My 240z is almost done
  • Replies 57
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
  On 12/2/2011 at 7:31 PM, texis30O said:
Where di dyou get your LEDs in the front from?
I bought those off Ebay. I think they are a 12 led cluster.
  On 12/2/2011 at 7:57 PM, Challenger said:
What kind of gauges? Looks awesome.
Those are stock gauges with speedhut gauge faces.
  • 4 months later...
  • 4 weeks later...
CHAPTER II
So i have decided to go ahead and do a carbureted small block chevy swap into my series I 240Z. As always i will be doing all the work in my garage with the help of friends.
First my motor:
I'm hoping to get around 250+hp and 300tq at the wheels.
freshly rebuild Chevy 5.7L SBC 350.
4-Bolt main
Block has been bored 40 over
An excellent set of 882 heads
Edelbrock RPM airgap intake
Holley 600cfm carb
New Comp 268 cam kit.
New flat top pistons providing a 9.5:1 compression ratio
M/T valve covers
New Black Coated Steet Rod Hugger Headers
Second Transmission:
I will be using a World Class T5 out of a 5.0L mustang. I have rebuilt the transmission and done a few upgrades to build in a lil extra strength into the T5.
New shift forks
New shift fork inserts
heavy duty cluster gear support plate
New Input Shaft/4th Gear Bearing & Race
New Output Shaft Bearing & Race (85-95)
heavy duty input Bearing Retainer
Third Chevy SBC to Ford T5 Coupling:
In order to couple a chevy motor to a ford transmission i an using the bell housing for a chevy WC T5 transmission and a custom adapter plate.
Fourth Clutch:
Again to run a chevy motor with a ford transmission i an running a flywheel and pressure plate from a F-body camaro and the clutch is from a 5.0L ford mustang.
I'll be using a JTR kit for the engine mounts etc.
I have the drive shaft from the mustang and once i get the engine and transmission transplanted into the car; Ill get a final measurement for the drive shaft and have it cut and balanced.
I got the hood and the exhaust off the car to get ready to pull the old 2.4L L6 motor.
Finally got the SBC and T5 dropped into the 240z. The entire motor sits behind the front cross member. Next step is to get the motor plumbed and wired; also need to get the drive shaft cut and balanced.
Today i created some homemade fuel lines for my car; the design has a return fuel line that ties into the OEM return lines of the 240Z.... hopefully it works as intended.
Also installed my beloved monte-carlo bar.
Got my drive shaft shortened and balanced and changes the flange yoke (neapcor 2-2-899-1) to match my R200 4.11 diff. Work was done by Drive shaft Inc. here in Tulsa and cost me $147.
Edited by logan1
  • 4 weeks later...
got my exhaust all mocked up and welded today. I cannibalized my old twice pipe set up to make the new exhaust. So far i happy with the way the car is sounding however i need to figure out a way to raise my exhaust up a lil higher as i only have 2" of road clearance at the resonator. I bought a cheap flux core welder from Harbor freight and welded the exhaust up. Its my first time welding and it shows but hell its just some exhaust pipe.
