DaleMX
Everything posted by DaleMX
  1. Ok, the tar paper is up. That's good enough. It's ok to move in now.
  2. I used a willwood clutch cylinder for the T56. The Datsun plunger fit into the willwood housing perfectly and bolted up like the stock unit.
  3. The adaptor was suppled in Johns kit for the LS1.
  4. Oh joy, fuel lines and exhaust. my 2 favorite things.
  5. DaleMX
    LS1 short belt setup
    I added an extra pulley and got a different belt to add contact area to the water pump pulley.
  6. DaleMX
    LS1 intake tubing
    Rubber hose for the intake. PM me if your intrested.
  7. DaleMX
    Rollbar
    Oh boy, steel for dinner.
  8. Oh boy, the night before. Took a while to get my nerve up.
  9. DaleMX
    Gauges installed
    Gauges are in.
  10. DaleMX
    Pro Comp Speedometer
    Pro Comp speedo with green LED's added for turn signals, Installed into stock bezel.
  11. DaleMX
    Pro Comp Tach
    Before installing into the bezel.
  12. Pro comp tach installed into the stock bezel, side view.
  13. DaleMX
    Pro Comp Tach
    Pro Comp Tach installed into the stock bezel
  14. DaleMX
    A4's installed
    Inside shot of the A4's
  15. The Passenger side rail with the nutserts installed for the LS1/T56 mount.
  16. Here's the LS1 JTR passenger side header.
  17. I had to get an adaptor set from AutoBarn to mount this. MAS280 sent me the link. It was a tight fit as the LS6 intake is a little larger than the LS1 intake at the back.
  18. I put the computer under the dash on the passenger side. It's a tight fit, but it works.
  19. DaleMX
    Konig Monsoons
    Joy, Konig Monsoons. Had to get hubcentric adaptors for the wheels.
  20. It fits perfectly.
  21. This is how I ended up running the steam vent hose. I used and adaptor from JTR and spliced it into the stock LS1 hose.
  22. The stock fuel lines have to be moved to use the JTR header setup. I ended up running a 3/8 aluminum line up the firewall.
  23. DaleMX
    Harness, Speartech
    Harness for the LS1.
  24. Pic from the walbro site with dim's.
  25. DaleMX
    Fuel Line Install.
    Oh joy, running fuel lines.
