VinhZXT
Everything posted by VinhZXT
  1. Hi Jmortensen, Thanks for a quick response. I was thinking of taking an extra step by cutting it open and blast the inside of the tank. Put the sealer on and then weld it back together. This is all depends on how to cut open the tank. If cutting around the edge (in the middle section of the tank) and the tank comes apart then welding back will not be a problem as long as I still have the lip around the tank. I guess my question is how the tank welded together from factory? I will inspect the tank carefully before I decide to cut it up. I am sure I will figure out a way to get in there to clean it up without cutting it up. Also thanks for the tips on the oil pan. I did modified my LS1 oil pan and did some welding on it. I will be watching for any leaks. Thanks again v.
  2. I am getting a gas tank repair kit from POR 15. I have not look at the gas tank yet but anyone knows a trick to cut open the 280Z gas tank and ofcourse it has to allow me to weld it back without a problem? Also what type of welding should be done to put it back? Thanks for the info. v.
  3. I am looking for the old style (sides) twin glass pack for my Cobra Kit car. Anyone has any info please send me an email or a PM I really appreciate it. Vinh
  4. Thanks for the replies guys. I've search this site briefly before posting this but didn't find the answer. Right after I posted it I went back and did more searching and found the info about the A1racing site. HCTrouble, my project car is a 280Z and I found that info about the 2.170 strut tube also. I believe someone made a sticky about that thread but I didn't see it on the top of the page. Hopefully I have time to check out VRJoe's setup this weekend and get more info from him. Thanks again guys.
  5. Have anyone have any experience with this seller? http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=8030831072#ebayphotohosting I was curious why their is so cheap. Thanks for any info. PS. I already know Ross offer them also.
  6. the tires guys will be cursing alot of F words when he puts these tires on the rims. lol..
  7. Damn, I got my wheels last year and they said they don't offer 10" for 4 lugs. Bummer I would love to have 10" wheels in the back. Maybe I will just buy another set and sell mine.
  8. Hey, I got the same wheels and how come I didn't get any compliments? This sux. lol.. Good choice Gabe..
  9. VinhZXT
    ls1tacsensor
    TAC installed in the stock gas pedal.
  10. VinhZXT
    ls1steeringshaft
    Steering shaft clears the stock C5 engine mount
  11. VinhZXT
    ls1radiator3
    Custom make the SS top cover piece to bridge between the radiator and rad support.
  12. VinhZXT
    ls1c5header
    Modified stock C5 header to clear the steering shaft
  13. VinhZXT
    ls1radiator2
    Back side of radiator after sealing
  14. VinhZXT
    ls1radiator
    Sealing areas around the radiator with SS sheet metal.
  15. VinhZXT
    ls1fan
    fan mounted on the SS fan shroud.
  16. VinhZXT
    ls1alt_waterpump
    Honda alternator and electric water pump mounted.
  17. You can always go back and do it better the 2nd time around after you get sick of the RX7.
  18. Found the problem. 2 spark plugs wire crossed. Had to go to the Ford forum to get the info.
  19. It doesn't matter Z or ZX. You can add a selenoid to activate (open) it from inside or by using a remote. For the Z you can lock it with that button and still be able to pop it if you installed the selenoid.
  20. it's for the Z , S30. I have the same one on my V8 240Z. Please email me at anh3pa@hotmail.com and I will send you some pictures.
  21. Hi all, First I want to appologize for posting this here. I have a fiberglass hood which is perfect for a V8 Zcar. If anyone wants it please send me a message. Please no flaming. Thanks..
  22. You can find many of different types of these selenoids in late model cars at a junkyard. It should cost you $5 or less for it. You should also grap a relay for it as well. Mounting the selenoid can be challenging but it's not impossible to do. I have install door release selenoids and they are both installed similarly. Good luck
  23. Thank you Pete ). BTW I am 6 hours away from Pittsburg lol. I am from Philly actually.
