A to Z
Super Moderators
    44
Everything posted by A to Z
  1. Yeah, I noticed that as well....kind of shrugged it off honestly.
  2. 10-16-2022 UPDATE: Today I started by cleaning all of the caked on dirt/oil off the timing cover. Even with the pitting, I really thought maybe I could save it, but it is just too far gone. Im going to source another one. Next I started on the crank. It was a dirty grimy mess. Using parts cleaner and an old toothbrush I stood the crank on it's end, leaned it against me, and just started dunking the toothbrush in the cleaner and then scrubbing and wiping...working by way down.....then flipped it over and did the same to the other side. That took quite a while, the crank looked like someone had poured 30 wt oil on it and then threw it in the bed of a truck and drove down dirt roads for 6 months! I then took some steel wool and started again on one end and worked my way to the other, flipped it over and again.... the counterweights came clean! That caked on grime on the counterweights, you name it....after this it was starting to look better. These Diesel cranks have a pin on the end that has to be removed when using it in a Z car engine, so a few minutes with my die grinder and good to go. At this point, I was able to take some180 grit Emory Cloth and I took a thin strip of it, wrapped it around one journal and pulled and pushed and worked way around the journal, checking to see if it was coming clean....then moved to the next. Next, I took some 400 grit wet/dry sandpaper and tore it into long strips, and sprayed it down with WD-40 and did the same as I did with the emory cloth to smooth it out. After that I took a sock and some Mothers Mag and aluminum polish and put some on each journal and pull/pushed with the sock until each journal shined like chrome. Then I took a thin screwdriver I had where the tip had broke off, and being a round shaft it JUST fit into each oil hole. I was able to use it and a rag to clean out all the oil holes that went through each journal. After that came the carb cleaner with the little red straw that comes with it I blew out all of those holes going through the journals AND used the carb cleaner to throughly clean the entire crank. Once done it just glistened. All the oil holes clean as a whistle. So, 2-3 hours of work, but the crank is now good to go. What's next? I went after the block! I pulled the crank, and the rods and pistons out of the L26 block. I then cleaned the main bolts, the caps, everything, and made sure to keep the caps in the order they were in the block. Once that was done, I took the wire wheel attachment in my electric drill and cleaned up the block a bit then sprayed the block inside and out with carb cleaner. Then it was cleanup time which took a bit, but it feels good to get the dirty/nasty part of the job out of the way....mostly. Here are some pics:
  3. 10-16-2022 UPDATE: Today I started by cleaning all of the caked on dirt/oil off the timing cover. Even with the pitting, I really thought maybe I could save it, but it is just too far gone. Im going to source another one. Next I started on the crank. It was a dirty grimy mess. Using parts cleaner and an old toothbrush I stood the crank on it's end, leaned it against me, and just started dunking the toothbrush in the cleaner and then scrubbing and wiping...working by way down.....then flipped it over and did the same to the other side. That took quite a while, the crank looked like someone had poured 30 wt oil on it and then threw it in the bed of a truck and drove down dirt roads for 6 months! I then took some steel wool and started again on one end and worked my way to the other, flipped it over and again.... the counterweights came clean! That caked on grime on the counterweights, you name it....after this it was starting to look better. These Diesel cranks have a pin on the end that has to be removed when using it in a Z car engine, so a few minutes with my die grinder and good to go. At this point, I was able to take some180 grit Emory Cloth and I took a thin strip of it, wrapped it around one journal and pulled and pushed and worked way around the journal, checking to see if it was coming clean....then moved to the next. Next, I took some 400 grit wet/dry sandpaper and tore it into long strips, and sprayed it down with WD-40 and did the same as I did with the emory cloth to smooth it out. After that I took a sock and some Mothers Mag and aluminum polish and put some on each journal and pull/pushed with the sock until each journal shined like chrome. Then I took a thin screwdriver I had where the tip had broke off, and being a round shaft it JUST fit into each oil hole. I was able to use it and a rag to clean out all the oil holes that went through each journal. After that came the carb cleaner with the little red straw that comes with it I blew out all of those holes going through the journals AND used the carb cleaner to throughly clean the entire crank. Once done it just glistened. All the oil holes clean as a whistle. So, 2-3 hours of work, but the crank is now good to go. What's next? I went after the block! I pulled the crank, and the rods and pistons out of the L26 block. I then cleaned the main bolts, the caps, everything, and made sure to keep the caps in the order they were in the block. Once that was done, I took the wire wheel attachment in my electric drill and cleaned up the block a bit then sprayed the block inside and out with carb cleaner. Then it was cleanup time which took a bit, but it feels good to get the dirty/nasty part of the job out of the way....mostly. Here are some pics:
  4. 10-15-2022 UPDATE. My 2.9 Stroker Engine build ~ still gathering parts, I am awaiting a box full of gaskets and seals from The Z car Depot, A oil pickup tube and screen I bought from Harold Burroughs, and I have an Arizona Z Car aluminum baffled oil pan en-route as well ( yes they are available, a fresh batch just arrived! Hurry!). 7.5 quart capacity and is fully baffled. Below are pics of it I found online, not my car, posted just to look at. My custom 85.5 mm foged aluminum pistons from Rebello Racing are being made now, and now I need to clean up stuff and clearance the block. Of course I will provide pics of all this as it arrives.
  5. 10-15-2022 UPDATE. My 2.9 Stroker Engine build ~ still gathering parts, I am awaiting a box full of gaskets and seals from The Z car Depot, A oil pickup tube and screen I bought from Harold Burroughs, and I have an Arizona Z Car aluminum baffled oil pan en-route as well ( yes they are available, a fresh batch just arrived! Hurry!). 7.5 quart capacity and is fully baffled. Below are pics of it I found online, not my car, posted just to look at. My custom 85.5 mm forged aluminum pistons from Rebello Racing are being made now, and now I need to clean up stuff and clearance the block. Of course I will provide pics of all this as it arrives.
  6. 10-14-2022 UPDATE: Today my rods arrived for my stroker build. K1 rods I bought through Steve Bonk. 132.9mm long, factory L24 240Z engine rod length. Already balanced to within 1 gram and also come with ARP 2000 bolts.
  7. 10-14-2022 UPDATE: Today my rods arrived for my stroker build. K1 rods I bought through Steve Bonk. 132.9mm long, factory L24 240Z engine rod length. Already balanced to within 1 gram and also come with ARP 2000 bolts.
  8. 10-13-2022 UPDATE: My LD28/V07 diesel "stroker" crank arrived from Thailand today. $400. My 132.9" (L24 length) K1 H beam rods with ARP hardware have a scheduled arrival of Saturday I ordered some pistons from Rebello Racing, forged and custom made, but went ahead and moved the bore out to 85.5mm. So .020 under stock L28 bore. Essentially a wash giving me L28 280Z engine bore. I will using my Early 1970 E31 head and matching "A" grind cam, but on the #3 hole, which provides more torque. Dave Rebello and I went over it all and the pistons will be a nice forged set giving me 10 to 1 compression, and if I need more in the future, a .020 shave of the head will take it to 10.7 to 1. End result is a 2.9 stroker engine. I also ordered up the gaskets and seales and a new Timing set from Japan as well. Z Car Depot sending that stuff. I will get the crank in for work soon. More than likely .010 under all the way across, chamfer the holes and micro polish the bearing surfaces, then magnaflux and balance Here are some pics of the stroker cam as it arrived today.
  9. My LD28/V07 diesel "stroker" crank arrived from Thailand today. $400. My 132.9" (L24 length) K1 H beam rods with ARP hardware have a scheduled arrival of Saturday I ordered some pistons from Rebello Racing, forged and custom made, but went ahead and moved the bore out to 85.5mm. So .020 under stock L28 bore. Essentially a wash giving me L28 280Z engine bore. I will using my Early 1970 E31 head and matching "A" grind cam, but on the #3 hole, which provides more torque. Dave Rebello and I went over it all and the pistons will be a nice forged set giving me 10 to 1 compression, and if I need more in the future, a .020 shave of the head will take it to 10.7 to 1. End result is a 2.9 stroker engine. I also ordered up the gaskets and seales and a new Timing set from Japan as well. Z Car Depot sending that stuff. I will get the crank in for work soon. More than likely .010 under all the way across, chamfer the holes and micro polish the bearing surfaces, then magnaflux and balance Here are some pics of the stroker cam as it arrived today.
  10. As you know, Nissan offered the 2.8 series 6 as a diesel as well. It has a longer stroked crank (83 versus L28 79 mm). Known as an LD28 or V07, they are now fetching over 1500 dollars each. Well, I got one out of Thailand for 400 bucks. So, I decided to build a stroker L series 6 engine for my Z car! I have the V07 crank, which has 83mm stroke, the L24 has 73mm. So I am gaining 10mm, of stroke! 99% of the guys are using this crank in a 280Z/L28 block to build a huge cubic inch stroker. If I did that, my freshly rebuilt SU 46mm carbs would be too small unless I spent money to have them bored out from 46mm to 50mm. So I figured, there is a way to get what I want...TORQUE, and use the stuff I have. Use an L24/L26 block instead of the L28/280Z block! Difference? L24/26 are 83 mm bore, L28 is 86mm bore. Since 260Z and 240Z use the same block, when given the oppurtunity to buy a long block L26 locally for CHEAP (REALLY CHEAP!) , I jumped! The stroker V07 crank is inbound, and Steve Bonk, well known in Z circles sold me a brand new set of forged H beam rods with ARP fasteners from K1 in the longer L24 rod size (L24 rod is logner than L28 by 3 mm! ). All that is left is pistons. They will be a custom made deal, as I want the bore to remain small, but still more than the stroke, so I maintain my bore/stroke ratio. 83 is the stock bore, and I am going to go 84mm which is barely larger than the 83mm stroke. Why not larger?? thicker walls mean more rigidity, more reliability and better seal, better everything! The pistons will work with the longer L24 spec rods and the V07 crank to get me right at 9.0 to 1 compression using the E88/260Z head with the Nissan head gasket. The E88 head I have, is .5 compression ratio lower, but has the 280Z exhaust valve already!I So I will use it. So, I got the long block today, and ran and got me a hoist and engine stand to do this. the bolts to hold the block in are NOT M10X1.5as everyone said ! I got those and they didn't work. I had to use SAE 3/8X16 bolts! That's right NOT metric but SAE! Were they tapped by a previous owner? Probably. I am OK with it. So, an additional run to the store got me some grade 8 botls, and I managed to get the engine off the ground and on to the stand! Then I commenced stripping it down. I think Nissan broke the Guiness book of world record for bolts for an oil pan....it seemed like there was 50 bolts holding it on! At any rate I got it down to a short block and rotating assembly. Next will be clearancing the bottom of the cylinders so the crank and rods will clear. A steady hand and my die griner and I hope to make the reliefs good enough that I don't have to do it again once the block is all clean and bored and ready to go. This will put me at 2750cc from 2393 cc ( gain of 350cc+). A L28/280Z engine is 2753....so Basically the same, yet, not. My engine more than likely will make more torque than horsepower, and that's fine. Why? Because I run an automatic transmission! Torque is king on the street, and especially with the auto trans. Keep in mind I still have a 510 torque converter for a higher stall and a Stage III shift kit I can add should I need to. With 3:54 open gears, it should really be great on the street! Cam selection is still up in the air....the C grind cam in the 260Z head is a great cam.....but I need to clean it up and see if she is good to go or not. Prior owner painted the block John Deere Green (why? ) Here are a few pics of my new headache.
  11. 10-9-2022 UPDATE. Things have been busy. As you know, Nissan offered the 2.8 series 6 as a diesel as well. It has a longer stroked crank (83 versus L28 79 mm). Known as an LD28 or V07, they are now fetching over 1500 dollars each. Well, I got one out of Thailand for 400 bucks. So, I decided to build a stroker L series 6 engine for my Z car! I have the V07 crank, which has 83mm stroke, the L24 has 73mm. So I am gaining 10mm, of stroke! 99% of the guys are using this crank in a 280Z/L28 block to build a huge cubic inch stroker. If I did that, my freshly rebuilt SU 46mm carbs would be too small unless I spent money to have them bored out from 46mm to 50mm. So I figured, there is a way to get what I want...TORQUE, and use the stuff I have. Use an L24/L26 block instead of the L28/280Z block! Difference? L24/26 are 83 mm bore, L28 is 86mm bore. Since 260Z and 240Z use the same block, when given the oppurtunity to buy a long block L26 locally for CHEAP (REALLY CHEAP!) , I jumped! The stroker V07 crank is inbound, and Steve Bonk, well known in Z circles sold me a brand new set of forged H beam rods with ARP fasteners from K1 in the longer L24 rod size (L24 rod is logner than L28 by 3 mm! ). All that is left is pistons. They will be a custom made deal, as I want the bore to remain small, but still more than the stroke, so I maintain my bore/stroke ratio. 83 is the stock bore, and I am going to go 84mm which is barely larger than the 83mm stroke. Why not larger?? thicker walls mean more rigidity, more reliability and better seal, better everything! The pistons will work with the longer L24 spec rods and the V07 crank to get me right at 9.0 to 1 compression using the E88/260Z head with the Nissan head gasket. The E88 head I have, is .5 compression ratio lower, but has the 280Z exhaust valve already!I So I will use it. So, I got the long block today, and ran and got me a hoist and engine stand to do this. the bolts to hold the block in are NOT M10X1.5as everyone said ! I got those and they didn't work. I had to use SAE 3/8X16 bolts! That's right NOT metric but SAE! Were they tapped by a previous owner? Probably. I am OK with it. So, an additional run to the store got me some grade 8 botls, and I managed to get the engine off the ground and on to the stand! Then I commenced stripping it down. I think Nissan broke the Guiness book of world record for bolts for an oil pan....it seemed like there was 50 bolts holding it on! At any rate I got it down to a short block and rotating assembly. Next will be clearancing the bottom of the cylinders so the crank and rods will clear. A steady hand and my die griner and I hope to make the reliefs good enough that I don't have to do it again once the block is all clean and bored and ready to go. This will put me at 2750cc from 2393 cc ( gain of 350cc+). A L28/280Z engine is 2753....so Basically the same, yet, not. My engine more than likely will make more torque than horsepower, and that's fine. Why? Because I run an automatic transmission! Torque is king on the street, and especially with the auto trans. Keep in mind I still have a 510 torque converter for a higher stall and a Stage III shift kit I can add should I need to. With 3:54 open gears, it should really be great on the street! Cam selection is still up in the air....the C grind cam in the 260Z head is a great cam.....but I need to clean it up and see if she is good to go or not. Prior owner painted the block John Deere Green (why? ) Here are a few pics of my new headache.
  12. 10-4-2022 UPDATE: A full day in the garage doing wiring. Got the headlights working correctly, blinkers good, brake lights seem ok, parking lights and gauge lights not working....they were working earlier, now they are not. 🙁 Endless chasing! I had to run a new power wire to the solenoid to bypass the hiccups of auto trans start protection relays that no longer work right. Closer and closer! 🙂 The carbs are great! Maybe a tad rich at high RPM's, but engine starts just bumping the key!
  13. 10-1-2022 UPDATE: New parts arrived. New reproduction panel from Motorsport Auto "The Z Store" and my Japanese spec Fairlady Z 432R radio delete panel from JDM-PARTS. I "deleted" the map light. Doesn't work/too old.)
  14. thanks a lot, Ken. Sure is nice to get it out now. The car is geting better and better! SU's are dialed in, everything working great.
  15. 9-25-2022 UPDATE. I managed to get a few things done today. I swapped out my hazard switch, pulled the center dash vent panel and stereo out, pulled the center console out and did some wire cleanup and more work on tracing wiring to get things working. I found a connector that was undone.....that probably had a lot to do with my issues. Funny thing is, if I unplug it, car starts fine, if I plug it in, car starts in the "on" position and runs with the starter engaged. I disconnected it, car runs fine, so I will have to figure out what is causing my car to run in the ON position from where I plugged it in downstream. Most of the lights working and the gauges......since the gas gauge didn't work, I checked out the wiring at the gas tank, and those connections were bad, so I cleaned them up did a little repair, and now it works too! While I was under there, I went ahead and rust converted the tank straps and painted the tank. I finished up the front end alignment, just eye balled it now it has just a hair of toe in. Today I also jacked the car up in the rear and adjusted my emergency brake....I did 3 small videos of that I will attach. After all of this work my blinkers STILL don't work......new turn signal relay, new hazard switch...hmmm . One headlight I have to figure out, and when the lights are on, one backup light is on....so just have to trace it out. I am setting the car up as a "a vent fan delete" and "radio delete".....with jacks to plug in a stereo if needed. The stereo I had in there doesn't work......I will have to test it to find out why. So, alot of little stuff today. here are some pics and 3 videos at the end. Click below, to get to videos, they are at the end of the 5 pictures. (2) Facebook
  16. On rolling the fenders for wheel/tire clearance, you can roll both layers in the rear together or you can trim half way and roll them in. A cut and roll will be even tighter when you need all the room you can get. In the rear there are 2 layers, the inner fender and outer fender. If you can cut the inner fender all the way back to where it is a 90 degree bend, the outer level will then roll up flush and pinch the end of the inner fender up and then rollup flush. Then seal it up to keep water from getting between the 2 panels.
  17. I super glued a small piece of rubber, a little square on each interior side door latch. So when you open the door and get go of the latch it doesn't hit the metal and rattle. I can't believe how fast it shifts when I shift it manually.
  18. 9-18-2022 UPDATE. Today was an odd day in the garage. I managed to take the turn signal relay out, and I found it is a 2 piece arrangement one plugged into another. So, I put the new one in and absolutely nothing still. I went over to the passenger side and looked on the outer footwell.....apparently there is supposed to be a round relay there....I sure don't see it. I have a relay there that is rectangular shaped with rounded corners......at that point, I decided heck with it and started working on other items for now. I cleaned up the door jambs. On the driver's (left) side, I went ahead and cleaned it up, masked it off and decided just to repaint it, as my wet sanding just wasn't getting back down to thenice paintjob that was there before I did the bodywork and painting. I ended up with a few runs that I can address later, but I got it painted....I also went ahead and attached a couple of weatherstripping pieces, and then took some steel wool and removed what was left of the chrome "plating" on the plastic strip of the door panels. I then masked it off and used the Molotov paint pen I had to make it look new. Well, it didn't. The paint pen doesn't allow it to go on smooth, and looks choppy when done, so I took a rag and Denatured alcohol and wiped it off. I think I will spray it with the Interior SEM Napa red paint and just make it a part of the whole door panel/card. I cleaned it all up and got it ready for that, then went over to the right side and did the same, but also went ahead and installed the weatherstripping for that side that needed to be replaced. Thankfully, that side didnt't need to be painted like the Left/Driver's side. I also finished the painting of my grill to a dark grey. I put everything away and deicded to take her for a drive.....Well it ran great sitting still but driving under load she was very lean, lurching and popping. So I turned the mixture screws on the SU's all the way in then back out 2.5 turns. Now it ran great! I found a stretch of raod where I could then carefully step by step lean it out until it ran bad, then back up one spot. So overall I am 2 turns out PLUS "one click rich" or 2 1/4 turns out. Put the airbox back on and hit the road! For some reason the kickdown from drive didn't want to work, and I found that manually shifting the auto was better anyway. Manually shifting gives you a very quick shift....so not quite sure why shift kits are even sold......I CAN however see where the loose torque converter I have could be nice from a dead stop....she is a tad sleepy for a second or two, then takes off fine. I have an appointment in a couple days for front end alignment and a vacuum brake bleeding, as my best efforts with the speed bleeders still isn't cutting it. The tires are also self clearancing the flares as needed on bumps, etc. Not damaging the tire at all, just shaving the inside edge of the plastic flare. I was able to reach under there and pull the filings off! I am really going to have to get serious about my lighting and couple gauges that aren't working now. Everything else is fine. Exhaust really growls on a downhill at speed when I downshift and let the compression slow her down! Here are a few pics.
  19. 9/17/2022 UPDATE. My air filter finally came in. A previous owner had drilled a bunch of holes in the bottom of the factory air cleaner cover. I remembered that 3M makes colored duct tape, and so I bought some and cut it nicely and covered the outside of the holes, then put it on the inside as well. I want it sealed. I then polished it up and took a few pics. I may get reproduction stickers for it....pics!
