rudypoochris
Everything posted by rudypoochris
see my problem was that the aero mufflers i linked only allow for a 2.5" inlet or a 3" if i go with the suv model, sow does it make sense to use headers to a 3.5" (Y) with one of those cones in it, and then at the very end limit the pipe down to a 3" to use the aero suv muffler?
i would go with a current m3 power plant, 8000 rpm red line 334 horse 3.2 litre.... but if you insist on that much torque i would forget the vvt-i i think it will only cause trouble for you, that stuff is tuned to the engine in so many ways throwing more cubes at it will only throw it off, imho
Si9nce you seem like a genius grumpy can you help me with a 302 exhaust setup, i would like to use 2 of those aero turbine mufflers (http://www.aero-turbine.com/buy/index.html) and i was thinking of using them right at the bottom of the headers then making them join into a 3.5" pipe. is this a good idea? would i cross over before the two mufflers or no need? willt he sound be ruined from the super long distance aft of the muffler? back pressure issue? thanks!
OMG i can't get the u joints out of the half shaft knuckles its on a r200 from a 76-78 280z can't remember the exact year, we got the clip ring things off and hit it with a rubber mallet till we were blue in the face, do we need to lube it up or is this a non-removable u-joint like ive been hearing about recently?
300zx rear rotor on 280zx
rudypoochris replied to Cody 82 ZXT's topic in Brakes, Wheels, Suspension and Chassis
more leverage is the reason that comes to mind.... -
wow 78 u-joints are not removeable? maybe thats why it took us so long with no results...t hats weird though because we had the u-joint clips ont he r-200 and removed them... then we hit it with a sledge, tapped with nromal hammers, and basically beat bones gaianst it like monkeys in front of an obelisk... what are we doing wrong or are these simply permanent u-joints sorryf or post hi-jack
Please help with cheap suspension setup
rudypoochris replied to Hugh's topic in Brakes, Wheels, Suspension and Chassis
ahha i bought from him too, and no 505 is correct will be 544 after everything... he raised his prices (i guess from weaker dollar) used to be 469 i think -
240z weighs about 2300 curb with a 225hp stock 302 from alot of 90's stangs you would pretty much be at 10lb/hp which is a good spot, note: i think the 302 is acctually lighter then the I-6 it is replacing so bonus on that.... tranny may be heavier... plus the 302 got room to grow... gt-40 heads and x303 or e303 cam you will see 340hp and 305 lb/ft i think not positive. Also you can always buy a $1895 300hp, $2095 320hp, or a $2395 340 hp long block 302 from centralcoastmustang.net i have never bought any but they seem cheap for what they are. So id say go with the 240z, first gen's have less amenities but if your drag racing.....
MY toyota 4 piston calipers restored!
rudypoochris replied to rudypoochris's topic in Brakes, Wheels, Suspension and Chassis
im getting two 92' rear 240sx calipers one has a torn dust boot (i think thats what they are called.... the thing that keeps dust out of the piston....) so i think ill just buy a disc hardware kit from autozone for that and paint those red too. then we willbe autobahnstormen -
ive been papering them... they are my babies... now onto the rears 240sx calipers but the problem is it seems damn hard to find a rear rebuild kit does anyone else have luck or is it okay to simply use them if the seals seem intact? also rebuilt ones cost like 65 a side :S plus 60 core -
uh are the wires yout alkign about the two metal clips seperating the pads int he picture...? and are you sure im missing something, if so please send me a picture.... if my slider pins are straight enough to fit threw but not perfectly straight is that okay or they should be changed any way? thanks! also on autozone.com i found a "CALIPER BOLT/PIN" but no slider pin are these the same thing? -
can anyone answer my question about the pink highlighted pins i think they are called, what part are they? if they are not straight must they be replaced or are they okay as long as they are relatively straight and can fit in? -
hahaha maybe the same seller seems to have an infinaesupply just search s12w and they will always be there -
i think its more like 70 a piece lemme ccheckyou might be thinking 12-8 ok it is $40 per calipers but also a $70 core charge per caliper as well... so if you have no calipers to start with your looking at $220 to get rebuilt ones.... -
Hey owen i was wondering if the dash cap from msa will cover a gouge that is 1/4 inch wide and sticks about an 1/8 of an inch up (plastic warped) to installt he cap i would simply sand the plastic flat? Thanks!
"Dupli-Color" Red caliper paint kit... the brush on kind. the box for 14.99 came with: paint, paint brush, masking tape, brake cleaner, and a stick to stir the paint. It was cheap and the right color so far so good. I got it at kragens -
I finished cleaning up my toyota 4 piston s12w: to...... talk about matching the color to the tokico springs!!!! 5 hours of decreaser whew then painting... (yes i know i could of put it threw a parts washer shhhh!) now im just wondering what parts i need to rebuild... i ordered the piston seals, boot retainers, and caliper dust boots, plus anti rattle clips... what else might i need? i have a feeling i will need new ones of these seeing as they were bent.... look in pic below: the things i highlighted pink are called???? caliper pins? i wasn't sure so i didn't order these... so any way i was jsut wodnering other than what i have ordered what should i order? (already ordered: piston seals, boot reatiners, dust boots, and anti rattle clips) thanks!
will early 280z stub axels work (from a drum braked 280? around 76-77) cuz thats where i got the r200 from
i found a z31 clsd to put into my r200 it is just the center.... will this bolt up to my u-joint style 240z half shafts? thanks! (sorry if this is a repeat but i need to know fast and have to leave right now)
i drive a tan ford explorer 92' xlt 5-speed what izzz it. my datsun is a 240z though and i am thinking 17X8 wheels using the 4X4.5" pattern they are hard to find though... i liked a couple i saw from exel wheels and some from sportmax... thats "sportmaxwheel.com"... always could go for some reqinds too but lots of people got them. i would put them in 235 yokahama A046 or Parada Spec-2's
How to clean a caliper?
thanks man! do i need tow orry about getting the liquids on the seals and the pistons while the brake caliper is uninstalled (the pads will be changed and the seals will probably be changed any way)?
