UofA_ZCar Posted January 22, 2012 Share Posted January 22, 2012 Where can I find the rubber fitting seen on the top left of this photo? I've checked blackdragon and MSA without luck. Any other ideas? Even if someone could point me to where I can find chunks of rubber stock like that, I can drill the holes and cut to size. Quote Link to comment Share on other sites More sharing options...
luseboy Posted January 23, 2012 Share Posted January 23, 2012 Seems like mcmaster carr would carry something like that. I'm pretty sure summit and jegs sell universal hardline insulators/mounts as well, you'll probably just have to get something like that. Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted January 23, 2012 Share Posted January 23, 2012 Call up All hose and see if they have what you need... http://www.allhoseinc.net/ Quote Link to comment Share on other sites More sharing options...
zcarnut Posted January 23, 2012 Share Posted January 23, 2012 Check with Jim Frederick who lives in Florida. His e-mail address can be found in this thread: http://www.classiczcars.com/forums/showthread.php?40701 Quote Link to comment Share on other sites More sharing options...
az240z Posted January 24, 2012 Share Posted January 24, 2012 Jim has them for the 240z only. Quote Link to comment Share on other sites More sharing options...
LanceVance Posted January 24, 2012 Share Posted January 24, 2012 Have you tried the dealer? If you can find the part number on the microfiche you might even be able to get it from courtesy... Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted January 24, 2012 Share Posted January 24, 2012 His is a 240z. Quote Link to comment Share on other sites More sharing options...
luseboy Posted January 24, 2012 Share Posted January 24, 2012 Here is what I was talking about but couldn't find before. This is what I will be using when I replace all my hardline. http://www.jegs.com/i/JEGS-Performance-Products/555/82030/10002/-1?parentProductId=763974 Quote Link to comment Share on other sites More sharing options...
Tony D Posted January 24, 2012 Share Posted January 24, 2012 They are available with a Nissan Part Number. In the fuel subforum custom solutions were discussed extensively. Quote Link to comment Share on other sites More sharing options...
UofA_ZCar Posted January 26, 2012 Author Share Posted January 26, 2012 You guys are the bomb.... thanks for all the replies! They are available with a Nissan Part Number. In the fuel subforum custom solutions were discussed extensively. Getting them locally would be the best. I went to the Fuel Delivery forum but did not see "Custom Solutions" subforum....... am I missing something? Would you mind just hitting me with the part number or a link to the subforum? Thanks Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted January 26, 2012 Share Posted January 26, 2012 The cheapest solution I can think of it this. Get a new rubber mallet and cut it up to the sizes you need. Then use a drill press and drill out where the lines will run. Then cut it almost in half to slide the lines in. I can call you tonight and talk about it with you. I'll prob go this route since it is really cheap to get a black rubber mallet. Quote Link to comment Share on other sites More sharing options...
LanceVance Posted January 29, 2012 Share Posted January 29, 2012 McMaster Carr has a few possible options HERE. Quote Link to comment Share on other sites More sharing options...
luseboy Posted January 29, 2012 Share Posted January 29, 2012 this is kinda off topic, but how important is it really to have rubber insulation? It seems like there wouldn't be that much vibration going through the lines, what would be wrong with just a simple metal clamp? Quote Link to comment Share on other sites More sharing options...
LanceVance Posted January 29, 2012 Share Posted January 29, 2012 this is kinda off topic, but how important is it really to have rubber insulation? It seems like there wouldn't be that much vibration going through the lines, what would be wrong with just a simple metal clamp? Stress fractures at the contact points with the clamp could be an issue... Quote Link to comment Share on other sites More sharing options...
luseboy Posted January 29, 2012 Share Posted January 29, 2012 Stress fractures at the contact points with the clamp could be an issue... Yes... that would pose some sort of a problem on your braking power... . Hadn't thought of that Quote Link to comment Share on other sites More sharing options...
