would be better off tying into the bolts on the cold side for your attachment point. That will drop a lot of heat too. Or you could try to use the two bolt holes near the top of the block if you have those. I used those for knock sensors but they would work good as a mounting point for the turbo
  22. @toffee You know you can just do an image search to see where the engine sits, but spoiler it is behind the crossmember. I don't know why this matters so much though. The main thing I don't like about the VQ is the intake manifold with the rear exit, which means you have to chop off your factory hood latch and fit in some other form of latch instead. A turbo L-series will make over 300hp, but all the wear item parts on the L-series are becoming way overpriced. The LS family is the best for the money by far, and the arguably best manual transmission in the world is what bolts to them natively. Also you can fit an LS and TR6060/magnum in the car with the only modification to factory metal being some clearance of the stock transmission crossmember ears.
  23. Does anyone run a knock sensor, particularly with a turbo car? I run two in the two holes at the top of the block, and get a lot of knock retard at higher rpms and higher boost. Its showing some pretty extreme retard, but the way it is pulling it at higher RPM under no load/boost makes me think that this is false knock. I see no physical signs of knock, and don't have any audible knock. I've attached a spark retard snapshot along with the final spark advance table to go with it. I've read of folks running more timing at the same boost levels, but then again I've read of plenty of folks blowing head gaskets too. I'm running on 93 octane pump gas. This is a stock n42/n42
  24. For closure, they are the same. My sensor was reading 200M Ohms due to corrosion between the sensor body and the nut.
  25. Is the coolant temp sensor for the gauge on an l28 compatible with the 240z gauge? My temp gauge no longer shows anything after attaching it to the L28 sensor in the thermostat housing.
