zedsn
Everything posted by zedsn
  1. zedsn
    WTB
    Hi, looked over the wheel cylinders today And you will have to free un the bleed nipple and remove the brake line nut as I just cut the line when I removed it but other than that I would just bolt up as is after you flush some brake fluid through it as the boot on each cylinder looks real nice. I tore the car apart last year but it was a running driving car. Ed from Ohio.
  2. zedsn
    WTB
    You have a PM.
  3. Hi, I believe that I have what you are looking for. Email me at zedsn@hotmail.com if you are still looking for the brackets.
  4. I have a nice working ignition switch and have sent you a PM.
  5. I have a steering column and have sent you an email.
  6. Hi, I have a good working pair. Will send you a PM.
  7. I have both quarters from a 76 280z that have no rust and were cut out from the inside so they are complete. I want $100 for each one and am in the Cleveland Ohio area. Would like these picked up or you handle all shipping arrangements if you want then. Ed from Cleveland Ohio area. zedsn@hotmail.com
  8. has not set their status
  9. Hi, sent you an email about glove box liner. Ed from Ohio.
  10. Sent you a PM on 240z wire harness and steering wheel hub.
  11. Hi, sent you a PM on chrome shifter and balance tube.
  12. Sounds like you may have a bad rust or scale build up in the block or a prior owner tryed to fix his leaky radiator problem with stop leak and the stuff has traveled everywhere and left behind chunks in bad places. You are going to have to somehow flush your motor big time but that may just move stuff from one spot to another. The ideal thing to do would be remove the head and inspect head and block water passages. Good luck and I doubt there is an easy long term fix.
  13. Hi, sent you a PM about door locks.
  14. Hi, they are called crankshaft bearings or main bearings. You should have your crank checked out by a machine shop and new bearings fitted. With a lot of miles these bearings get worn down pretty good.
