alright, so i checked the wire to the back of the tach, and that was fine, all of the wires were solid.
i took out my volt meter and found that i was getting 13V from the BW wire on the resistor to the GW wire on the reisistor. when i tested the power from the + side of hte coil to the - side of the coil it read 0V.
started looking at the connections, recleaned them, replaced the plugs and tried again. same results. since we were getting power to the resistor but not through the coil i figured that it might be a bad ground (B wire on - side of coil). so i added a ground wire to it, and FINALLY got voltage running through the coil.
while key is in the "ON" position and resistor connected i was getting...
+/- on coil is 6V
+/- on resistor is 6V
High tension (nipple from coil to distributor) to (-) on coil is 6v
while cranking the car
+/- on coil is 7.75V
+/- on resistor is 0V
High tension (nipple from coil to distributor) to (-) on coil is 8v
this is where it gets weird. when i connect the voltmeter to the the distributor cable it shows no volts running through it. when i take off a spark plug wire at any cylinder there is no spark running through it.
so i dunno, the coil now has power going through it. but whenever itwants to transfer to the distributor it shows no voltage, and i would think that there would be.
so what is the next plan of attack? is it in the distributor? i replaced the points, rotor, condensor, and cap.
