A bit of an update!
Well Then engine had to come back apart again. Multiple problems. The head is actually the most stable part of the build right now, ha.
First of all, I installed a Z32 RPS six puck disk and pressure plate about a year ago. The clutch is WAY too much pressure for the thrust bearing in the engine. THe stroker crank is trashed, because the thrust bearing wore completly through and the crank was riding right on the back of the main cap and block. I have always been carefull to not hold the clutch in when I dont need to, ie. when at stop lights, waiting for the flagman at race tracks to wave me on etc. The car needs that much clutch, so I cannot put a weaker clutch. I am in the process of designing a new style thrust bearing that goes inbetween the back of the cranks, right on the flange where the flywheel bolts to, and inbetween the block.
Next, The 440.00 dollar harmonic balencer from BHJ has failed. They make the hubs out of alluminum. I should of cought this before I installed the unit. You cannot have a press fit of about .002" from the ID of the harmonic to the OD of the crank snout, with the hub out of alluminum. When that crank and snout and the harmonic hub gets to 200 degrees, you loose all of that press fit, for the reason of material exansion difference in rates between alluminum and steel. From my calculations, it becomes .002" clearence at that temperature. The keyway in the harmonic, and on the crank was both "wallard" out. Once this all happened, the bolt got loose and the harmonic started to walk forward. I use Red high temp locktite, long custom made bolt, Thick 17-4ph stainless custom made washer, and 150 lbs of torque. Once the harmonic walked forward, and the thrust bearing on the crank was wore out, the lower timing chain sprocket mooved so far forward that the double roller custom timing chain had not been straight on the sprocket, and broke the lower timing sprocket, (also custom).
I am not sure what you guys with high pressure clutches do for thrust, but the size of the L series thrust washer is REALLY small for high pressure clutches. At the price and availibility of V07 cranks, I cannot afford to keep trashing them. I will post pics on my new thrust design also.
It also looks like that with 600 ft lbs of torque and 700 plus RWHP, that the cylinder bores are not staying round, even with an extra thick block. I have sonic tested this block to be an average of .125" walls with an 89mm bore. I am now going with an 87mm bore with another extra thick block, to maintain more cylinder wall thickness for my HP and TQ numbers. Z32 pistons will work great.
