locktite on flywheel
Justinp551
Locktite blue on the PP to flywheel bolts and red on the flywheel to crank bolts.
Please explain...
Well this is what I got from a mechanical engineer, basically when I was taking the flywheel bolts off during a tear down the bolts were obviously tight. I so to remove them we used a torch not on the bolts but on the flywheel side to expand the metal to relieve tension so the bolts could come loose with an air ratchet. I figure if the heat from the engine could make the bolts so tight that you need to turn up tue air compressor to like 150psi for the ratchet and use a torch on the flywheel to expand the metal around the bolts, then why use locktight? I'm in no way a professional of any kind just to be clear lol. But I also didn't see any locktight(or different colored dried goo) on the bolts anyways when I took them off, so I assume it was torqued down from the factory since it was a stock motor that hadn't been touched.
I don't see how heating the flywheel would relieve tension on the bolts. Heating the flywheel will cause it to expand in all directions thus increasing tension on the bolts. Heating up the flywheel caused it to move due to thermal expansion and break the corrosion layer between the parts thus reducing the torque required to remove the bolts.
Try an impact wrench next time. It will remove the bolts in a matter of seconds.
Locktite is a much better secondary locking feature than the pressure plate lock washers and nothing in the case of the flywheel bolts.
Whoops I didn't mean to say expand, lol I just did what he told me to since that's what he learned in school. Oh yeah I was using an impact wrench not an air ratchet. They were rusty to hell as we'll lol.
I'd say definitely use red on the flywheel bolts and blue on the pressure plate bolts. You wouldn't want to use green... that's like a penetrating thread locker to use after the bolt is tightened down. Also it's not really a very strong threadlocker. Honestly who cares if it takes a little more effort to take off the bolts, at least they won't be able to come out on their own resulting in you being about 2 feet shorter. Besides that, how often do you need to remove the flywheel? Not very often at all.
The bolts will get longer as they "expand".
Read the post carefully. They heated the flywheel, not the bolts...on purpose. Obviously the bolts will also get hot and expand due to conduction but at a somewhat slower rate. It seems to me that if you want to relieve tension in the bolts "with heat" that you would heat them directly not by heating the flywheel and thus the bolts indirectly. Anyway, I think the consensus is that Locktite should be used on all the bolts.
Locktite changes the torque setting when you install the bolts. How would you compensate for that? I would rather have "dry" bolts properly torqued.
It lubricates the threads during torquing, which is a good thing assuming you adjust the torque to compensate.
I've never heard of loctite changing the torque setting... It may affect it in a dry application (letting loctite dry on the bolt before installation), but even then it will be such a minimal difference, and for something like this... I don't see it as being that incredibly important. It could be important with an internal engine bolt, but you don't want to use loctite in there, and even then, I don't think it's gonna be much of a difference. Use red loctite on the flywheel to crank bolts. Less swearing will be done when heating the bolt and applying extra force for removal than would be done when the flywheel flys off and cuts your legs off :o. Blue loctite makes sense on the pressure plate bolts since they need to be removed for every clutch change, and they aren't that big of a bolt anyways. Not to mention it's far less dangerous if the pressure plate comes off than if the flywheel does...
Admittedly I am very conservative about this but I assume the FSM torques are for dry bolts. Anytime a lubricant is added to the threads then the torque should be lowered. Dry torque assumes a higher friction coefficient. If you torque a lubricated bolt to a dry torque spec then you risk over torquing the bolt.
Definately use lock tite!! I learned the hard way. I did not use any lock tite on my last flywheel and clutch install. I torqued all bolts to spec. This lasted about 5k miles, then things got loose. I lost the clutch, flywheel, rear main seal, front trans seal and bearings!!!! And yes I have all new hardware this time too, this cost me almost 2k to fix!!
