Kbhead
Everything posted by Kbhead
  1. Heading to Vancouver, BC for the Autocross and Car Show this weekend
  2. I'm sorry it took me a few days to give you an answer, but I had to go to the post office since the package would be going to Canada. Shipping for the LED taillight conversion would be $12 and we do accept paypal.
    Thanks,
    Brad
  3. Your probably correct, but I haven't see another list showing all the options.
  4. Check this link out it will tell you all the ratio's and what year and car they come from. http://www.geocities.com/inlinestroker/ratio.html
  5. House reno's, car still on blocks :(
  6. As far as the gauges go, here is the thread on my set:
    http://forums.hybridz.org/index.php?/topic/69249-autometer-guts-in-oem-gauge-cups-saga/page__st__40__p__873823#entry873823
    and this is another on just the speedo and tach, even though you can see that I did mine slightly different: http://forums.hybridz.org/index.php?/topic/63713-mounting-autometer-5-tachometer-like-stock/
  7. Sorry it has taken me so long to get back to you! The trip to Victoria went well, even though this trip we could have used at least one more day, time was short. Victoria is an amazing place, so much so that my friend wants to move there, haha.
  8. Cable, I'm not sure yet as I might try and use the baffles for the LS1 oil pan.
  9. Heading to Camby, Oregon for this weekends car show.
  10. Do you still have the stock GTO oil pan? If so, want to sell it?
    Thanks!!
  11. I'm also interested in the same answers or other options? 1) Can you leave the stock proportioning valve in and put the adjustable proportioning valve down the path? Please show pictures of your setups. Thanks
  12. Nice job! Feels good to do it yourself!
  13. Nice job! Feels good to do it yourself!
  14. Hello, I have search the forum for a diagram and explanation of were and how the line lock should be placed on a Z setup. I have replaced the master cylinder with a 280zx (11/15") and replace the stock 240z proportioning valve with the 280zx one. Now I want to add a line lock and adjustable proportioning valvue (APV). 1) I see most people replacing the stock proportioning valuve with the adjustable one. Is that the best way to do it or should the adjustable valve go between the back brakes and the stock proportioning valve? 2) Line lock, should that go between the master cyclinder and the brake sendor valve (before the proportioning valve) on the Front line? 3) What line lock system are people using? Is B&M 46076 Line Lock Launch Control Solenoid Kit worth getting? Thanks for your help.
  15. In progress (LS2 engine swap) 1973 240z 2005 GTO LS2 (4044 miles) T56 Six speed transmission B&M Short Shifter JCI's Engine & Transmission Kit JCI's Sandersons short hugger headers R200 diff 3.9 gears with Torsen Gleason limited slip 280z Stub axles, Modern Motorsports CV adapters, CV Joints with 280z Half Shafts Front Suspension shortened 1.5", powder coated red Koni adjustable shocks 8" coil overs with 250 lb springs Toyota 4x4 calipers, 300zx vented rotors Adjustable lower control arms Adjustable Tie Rods AZ Front Camber plates 7/8" Front sway bar Rear Suspension shortened 2", powder coated red Tokico illumina 5 2ay shocks 8" coil overs with 225 lb springs Modern Motorsports disk brake adapters 240 sx rear calipers, 280 zx rotors Modern Motorsports Adjustable rear control arms 3/4" rear sway bar Wheels Enki 16x7.5" -20 offset 225x45x16 Yokohama V710 tires Replaced frame rails with 2x3" boxed steel, extended the frame rails from the front to the rear suspension. Still need to add rear camber plates, finish painting the engine bay. I have already dry fitted in the LS2 and transmission. Hope to have it on the road this summer! I love reading everyone's builds and love the creative ideas people come up with, some of thes I hope to implement on my car. I call him Frank short for Frankenstein.
  16. When you say the injectors are dead, are the connections corroded or can the injectors be cleaned, then reused? My engine has been sitting for a few years as well.
  17. I used the same 2x3 .125 wall as that was the thinest I could find. But I noticed that you brought them flush with the floor pans. I had mine up about 3/4" in the floor. I like your idea better. Nice work ...
  18. Spending two weeks in Disney world. This long weekend looking for a car show with some Z's in or around Orlando, any suggestions?
  19. Dragonfly, It seems like the cap is a little wider than the whole and if I tap on the cap, will I not bend the sides while trying to tap it in? Thank you, will give it a try.
  20. Hello, I need to install a new grease cap (not sure what it is called) on one of my 300zx half shafts. (see pics below) I'm assuming you need to press the cap and then lightly tap it in. Similar to how you install pistons into an engine block. Does anyone have instructions or suggestions on how to do this correctly? Also, what tool(s) do you recommend to install this cap? Thanks,
  21. EvilC, Thanks, I sure hope the LS2 will perform. I've always loved the 240z, but it just didn't have the power like a muscel car, so I'm hoping this engine will solve that problem. And from what I have read on this site, everyone is very happy with the performance of the LSx engines. I can't wait to find out.
  22. EvilC, Thanks for the post, it's comforting to know others are taking longer than expected on their projects. My hats off to all those who stuck with it and completed thier engine swaps or restoration. Anyone can purchase a new car, but not everyone can create a classic sports car that rivals most new cars in performance and handling. Thanks for the inspiration, I can wait until my car is finished!
  23. Jon, If you do not use the crossmember how are you attaching the rear control arms? Kim
  24. Keep it stock, get another Z to modify. One stock and one modified can't have it any better than that. Kim
  25. Congrats! You've done a lot of work to get to this stage, well done! Kim
