Everything posted by VinhZXT
Machoir,
All I can say is get the car to relearn the idle and the fuel trims. I don't have the procedure on top of my head. I will look up the manual tonight when I get home. If you ran out of idea try put in a new crank angle sensor. Again I don't have my manual here with me but I remember the misfires can be related to the crank rotation. GL.
Vinh, I found a cracked spark plug which seems to have caused a lot of the problems. I still get a PO302 code but not a multiple misfire anymore and it runs a lot better. It doesn't seem to misfire on the gas anymore, but coming off the throttle. I am going to swap coils around to see if the #2 coil is not working right. Anything else I should check? I want to get it tuned but don't have that kind of $ to spend on it right now.
Chris,
My only suggestion is to swap out the distributor with a known working one. From my experience this is the first thing you should check. Also check the wirings to the distributor. GL.
Vin,
Chris here, Adams friend, New harness worked out much better. Thank you for helping out. We hooked it all up, car started. Then we nicely connected all the wires with connectors and even tested continuity. We now have no spark. All other systems are working correctly. Power to ECU, checked dizzy (Pulled out and spun, injectors clicked) I've been working on these for years and am stumped. Any thoughts?
C
