Synlubes
Everything posted by Synlubes
  1. Sweet! I`ve always liked a white Z. Mine will be white one of these years.
  2. I also did a cowl mod, but left the pass side vent hole open. I use glass cloth (4 layers), then fill & sand, fill & sand . . . . . . . Ck it out, click Z pics in my sig.
  3. The average user has no clue what someone with some knowledge can do with an unsecure wireless connection. Wireless is great technology, but beware what the salesperson doesn`t tell you (or know them self). Find some tech folks and ask lots of ?`s.
  4. This can also be corrected with a speedo pinion gear change.
  5. 215/60R/14 fit and look well on the car. You would want a 7" wheel.
  6. There are also some vent lines on top of the tank. Sounds like you need to drop the tank, spend the money and replace the necessary hoses.
  7. Don`t know about a kit ??? Try a search. Hybridz member "Mark" is one that I know has done this swap. Search for his posts and you will find his info. He also has some pics in his personal gallery. There also are other members that have developed "kits" for our cars. Search for Mike Gibson (aka) SCCA and Ross (Modern Motorsports). There are others also, sorry I missed some of them.
  8. John, I the 79 - 81 ZX masters will bolt up with no mods. The 82 - 83 mounting is different. I used the earlyer ZX 15/16 master on my Z. I also changed frt calipers and installed a tilton pro valve all at the same time. All I can tell you is do it, it is an inprovement over the stock Z master.
  9. kustom240, Try a search, there have been a couple of swaps of this type by members here. Go For It !
  10. 41 as of this past October. I`ve owned my Z since 1981, that`s half my life. You younger folks, Don`t let time slip away. The years go by quicker every year.
  11. Synlubes
    Pinion nut size?
    Tom, I think it`s 24 / 27 mm ??? My book says torque pinion nut to 123 / 145 ft-lb. Hope that helps
  12. I use them on a track car and change them after 2 years. I have worn out rear ajustable bushing but the frt have done well. How you use you car would make some difference. If you already have them in, leave them and take advantage of the ajustability. No need to just replace them.
  13. Greg, All S30 series hoods will interchange.
  14. On that part # from McMaster Car was that "bulb location" A or C ?
  15. Rufus, I have had good dealings with them. Just give a call.
  16. Wow, not only the engine but ck out the double tire set up.
  17. I had to . . . Sorry I couldn`t make it full size
  18. Hey Georgia Flash, How was the fit and finish of that hood ? Your car is looking good !
  19. facing your garage, you could always add on another bay to the right side. Garages are never big enough.
  20. You need to start taking some pics as you go and letting us see them.
  21. Are you talking about the motor hanging on your engine stand now?
