Everything posted by shika805
^as you can tell the rear mount had to have a hole drilled to through the rail to secure the seat in place. The problem with this is that it will limit how far you can adjust (slide back) the seat back... I'm only 5'8'' so this works for me, people over 6 foot will probably have some issues with room.
aright just an update! got the seats installed with no problem, took me about a day to think about and about 2 hours at Osh... here is the finish product, all done by hand no welding required!!!! took off the rear brackets and drilled a new hole to connect the cross-member mount that will connect to the existing mounts in the floor pans. cross member cut out and drilled spacers for the mounts front mount rear mount
mine what all brittle and came off by hand... i have linex as a new sealent, sound deadening and coat on the floor of my car.
gotcha, i've seem them already... i've looked in the seat swap thread, and few thread on zcar.com... not one goes into real detail about how they came about installing the seats. I took some measurements of the car it looks like i will be making some custom brakets for the rear mounts on the seats. I'm going the "no welding" route, bolting a custom mount to the rear mounts on the seats, then bolting it together to the car. I looks like i'm going to have to cut out the rear mounts on the seats to attach my fabricated ones.
seal in the MC... like stated. happened to me a few times with cars
Looking for pictures of Z cars with WIRE WHEELS
shika805 replied to logan1's topic in Brakes, Wheels, Suspension and Chassis
that burnt orange Z is making me change my mind of wire mesh wheels. nice post -
Ok, so I scored and awesome deal on some S2K seats from a friend that did a swap. They were in perfect condition and I had the money for it. I know the s2k seat swap has been done before in a 240z, but not much info on the install. Seems like it's one of the harder seat installs Some of the issues that i searched that came up: -Transmission tunnel is too wide for the seat on driver side -s2k mounts too wide for 240z mount holes -The rails on both seats, have a rail that is longer than the other -Seat install seems to sit higher than original There are probably more issues that i've missed but these seem to be the ones that came up. I know custom fab work has to be done, but if anyone has any experience with this install i would greatly appreciate it.
my car is still on jack stands but once i have it on the ground i will let you know... my buddy has a Z and its about sitting with a 3 in drop... no scrapping of any sort. his is exhaust is kinda low and it gets close, just adjusting the hanger will make it better. i wouldnt go past 4 in. thats a little over kill
350z wheels on z31
shika805 replied to Delasangre4231's topic in Brakes, Wheels, Suspension and Chassis
^ there you go! -
350z wheels on z31
he means that when you have a higher offset, the hub is more toward the outer part of the wheel. Lower offset means that the hub is more inward from the outer part of the wheel. I believe the z31 is a low offset wheels based car, you would need a spacer to fit the wheels -
totally agree, i just meant the Japanese Domestic Market, always keeps all the good stuff in their home court, us here in North America we get the left overs. I see it a lot with honda, mazda, nissan, whatever.... sorry to be off topic, but i'll be definitely looking for a good sway bar... thanks guys
^thanks john so your telling me that a early 240z is not for driving "hard???" and a later 240z and above that were equipped with a sway bar are meant be to ran the crap out of??? ^of course its not mild, I was pertaining more to why did the early 240z's were not equipped with a sway bar but have the mounts for a sway bar???... it just makes sense that we should have one, right? what's it gonna hurt anyway? like what HS30-H said, we just got shafted from the good stuff...
thanks for the info guys, ok so this leads me to this question? my plans for the car is making it a weekend driver for now. I currently have shortened struts and the Ground Control kit on the car and is lowered about 3.5". I would love to take this car to autox someday but not now. Would you think a rear sway is in order or just leave it how it is? seems as if the rear sway bar doesnt have a noticeable difference in handling with your guys' experience?
amazing.... i can only wish, i can be doing that with my restoration, just beautiful.
cool, i tried reading in the Haynes Manual but nothing explained about the missing sway bar??? Is is possible to swap a 260 sway bar into an early 240??? I wasnt quite sure where the mounts would be on the body of the car? i know that the control arms have the mount holes for the sway bar? would it work?
So I am currently rebuilding my 71 240z from the ground up... I'm currently working on the rear suspension and placing everything back together. I noticed on my car that it wasn't equipped with a rear sway bar???? I never noticed this when I was removing the rear suspension from my car? I took a look at my Haynes manual and found that indeed that the s30 was equipped with a rear sway bar? The new bushing kit that i ordered included new bushings and end links for a rear sway bar also???? Has anybody ran into this issue before??? This car has been in my family for about ten years sitting out in the from yard. My dad never touched the car and left it to me to restore when I got older. I recently took over the restoration about year ago and is about half done. I noticed this when getting my car back from the paint shop. My car is an early model Z, it was built in November 1970, but was sold in 71' if that helps. Thanks in advance guys!
cutting my eibach springs?
shika805 replied to SkYBlue280Z's topic in Brakes, Wheels, Suspension and Chassis
yeah progressive springs are meant to NOT to be handled with, if you love your s30, save some money and buy a good set of springs that will bring your car lower, or go the Ground Control route with shorten struts, my $0.02... -
suspension removal issue... HELP!?
shika805 replied to vertebraille's topic in Brakes, Wheels, Suspension and Chassis
^ this will also help if you are still wanted to save your tie rods. my suggestion is just getting some new ones, hammering on those tie rods really mess up the threads. -
i had a problem with this too... how i got mine off was removing the steering knuckle from the ball joint and strut tube. Your tie rod is now able to be removed from the steering column with the steering knuckle still connected. When you have both parts off the car i took one blow with the hammer to the tie rod and damn thing popped out. I dont know why it was so easy to removed it with off the car when on the car??? use some liquid wrench or aero kroil, it'll help a lot. -
240z Suspension update! - lots O pics!
shika805 replied to Rimal310's topic in Brakes, Wheels, Suspension and Chassis
how you doing man, sorry to bump old thread, just had a question, are you using any type of bump steer spacers? My set up is almost exactly like yours..
