It sounds like you may have an issue with the alternator, you should not see the voltage drop once you are off idle, but that when measured at the battery or fuse panel. I'm not sure where your voltage is being measured - if you are getting that off MS, you don't have a good power wire to the ECU, it is dropping voltage when you make it busy.
